    Large Terrain Mesh
    105 Posts 11 Posters 26.4k Views 11 Watching
      dbwv69
      @bjornkn said:
      But then you already have the solution then? Your 25 sq miles should be around 5-6 million triangles at 3x3m resolution, which should convert to around 150k faces in SU, which might work. Then you just have to figure out how to texture it with a 70+ Mpx orthophoto to get 1x1m resolution (which isn't much btw)...
      Texturing with the orthophoto no longer a concern to me because I have already solved that problem and it's resolution isn't critical because it will only be used as a background texture on the mountains.
      OK. As you don't seem to be interested in advice along that road (if it costs anything at all) I think I'll stop spending my time on this "journey" of yours.
      Looking forward to see the results though.
      That's probably a good idea because debating "free" v/s "paid" isn't doing a thing to help me achieve my goal. BTW: Did I detect a note of sarcasm there?
        mac1
        dbwv69
        I have had some what similar problem with Su=>Collada=>MeshLab=< Su( Collada) and then see a number of self intersecting faces and the obj works much better. Belnder has bug reports, ref. Collada import, my check of latest stable release shows the patch is not yet included but fix is known.
        Ploy reduction is one of the easier filters in MeshLab to apply ,but as I am sure you know there are many more. I was thinking the Poisson smoothing could help your problem. I dabble with MeshLab so if you can post even a section I'll take a look. May not get any where but will at least try.
        G day and good luck
        • charly2008C
          charly2008
          Hello Geo specialists,
          I am a beginner in terms of geographic information systems. But I am very interested in this subject.
          I have a question and would be delighted to receive a response from you. Is it possible to produce a TIN from SRTM 90m Digital Elevation Data and how is it done?. I own Global Mapper 11. Thanks in Advance.
          Charly
            dbwv69
            @mac1 said:
            dbwv69
            G day and good luck
            Thanks for the help, I appreciate it.
            I was reading about the Poisson smoothing and while I have not yet experimented with it, the reports I read do sound promising. So far, using MeshLab I have been able to achieve decent results by applying a Quadric Edge Collapse Decimation filter, which produced a TIN that closely resembled the original symmetrical mesh, only at a greatly reduced polygon count.
            However, I did notice one thing that could potentially cause problems with proper alignment of the completed terrain meshes. The mesh somehow gets rotated on it's axis when it's imported back into Sketchup. I don't know if it's caused by MeshLab or some part of the convoluted import/export process needed between the various programs.
            I extracted a small sample of the area I am working with from the original 3 meter Lidar data, and exported that to a DXF 3D mesh file at full resolution. I can convert it to other formats if needed. See attachment: Sample Section DXF.zip
              dbwv69
              Charly
              For the best results, using Global Mapper, you can export the data to either a DXF Mesh file or a DXF 3D Face file but you will need Sketchup Professional to import it.
              Alternatively, using Global Mapper, you can export the elevation data to a DEM (Digital Elevation Model) and import that into the free version of Sketchup but the results (in my opinion) aren't as good.
              Another method is, using Global Mapper, export the elevation data to an XYZ file and import that into Sketchup as a point cloud with the Cloud plugin. You will then have to triangulate it with either the Cloud plugin or another plugin designed for that purpose.
              Lastly, using Global Mapper, you can generate contour lines and export them as Vector data to a DXF file and import that into Sketchup then convert the contours to a mesh using the Sandbox tools but again, you will need Sketchup Professional to import the DXF file.
              Whichever method you choose, it is still possible to have problems with the amount of data involved, depending on the size of the area you are using. If you have problems, try changing the sample spacing to a higher number in Global Mapper, prior to export. It will reduce the amount of data but the resolution will suffer as a result.
                mac1
                Thanks for the file, I have SU7 free with the dxf import add on so was able to open file, used TIGS obj exporter to create obj file for MeshLab. In my dabbling https://sites.google.com/site/sagesuwiki/tutorials/tips#TOC-MeshLab:-Centric-View-of-Polygon-Me I have convinced my self the export by kmz is better than dae alone and that I seem to run into problems with dae and MeshLab declaring self intersecting faces. I have also noted the axis issue and scaling but previous apps I did not worry too much because of the relative small components I was dealing with.
                For your case in MeshLab ( obj file) there was 479K+ duplicate vertices deleted. ( I don't merge vertices because the model can get distorted. For terrain probably Ok but not component model. Zero self intersecting faces, zero non manifold vertices and edges I could see (ML paints them red so for large mesh they get hard to see). Did quad collapse decimation and at Ml recommended value collapsed down to 49k+ vertices and 98k+ faces. Will dabble some more but for what it is worth here is the dxf file exported from MeshLab fileBaseline ML.zip
                • charly2008C
                  charly2008
                  Hi dbwv69,
                  Thank you very much for your detailed explanation. I will try the options described.
                  Charly
                  • B
                    bjornkn
                    I'm afraid I couldn't hide it completely 😉
                    Nevertheless I couldn't resist wasting another hour+ on this terrain after you posted that "little" dxf detail.
                    All free tools (I think there are free guide point tools? Although I did use the one in Amorph) 😉
                    I will not post the Amorph version... It didn't have a chance trying to polyreduce that beast of a terrain in any reasonable amount of time, but could easily build a terrain on top of the dxf.
                    • soloS
                      Hey guys, I have not read this whole thread, I just jumped in here, I'm guessing it's about using large terrains, if not please ignore everything from here.
