    [Plugin][$] FredoScale - v3.6a - 01 Apr 24
    1.1k Posts 345 Posters 2.4m Views 342 Watching
    • fredo6F Offline
      @dedmin said:
      Do you have the model.
      The bugsplat in mirroring seems to be related to the question of unique component (again).
        dedmin
        BC1D1S1D.skp
          karros
          Found this thread (and forum) by chance while looking for some answers on google. Plugin works great, thank you!!!
            Designmark
            Thanks Fredo,
            Downloaded FredoScale today, it's fantastic!!
            I really appreciate this plugin.
            Kind regards,
            Mark.(Newby)
              merlin7777777
              I'm getting this error when i start SU (v 8):
              Error Loading File bootstrap_FredoScale.rb
              (eval):1: uninitialized constant FredoScale::T6Error Loading File ZLoader__FredoScale.rb
              no such file to load -- LibFredo6.rbError Loading File __loader.rb
              uninitialized constant Traductor::Plugin
              I'm fairly certain the directory structure is as you specify. I extracted the files from the subfolders into their own folders as specified but I also extracted those files to the plugin directory just in case.
              any thoughts?
                Jim
                Did you install LibFredo6, as the instructions say? It's required to run most of Fredo's plugins.
                  merlin7777777
                  ah - no. can't see that info in the OP. can you direct me where to go for it?
                    • gillesG Offline
                      gilles
                      I am trying to bend a profile with precision, let say a 4000mm radius bend at 90°.
                      the only way I found to do this is to first calculate the length of the arc: PI2000, then use the bend tool and type 6283,20 (PI2000) and bend 90°.
                      Could it be possible to just type the desired radius in VCB ?
                        merlin7777777
                        OK - added the fredo6, all works ok except still egtting this error on startup:
                        Maybe something to do with the double extraction I did?
                          To be sure it isn't, why don't you remove anything to do with FredoScale and LibFredo and reinstall them so you know they are installed correctly.
                          • fredo6F Offline
                            Do you use Plugin Organizer?
                            Another user had the same problem, which can be solved by setting Excluded Directories.
                            • dereiD Offline
                              derei
                              Hello, Can I use "Stretching with orientation of scaling box" with absolute value? It seems that it works only with scale ratio.
                              It would be nice to work like SketchUp native scale tool (where is you scale and input 500mm, it will scale the object to have 1000mm on the scaling axis. Or to scale the object adding a certain value more (example: +50mm).
                              Thanks.
                              • fredo6F Offline
                                Thanks.
                                If you press TAB, you'll get a dialog box where you can enter absolute values.
                                Fields in the dialog box support formulas and units, so you can add " + 50mm" to the fields you wish.
                                • pbacotP Offline
                                  I find while using box stretching that sometimes nested components move too far. They seem to move the same scale amount in relation to the component being scaled. So if you stretch a component by 8" nested components on the stretch side move 16". This does not always occur with nested components. I haven't figured out what the difference is. Is this how the tool should work? Peter
                                  • fredo6F Offline
                                    There may be some issues with nested components when small.
                                    Do you have an example?
                                    Fred
                                    • pbacotP Offline
                                      Fred,
                                      Here's an example. When I went to make the example file, I copied the component and made it unique-for before and after.
                                      Interestingly the doorknob in the original component moved as well--as if the move was made INSIDE the doorknob component itself. AND the doorknob was within a latch component--not all of which moved excessively.
                                      I suppose the fix is to explode the components,if feasible?
                                      Regards,
                                      Peter
                                      Example box stretching
                                      • N Offline
                                        narayan
                                        Hi all!
                                        It's my first post here; so pardon me if there are any unintentional lapses.
                                        I am facing a small problem with the FredoScale's toolbar: The buttons require some buffer space on the right. So, if I fold the toolbar in two columns, the width of this toolbar does not match the other two-column toolbars (e.g. the SU's own "Large tool set").
                                        Can this toolbar width be standardized?
                                        Thanks in advance!
                                          Hi Narayan,
                                          Could you post a screenshot of it?
                                          • N Offline
                                            narayan
                                            The screenshot is attached (this is link to my Dropbox account. Please let me know if there is a better way to share images. Thanks in advance!)
                                            http://db.tt/4oxATnt
                                            As the image shows, the FredoScale toolbar is wider than the other toolbars, such as "Drawing", "Construction", etc.
                                            • 27
                                            • 28
                                            • 29
                                            • 30
                                            • 31
                                            • 56
                                            • 57
                                            • 29 / 57
