    RenderIn causes trouble with make component
    12 Posts 2 Posters 580 Views 2 Watching
      ricdach
      Once intalled, RenderIn causes trouble on the commands - make component and make group - (at the mouse's right click propreties bar). They went gray with no funcion.
      Do anyone knows what to do?
      If I uninstall it, everythig goes normal again.
        Ricardo, I moved your question because it isn't a SketchUp bug. More folks are likely to see it in the Discussions section.
        Do you have a lot of plugins installed?
          ricdach
          Hi.
          Yes a heve a few. Does has Sketchup a limit for it?
            There are some issues that seem to be related to some plugins and the number of plugins may have some impact. Take a look at this thread and install the plugin you find there. It may help.
              ricdach
              Thanks for your quick answer and help. Unfortunatelly, I've unzipped and installed it in the plugin folder, and the gray problems still happening. Do you have another idea to solve this problem? Thanks again
                Did you restart SketchUp after installing the plugin? And did you install it correctly maintaining the file structure in the ZIP file?
                  ricdach
                  yes. It has a file (!!!ContextMenuOptimizer_loader.rb) and a folder (Archtools), nad I copy them into the plugin folder.
                  Afterwards I´ve closed Sketchup and restared again.
                  Did I do something wrong? Thnks
                    I don't think you've done anything wrong. The plugin should just run automatically when you open SketchUp. Look at File>AT Utilities and make sure ContextMenuOptimizer is checked.
                      ricdach
                      Hi there. I've checked it and the ContextMenuOptimizer is already checked. I'm using the Sketchup Pro version 8.0.4811, is there, any thing else I can do to solve this problem? Thanks again
                        I think I would contact the RenderIn folks and see if they have any suggestions.
                          ricdach
                          That will be very nice from you. Thanks a lot! A realy looking forward to find a good solution.
                            I was suggesting that you contact them since you are using their plugin. I don't use it so they'd have no reason to help me with it. It would be better if you contact them directly so there's no one in the middle.
