    Large Terrain Mesh
    105 Posts 11 Posters 26.4k Views 11 Watching
      dbwv69
      @solo said:
      I doubt very highly that you can reduce that to a point it opens in SU and resembles anything close to what you need, but lets try, I have all sorts of tools to try with.
      I'm trying Vue-SU first, but that will take a while to import.
      I do too but was going to divide it into several sections as to lighten the load of each.
        dbwv69
        If I can figure out why my 90% reduction in Deep Explorer isn't coming out like yours, I believe my problem may be solved. I have tried numerous variations of settings but I start to lose detail at around 50% and it gets worse from there. I even managed to make what resembled a spiked cactus once.
        • B
          bjornkn
          @dbwv69 said:
          What is GP?
          Guide point.
          I suppose you not knowing that implies that you never tried the method at all, but just were thinking that it would be way too much work - even just to try it?
            dbwv69
            @bjornkn said:
            @dbwv69 said:
            What is GP?
            Guide point.
            I'm willing to try anything that will help me to achieve my goal. Remember, I'm not a Sketchup expert, or an expert with 3D software in general, far from it in fact. By and large, I am learning as I go and will undoubtedly make a lot of mistakes along the way.
            Honestly, and I am showing my ignorance here, but I am not completely sure what the guide point method entails. If you would care to enlighten me, I'd be happy to give it a try.
              dbwv69
              Solo, what settings did you use when you reduced the mesh sample I provided earlier? From what I can tell, the settings are very touchy and believe that's where the problem lies.
              • B
                bjornkn
                Just for fun I ran a quick test with Mootools Polygon Cruncher.
                I removed 95%, and was left with 9770 faces from 198000. BTW, that dxf file is full of duplicated vertices.
                As you can see on the leftmost version there's a lot of lines at the edges - that's because I told it to not touch the edges. Which means that all the edge vertices are exactly as in the original, and should very easily connect to the next patch as all the vertices should align.
                The middle version is smoothed/softened and the right version is just softened with no normal smoothing.
                  dbwv69
                  I'm sure it could work fine even at more compression?
                  I'm impressed. The results you obtained look very much like the example Solo posted earlier. Now if only I could manage to do the same, my headache might go away and I could begin to do some real modeling. Though I must admit that I am not looking forward to the challenge of roadbuilding. LOL
                  • B
                    bjornkn
                    Try anything? Except open your wallet ie πŸ˜‰
                    It's written on that image with 3 brown meshes posted a while ago.
                      dbwv69
                      Here is another "tutorial.
                      And I forgot to mention that due to it's sheer size, I can't open the full DXF file, or even significant parts of it without causing Sketchup problems or outright crashes. It has to be reduced first regardless.
                      • B
                        bjornkn
                        Then you would have to open your wallet first, as Polygon Cruncher costs some money, as do DE and Vue πŸ˜‰
                        OTOH, my first run ended up very badly in the Cruncher because there was all these non-merged points in the mesh. Try to merge points with DE before you polyreduce it?
                        You would look forward to it if you were using Amorph πŸ˜‰
                        • B
                          bjornkn
                          No it doesn't. You could build each part separately and then assemble them afterwards when they are low-poly.
                          You should be able to Sandbox/from contours to stitch them together - or do it manually.
                          Be prepared to do some Edge flipping too..
                          • soloS
                            This is what your mesh looks like.
                            It's too big to crunch right now as it requires more than 12Gb of ram, which is all I have on this machine, if there was a way to trim the sides or even split in two parts, I'd be able to do this easier.
                              dbwv69
                              I was not aware that the mesh had "non-merged points". They had to have been caused by Global Mapper because that is the program I used to create the file. How do I detect and merge them with Deep Exploration?
                              • B
                                bjornkn
                                Join Equal Points IIRC
                                  dbwv69
                                  This is the best I have been able to get after joining points and applying a 90% reduction using Deep Exploration. All detail is lost and the surface is a mess. Something is clearly wrong somewhere. The default setting produced something that looked even worse.
                                  Does someone want to tell me EXACTLY how it's done?
                                    mac1
                                    @solo said:
                                    You may want to check the dem file, it's kinda wierd, hard to explain, lacks all detail.
                                    Open ok in Global Mapper, cannot export though just the viewer
                                      dbwv69
                                      Here is another "tutorial".[attachment=0:20u6n4iw]<!-- ia0 -->GPgrids.jpg<!-- ia0 -->[/attachment:20u6n4iw]
                                      As I stated earlier, opening my wallet isn't a matter of choice at this time. Unfortunately, I have to make due with what I have or can get for free.
                                      So guide points are just another word for tracing, or at least that's what I've called it in the past.
                                        dbwv69
                                        It's a beast of a mesh to be sure. That's why I was testing the sample prior to carefully retracing individual sections in Global Mapper prior to export. I haven't created the individual sections yet because I was focused on achieving a solution to the reduction problem first.
                                          dbwv69
                                          @bjornkn said:
                                          The amount of detail is entirely up to you, with full control, and would not take forever. Took about 10-15 min to place ~1400 guide points on the rightmost terrain.
                                          I think you get a bit blinded by the massive amount of data in the mesh, and think that it must be precisely like that in real life. But in reality it shows a smoothed version (3x3m) of the terrain that looks like it's covered in fine sand or snow when you get close - no crisp details. It's like a heavily blurred photo. A real terrain doesn't look like that at all in the details.
                                          Most of my problem is directly related to smoothing. In most attempts I have made, the terrain came out very soft, with most of the edge details lost or obscured. What I am hoping to achieve is a crisp division between all of the major features like ridge lines, stream beds, etc... The example Solo posted shows the exact image I have had in my mind while trying to achieve my ultimate goal of simplification without losing the important details.
                                          I'll admit that it is easy to get blinded by the sheer amount of data involved but at the same time I have always been aware that I don't need to show every detail. In essence, I want to preserve the overall shapes while maintaining a sharp division at boundary lines.
                                          Do you have a photo of the area? Ground level? The shapes indicates that there must be lots of boulders, rocks, gravel everywhere?
                                          Where is it?
                                          The shapes are actually a bit misleading. While there are some rocky outcrops, most of the area, with the exception of the valleys, is forrested terrain. As irony would have it, Lidar data tends to pick up a lot of ground clutter which only contributes to my problem.
                                          BTW, Solo wrote that he used Deep Exploration, which costs $400-$700 per year πŸ˜‰
                                          Nice program though. I have an older version of the CAD/expensive version, bought when it was much cheaper and with no annual fees. No skp, Collada, FBX though.
                                          Yes, from what he wrote, I too assumed that he used Deep Exploration. As it turns out, I also have an older copy but had completely forgotten about it. If I can learn the method Solo used, my problem may be solved, especially if I can achieve results like the ones he posted.
                                          • soloS
                                            I sent you a PM with settings, I have also managed to reduce the full scene from 650MB to 65MB keeping the detail similar to the sample above.
                                            • 4 / 6