                      I say do not do it, SU buckles at it's knees, use a third party app like Terragen or Geo control, even the new Vue can do it great these days.
                      If you do need to the use a good reducing app like deep exploration (very expensive).
                      Here is your sample, brought directly into SU was 35MB, reduced to 2.6MB, can go lower but this was a good balance as nothing much in detail was lost, I reduced it by 90%.
                      Softened:
                        dbwv69
                        Very good work! The results you achieved are exactly what I am looking for. How did you do it?
                        [attachment=1:20afzex3]<!-- ia1 -->sample section reduced by 90 percent.jpg<!-- ia1 -->[/attachment:20afzex3]
                        Softened:
                          dbwv69
                          I obtained similar results using the method mentioned earlier. The face counts are still high but it is definitely a step in the right direction. I'm thinking I can get a reduction of around 90% and still maintain just enough detail in the valleys to make it useable.
                          It may take some tweaking to get it just right but I am more convinced than ever that it can be achieved.
                          For your case in MeshLab ( obj file) there was 479K+ duplicate vertices deleted. ( I don't merge vertices because the model can get distorted. For terrain probably Ok but not component model. Zero self intersecting faces, zero non manifold vertices and edges I could see (ML paints them red so for large mesh they get hard to see). Did quad collapse decimation and at Ml recommended value collapsed down to 49k+ vertices and 98k+ faces. Will dabble some more but for what it is worth here is the dxf file exported from MeshLab file[attachment=0:24kp526k]<!-- ia0 -->Baseline ML.zip<!-- ia0 -->[/attachment:24kp526k]
                            dbwv69
                            The first example (hand sketch) you posted reminds me of an idea that I had originally considered, where I thought about "tracing" over the grouped contour lines to capture all the major details (shape) of the mountains. After some brief experimentation, I quickly discovered that it would have taken forever to do because I wish to maintain as much detail as possible in the lower elevations and especially in the stream beds. It is still an interesting notion, however.
                            [attachment=0:2qr61cuc]<!-- ia0 -->dxfterrs.jpg<!-- ia0 -->[/attachment:2qr61cuc]
                              dbwv69
                              This is slightly off topic but I just had to say that I had a look at your website... NICE WORK!
                              • B
                                bjornkn
                                The amount of detail is entirely up to you, with full control, and would not take forever. Took about 10-15 min to place ~1400 guide points on the rightmost terrain.
                                I think you get a bit blinded by the massive amount of data in the mesh, and think that it must be precisely like that in real life. But in reality it shows a smoothed version (3x3m) of the terrain that looks like it's covered in fine sand or snow when you get close - no crisp details. It's like a heavily blurred photo. A real terrain doesn't look like that at all in the details.
                                Here's a "stream" in a flat terrain, 15m wide and 3m deep with vertical sides - 15 faces.
                                On the right side is a "gridded" version with 3x3m resolution (using Terrain Reshaper - free) and ~8000 faces!
                                Doesn't look much like the "real" terrain, even though it has "much more detail"?
                                Do you have a photo of the area? Ground level? The shapes indicates that there must be lots of boulders, rocks, gravel everywhere?
                                Where is it?
                                BTW, Solo wrote that he used Deep Exploration, which costs $400-$700 per year 😉
                                Nice program though. I have an older version of the CAD/expensive version, bought when it was much cheaper and with no annual fees. No skp, Collada, FBX though.
                                • B
                                  bjornkn
                                  Thanks for the coordinates.
                                  After having a look I'm even more confused why you insist on having all the details in the mountains, with ridge lines etc, when they are not visible at all because of all the trees?
                                  The perceived landscape is even much smoother in the hilly areas than on my simplified versions. Not only will a more detailed version contain way too many faces, but it will also look wrong because you should really "model" the forests instead of the ground below, as it isn't visible anyway.
                                  And at the same time you have the ground level with Lidar clutter, too little details and too smoothed. I think you'd be much better off with making this by hand. That way you may even end up with a full model that is managable in SU 😉
                                    dbwv69
                                    While the primary purpose of the terrain will be to display various scenes from the area, it will also be used to show mining and other activity which requires that some level of detail remain in tact. The mountains do not have to have much detail, other than the general shape, but the lower elevations absolutely must have crisp boundaries because of the proximity of homes, roads, streams, and railroad lines, all tightly packed in among the mountains. You would have to see the area up close to understand fully because satellite images just don't do it justice.
                                    Drawing an area of this size by hand is not a task that I would want to even contemplate doing. Especially with the terrain involved.
                                    • B
                                      bjornkn
                                      Do you really have any choice? Even though DE may do a good job reducing the mes it will not add any detail where there is none. Neither will it use different rules in selected areas (my version doesn't anyway).
                                      Have you actually tried the GP/Triangulate method? It is actually quite fast, and allows you to add detail exactly where you need it, and it allows you to add some edges/creases where there are only ssoft dunes in the dxf mesh.
                                      Like on this little 100 faces patch elevated 50cm to make it visible entirely above the ground. 5mins?Clipboard-4.jpg
                                      • soloS
                                        Vue9 can import the dxf, dem, ect, then assign material based on slope, height, orientations or even selected with paint brush tool.
                                        Here is a very fast example.
                                          dbwv69
                                          What is GP?
                                            dbwv69
                                            I'm a bit confused... So you used Vue to do the reduction shown earlier? I thought you had used Deep Exploration but when I tried a 90% reduction, it it didn't look very good.
                                            • 2 / 6
