    [Plugin][$] FredoScale - v3.6a - 01 Apr 24
    1.1k Posts 345 Posters 2.4m Views 342 Watching
      rock1
      great plugin fredo!. I'm really amazed by this plugin !! I found fredoscale very useful. πŸ‘ πŸ‘
      Signature removed by SCF Admin
        dedmin
        • fredo6F Offline
          @dedmin said:
          Do you have the model.
          The bugsplat in mirroring seems to be related to the question of unique component (again).
            dedmin
            BC1D1S1D.skp
              karros
              Found this thread (and forum) by chance while looking for some answers on google. Plugin works great, thank you!!!
                Designmark
                Thanks Fredo,
                Downloaded FredoScale today, it's fantastic!!
                I really appreciate this plugin.
                Kind regards,
                Mark.(Newby)
                  merlin7777777
                  I'm getting this error when i start SU (v 8):
                  Error Loading File bootstrap_FredoScale.rb
                  (eval):1: uninitialized constant FredoScale::T6Error Loading File ZLoader__FredoScale.rb
                  no such file to load -- LibFredo6.rbError Loading File __loader.rb
                  uninitialized constant Traductor::Plugin
                  I'm fairly certain the directory structure is as you specify. I extracted the files from the subfolders into their own folders as specified but I also extracted those files to the plugin directory just in case.
                  any thoughts?
                    Jim
                    Did you install LibFredo6, as the instructions say? It's required to run most of Fredo's plugins.
                      merlin7777777
                      ah - no. can't see that info in the OP. can you direct me where to go for it?
                        • gillesG Offline
                          gilles
                          I am trying to bend a profile with precision, let say a 4000mm radius bend at 90Β°.
                          the only way I found to do this is to first calculate the length of the arc: PI2000, then use the bend tool and type 6283,20 (PI2000) and bend 90Β°.
                          Could it be possible to just type the desired radius in VCB ?
                            merlin7777777
                            OK - added the fredo6, all works ok except still egtting this error on startup:
                            Maybe something to do with the double extraction I did?
                              To be sure it isn't, why don't you remove anything to do with FredoScale and LibFredo and reinstall them so you know they are installed correctly.
                              • fredo6F Offline
                                Do you use Plugin Organizer?
                                Another user had the same problem, which can be solved by setting Excluded Directories.
                                • dereiD Offline
                                  derei
                                  Hello, Can I use "Stretching with orientation of scaling box" with absolute value? It seems that it works only with scale ratio.
                                  It would be nice to work like SketchUp native scale tool (where is you scale and input 500mm, it will scale the object to have 1000mm on the scaling axis. Or to scale the object adding a certain value more (example: +50mm).
                                  Thanks.
                                  DESIGNER AND ARTIST DEREI.UK
                                  • fredo6F Offline
                                    Thanks.
                                    If you press TAB, you'll get a dialog box where you can enter absolute values.
                                    Fields in the dialog box support formulas and units, so you can add " + 50mm" to the fields you wish.
                                    • pbacotP Offline
                                      I find while using box stretching that sometimes nested components move too far. They seem to move the same scale amount in relation to the component being scaled. So if you stretch a component by 8" nested components on the stretch side move 16". This does not always occur with nested components. I haven't figured out what the difference is. Is this how the tool should work? Peter
                                      • fredo6F Offline
                                        There may be some issues with nested components when small.
                                        Do you have an example?
                                        Fred
                                        • pbacotP Offline
                                          Fred,
                                          Here's an example. When I went to make the example file, I copied the component and made it unique-for before and after.
                                          Interestingly the doorknob in the original component moved as well--as if the move was made INSIDE the doorknob component itself. AND the doorknob was within a latch component--not all of which moved excessively.
                                          I suppose the fix is to explode the components,if feasible?
                                          Regards,
                                          Peter
                                          Example box stretching
                                          • N Offline
                                            narayan
                                            Hi all!
                                            It's my first post here; so pardon me if there are any unintentional lapses.
                                            I am facing a small problem with the FredoScale's toolbar: The buttons require some buffer space on the right. So, if I fold the toolbar in two columns, the width of this toolbar does not match the other two-column toolbars (e.g. the SU's own "Large tool set").
                                            Can this toolbar width be standardized?
                                            Thanks in advance!
                                            • 51
                                            • 52
                                            • 53
                                            • 54
                                            • 55
                                            • 56
                                            • 57
                                            • 53 / 57
