    Football Panels
    22 Posts 7 Posters 1.7k Views 7 Watching
    • soloS Offline
      John,
      Can you post what you have already? that will make it easier to help.
      BTW, welcome to SCF.
        Jsketch
        here's what I got so far.
        • soloS Offline
          This is what you want right? (excuse ralph lauren ball, but it was first image I found that looks like what you need).
          The indentations are the 'ribs'?
          http://4.bp.blogspot.com/_A2sH6UV9KQ8/SLXvNTdTQbI/AAAAAAAAAlY/jb4543mj8fc/s400/rugby+striped+mini+rugby+ball.jpg
            Jsketch
            yes exactly
            • soloS Offline
              Can you post your model?
                Jsketch
                do you mean the sketch up file, or what I'm trying to model it after? I'll attach the .skp file anyway
                rugby ball.skp
                • soloS Offline
                  Here is a start.
                  rugby%20ball[1].skp
                  • StilTegS Offline
                    StilTeg
                    I had an idea without plug-ins but my SU just crashed, I'll have to give it another try
                    doing technical engineering on SketchUp ... without plugins
                      Jsketch
                      thanks solo, how did u get everything so smooth?
                      • soloS Offline
                        a plugin called Artisan. (put in search)
                        Hope you succeed.
                        (off to bed almost 3am here)
                          Jsketch
                          I'm sure ill get there, thanks for the help
                          • Alan FraserA Offline
                            Alan Fraser
                            Surprisingly tricky for something so simple. You can probably do some of this with Rubies, but I couldn't be bothered trying to work out which ones...so I just did it by hand.
                            rugby ball.skp
                            3D Figures
                              Alan Fraser
                              Of course, the easy way would be to just lathe the basic shape, then apply a texture, using the spherical map setting in the UV Tools ruby.
                              rugby ball.skp
                              3D Figures
                                bjornkn
                                A simple way to make a rugby ball would be to lathe the profile/curve a quarter circle.
                                Then extrude each end/inside face a few mms.
                                Then scale that face towards the center, once top/bottom and once outside towards center - about .98?
                                Then you make it a component and rotate/copy 3 copies.
                                A little tweaking and smoothing and you're done 😄
                                Another way would be to use Joint Push Pull tool.
                                Curviloft, Artisan, Amorph are all plugins that could be used here.
                                • honoluludesktopH Offline
                                  honoluludesktop
                                  OK, just how did you do the crease without a plugin?
                                  • StilTegS Offline
                                    StilTeg
                                    Without PlugIn, I created the quarter sphere, Made it longer in one direction, then resized just the 2 flat faces remaining (leaving the corner untouched) and copied it 3 times around that corner ...
                                    Exagerated, this is one result
                                    FootBall.skp
                                      Alan Fraser
                                      hd, I routinely leave creases in all my people and other organic stuff...mostly to delineate muscle groups, facial features, knuckles etc.
                                      The football was easier as it's a more regular shape. I used the smoothing slider just enough to smooth the panels, but not enough to smooth the seams. Then I turned off hidden geometry and rectangular selected the whole thing (as opposed to triple-clicking it). This selected all the smoothed faces as a single surface, plus all the yet unsmoothed seam lines. I then used the smooth dialog again...but with both boxes unchecked...turning it up until all the seam lines disappeared.
                                      They disappear but don't smooth (because the normals box is unchecked)...hence a crease. 😄
                                      3D Figures
                                        honoluludesktop
                                        Al, OK, still not that easy to do (for me), but I understand it. Thanks.
                                        • arail1A Offline
                                          arail1
                                          I do wish the workflow between SketchUp and modo was a bit more fluid. Deformations like this are a one button task in modo.
                                            Jsketch
                                            cool render arail1, that's what I was hoping to do, Im' gonna try to make a nice bumpy texture for the ball when I have time, I'm new to sketchup and rendering so it will probably take me some time.
