    โš ๏ธ Important | Libfredo 15.8b introduces important bugfixes for Fredo's Extensions Update
    Recommend Doors for residential use
    6 Posts 4 Posters 1.5k Views 4 Watching
    • pbacotP Offline
      Can anyone recommend a set of doors in the 3d warehouse for residential modeling. I am doing house models, so I want something that looks right and is correct but not so heavily detailed I can't fit them in the model. I downloaded a nice looking door from the 3d warehouse. I thought I better just remove some of the back faces on the frames, don't need those! Eventually I discovered that even the innards of the lockset was modeled with thicknesses for each part. At first I was surprised the screw heads actually sat in beveled holes, but then the oval head knob screws each probably had as many polygons that I had in the house so far! ๐Ÿ˜ฎ
      Not sure why anyone does this sort of thing, to model standard hardware which no one will ever see (except me). Someone got the modeling bug, I guess ๐Ÿ˜•
        bjornkn
        Or someone just downloaded and assembled ready-made objects instead of modeling them themselves ? ๐Ÿ˜‰
        Frankly, it would probably take you much less time to just model a few doors yourself, with full control of everything.
        • KrisidiousK Offline
          Krisidious
          SketchUp has become much more accepted in the manufacturing world and now many companies offer SU files of their doors and windows on their sites... have a look around at the big boys... some of their models suck but some are sufficient.
          By: Kristoff Rand
          • pbacotP Offline
            Your right in this case I think!
            But if SU could take my floor plan and automatically place 3d doors and windows, I wouldn't mind it. Instead I will take whatever I find useful and add features for assemblies to match my method. There is nothing unique about the doors (unless I find clients who want to pay for custom designed doors).
            Thanks Bjornkn and Kris for answering.
            Peter
            • H Offline
              Howard leslie
              Peter,
              This Dynamic Door Component may be useful for your purposes:
              http://forums.sketchucation.com/viewtopic.php?f=289&t=21350
              It's animated and you can change door size, door opening angle etc very easily with the dialog box
              Hope this helps
              Regards
              Howard L'
              • pbacotP Offline
                Thank you Howard,
                I've downloaded your door component and have been considering it for an approach to my doors.
                Peter
