    Why can't I make this a solid?
    7 Posts 2 Posters 579 Views 2 Watching
      d12dozr
      I have a model (made with TT's Bitmap to mesh plugin) that I cannot make solid. There are 4 problem spots, marked in red in the model. For some reason, these 4 faces are not meshing with the rest of the model. I've tried deleting the faces and redrawing them...its not working...arrgh! Any ideas?
      Tile.zip
      http://goo.gl/f7ooYh
      • jeff hammondJ
        i moved some vertices up in order to make the problem face and the one next to it all one face..
        SU Icon PP Tiles_fix.skp.zip
          d12dozr
          Yes, that's exactly what I was trying to do, Jeff...thank you! It took me a bit of playing to figure out what you did, and fix my original file. All the vertices were coplanar to start with...SU quirk?
          • jeff hammondJ
            @d12dozr said:
            .SU quirk?
            yeah, i think so (but SolidInspector recognized the errors so maybe not?)
            it's not like i saw a problem and fixed it though.. i just tried a couple of things and connecting the faces to make the larger single face worked.
              d12dozr
              Usually I play a little bit and get it to work, just not this time. I do appreciate your help πŸ˜„
              • jeff hammondJ
                here's something weird.. i copied a section of the problem area into another file then cut/closed the bottem and made sides.. it's recognized as a solid and i didn't do anything to the red face.. ?
                quirk.skp
                  d12dozr
                  Yeah, I did almost the same thing before uploading...I drew a cube around 2 of the problem faces, intersected with model, then deleted the rest of the mesh and got a solid with out touching the red faces. When I tried to paste the now corrected face back in the original model, it reverted to 'not solid' πŸ˜•
