Useful MAC Apps and Hardware [Ongoing Updates]
Hi Guys,
When I was back in the Stone Age using Windows
, I got very fond of a handy little utility called 'Meazure'. It was an on-line ruler.Over the past couple of years I have come across a few similar Mac apps but none as good as Meazure until now!
PixelStick http://www.plumamazing.com/mac/pixelstick/ does the job very well. Check out the screencast on the site as it explains the in and outs.Meazure allowed me to open multiple rulers which was needed at times. To do this in PixelStick I have to 'copy' the app and make multiple pixelsticks.
It looks to be free or a pay if you like! If you find it useful please consider buying as it helps the developer to improve the app.
Mike
PS: For all the Win users that have a peek in here, the link to Meazure is http://www.cthing.com/Meazure.asp
Compress PDF Workflow 6.0
Apparently Apple removed this feature in Tiger! (How annoying!
)However after a little searching, I found this Automator script, that does a fab job- although a bit fiddly if you need to tweak it.
http://www.apple.com/downloads/macosx/automator/compresspdfworkflow.html -
SmillaEnlarger 0.9.0 MAC
http://www.macupdate.com/app/mac/31807/smillaenlargerVery handy for detailed zoom of image sections
What a great App! Thanks for sharing that Mike!
http://www.pascal.com/software/freeruler/
Note: Free Ruler is only available for Mac OS X. It may work on Mac OS 9, but this has not been tested. It most definitely will not work on your stupid Windows PC.
Actually, this app would be useful if it actually stayed on top!
Tom,
I find RulerX better http://homepage.mac.com/kyasu/soft/
and to keep things 'on top' I use
AFLOAT
http://infinite-labs.net/afloat/
http://youtu.be/qSLTfII8ClUMike
Its tricky the find the download. See attached image
Hi Mike. I just tried that app, but it almost froze my computer.
Did you check your PM?
Yep, and thanks
I've been doing a lot of research to write a ruby or applescript that lets me quickly view 2 or more models for various reasons, known only to Mac users ο£Ώ
however I just found this, downloaded and tested and it's great, Free trial and a whole $5 if you like it...
I;m still going to try and write my own SU specific plugin, but in the mean time...
http://manytricks.com/moom/
anyhow thought I'd share as the search here says no-ones mentioned it before.have fun
Thanks John, downloaded, installed and tested ...... will keep it
Well worth the $5! -
recent acquisitions from the App Store:
MsgFiler: a Mail plugin that helps to move files.
Savings: personal finance
Radium: internet radio player
Contacts Cleaner: basically helps you keep your address book tidy and without duplicates
Cloud: allows you to share images, links, music, videos and files -
I can see great potential in this one especially for making transparent "flipbooks" in PNG format for overlaying on a sketchup model.
Hi Guys,
While looking for a simple 'one trick pony' app to simply crop pics I came across Kroper. It does just that and no more. Just drop the image in and 'krop it'. It can be downloaded here, http://www.macupdate.com/app/mac/35241/kroper Oh, and its free!
Mike
definitely the best 3rd party utility app i own: Keyboard Maestro
Keyboard Maestro 11.0.4: Work Faster with Macros for macOS
Keyboard Maestro is the leading software for macOS automation. It will increase business productivity by using macros (or short cuts) with simple keystrokes.
(www.keyboardmaestro.com)
it's a macro editor/creator which works very well with sketchup..
[for instance, i have a macro which will (open component, select all, explode, explode again, generate faces(tos),exit component edit) all with one keystroke]i have it set up to do a few more things as well and hope to incorporate it more in the future (im just a little hesitant to set up 50 macros at once as i'll probably forget them.. i generally try one or two new ones a week)
worth checking out though..
Hi Guys,
I came across this useful little 'stand alone' app called iSplash. What it does? 'Choose any image and iSplash will turn it to grayscale. Then, choose any part of the image to restore the original color.'
Its on sale at the moment for 99cent, normal price is $4.99.
Attached is an image of my mate Val standing beside a statue of Mr Picasso in Torremolinos ..... notice the strong resemblance .... Val now think they must be related
Mike
PS: Val woke up that morning missing a tooth! He couldn't remember how it happened
re: the keyboard maestro app i mentioned a few posts back..
here's an example of it being used to divide a single group into 110 individual groups (via a thread here at scf)
http://forums.sketchucation.com/viewtopic.php?p=336059#p336059
Hi Guys,
The more of those useful little apps I accumulate the more difficult it is becoming to locate them in Applications! I often find that I know what the application I am looking for actually does BUT for the live of me I often can't remember its name! I did a search around for an answer and found Tab Launcher for 99cent! http://tablauncher.com/index.html
I've installed it and sorted out 8 tabs that cover the various types of apps I use. It was just a case of then dropping in the various apps. No more searching around or trying to remember the apps name!
Mike
@mike
That's how lion is goingto be setup. Apple is taking some of their iOS stuff and putting it in osx.
Namely, the way you can organize your apps on an iPhone will now be possible on the computers (supposedly with a better way to launch said apps as well via launchpad)I guess we'll find out soon enough.
