    [Plugin] 2D Tools
    791 Posts 178 Posters 807.6k Views 177 Watching
      As you can see I have no issues with 2d filleting - Vista + v7 or v8 fillet_test_Capture.JPG
      Have you tried reinstalling the 2Dtools in case one is somehow corrupted [I can't think how it might be though!].
      Have you tried repairing your Sketchup installation in case it's corrupted in some minor way ?
        SketchUpNoobie
        Reinstalling 2Dtools now. How would I go about repairing my SketchUp installation? ๐Ÿ˜•
        SketchUpNoobie: the complete noob in all things SketchUp.
          No exactly sure on XP - perhaps someone else can chip in too - on Vista... Exit all apps... Then Control Panel > Programs & Features...
          Find Google Sketchup v7 in the list, highlight and click UnInstall/Repair button. When prompted choose Repair and it should run and repair the installation.
          If that doesn't work you might need to do a full install - it shouldn't affect any Plugins etc you have installed already...
            SketchUpNoobie
            I found how to do it but it can't find the installer for SketchUp. I must have deleted it. How could I completely reinstall SketchUp 7.1? Is there some place you know that I could download it from?
              Luckily it's linked here http://forums.sketchucation.com/viewtopic.php?p=315903#p315903 ๐Ÿ˜ฎ
                SketchUpNoobie
                Thanks. ๐Ÿ˜„ And do I have to do anything to keep all my plugins, styles, templates, etc.?
                  If you do a 'reinstall' it should keep all of the already added stuff and simply renew the required program files.
                  To be on the safe side you could always make copies of your Templates, Components, Materials, Styles and Plugins folders etc and then reinstall, after that check if the custom Templates, Scripts etc are still there, if not you have copies to move over.
                  It's a good idea to have a back-up copy of your custom files/folders in case of a disaster anyway - I suggest you burn a CD/DVD of them and keep it safe for unforeseen problems...
                    SketchUpNoobie
                    But I'm not really reinstalling am I? I'm going from v.7.1 to v.7.1pro trial. I have all the files backed up on DropBox so I should be good.
                      The difference between Free and Pro is minimal on the install - they are very similar and the core program parts are the same - it's just that after the time limit is up some v7.1 features no longer work, unless it's fully licensed...
                        SketchUpNoobie
                        I reinstalled both 2Dtools and SketchUp but I'm still getting the same thing. Is the plugin conflicting with another plugin or program? Weird thing is, every other part of the plugin works. It's just the fillet tool that I'm having problems with. ๐Ÿ˜•
                          ๐Ÿ˜•
                          As all of the 2Dfillet's methods are wrapped in a class, and it only uses built-in API calls... I'd expect no clashes.
                          Have you tried resetting hardware acceleration etc in preferences to see if that is affecting anything [clutching at straws here!]
                          To check if script that loads after 2Dtools IS messing something up you could try and copy/paste this into the Ruby Console + <enter>
                          load '2Dtools/2DfilletTool.rb'
                          Then try to use the 2Dfillet tool - if it works we know something is clashing if not we are no worse off...
                          If it's still bust try temporarily renaming 'Plugins' as say 'Plugins_Disabled' and then make a new 'Plugins' folder; now copy into that the following files/folder that are needed for the 2Dtools to work:
                          2Dtools folder with all of its contents intact
                          2D#.rb
                          deBabelizer.rb
                          Restart Sketchup.
                          If 2Dfillet now works we know there's a clash with something that's now not loading.
                          If you've recently added some scripts try copying those over a few at a time and restart/test to see if you can still use 2Dfillet.
                          If you get a culprit let me know
                          Remember to copy the scripts so the origin set of plugins is not changed.
                          Swap the Plugins folders' names around so the origin is now called 'Plugins' again...
                            SketchUpNoobie
                            @tig said:
                            :? Have you tried resetting hardware acceleration etc in preferences to see if that is affecting anything [clutching at straws here!]
                            No luck.
                            When I use the tool, the same thing happens. I get this error in the console. Error: #<NoMethodError: undefined methodexplode' for nil:NilClass>
                            C:/Program Files/Google/Google SketchUp 7/Plugins/2Dtools/2DfilletTool.rb:404:in create_geometry' C:/Program Files/Google/Google SketchUp 7/Plugins/2Dtools/2DfilletTool.rb:197:in onLButtonDown'
                            C:/Program Files/Google/Google SketchUp 7/Plugins/2Dtools/2DfilletTool.rb:404`
                            Wahoo!!! It works! ๐Ÿ˜ I'll add stuff back in and let you know when I find out what plugin it is that was causing the problem.
                            I should have tried this first. ๐Ÿ˜ณ I will in the future.
                              The error you [eventually] reported occurs after some grouping and copying etc - it's obviously failing.
                              We seem to be looking for something that overwrites base classes like group methods. I know SketchyPhysics has caused some problems in the past - try re-enabling that if you have it, and see what happens...
                                SketchUpNoobie
                                Sorry for not checking that sooner. ๐Ÿ˜ณ Not sure what you're saying about grouping . . . ๐Ÿ˜•
                                Re-enable? Like reinstall? If I copy over all the plugins except for SketchyPhysics and it's components, the fillet tool works so SketchyPhysics seems to be the guilty plugin. Should I just reinstall it? I don't really use it so I could just delete it.
                                  Many complex tools do some temporary 'grouping' in the back ground, although by the time you see the result they've been erased or exploded etc.
                                  2Dfillet is one of them.
                                  Some tools rewrite some base classes' methods which can mess up other tools using them.
                                  If the error only occurs with SketchyPhysics 'loaded' then move it back into the disabled 'set' and then try all the rest.
                                  If you still have a working 2Dfillet tool and you don't need SketchyPhysics so much leave it disabled...
                                  You can always swap back briefly when you need it.
                                  When I said 'reinstall' I just mean move from the disabled set into then Plugins folder...
                                  You could also check you have the latest version of SketchyPhysics as it might have fixed this issue... ๐Ÿ˜•
                                    SketchUpNoobie
                                    Alright, I just disabled SketchyPhysics for now. If I need it I'll go download the newest version.
                                    Thanks a ton for taking the time to help me out TIG. And thanks again for this awesome plugin.
                                      That's why we are here... to try to help those that try to help themselves... โ˜€
                                        SketchUpNoobie
                                        That rarely ever works. ๐Ÿ˜’
                                        • E
                                          ed1732
                                          it might help a lot
                                            define
                                            @earthmover said:
                                            @define said:
                                            if one 'sotospeak' could make the 2dtools work with
                                            your 'work-planes' too? This would make it into something even more versatile.
                                            This would in fact be quite redundant. The work planes are used in a similar manner to the 2D tools, as they create a "shield" to prevent the inferencing of the native tools to the geometry on the opposite side of the plane. You can draw directly on it as it's a locked group and delete it at will. The 2D tools do much the same except they are restricted to the X,Y axis for 2D drawing, but still allow you set the Z, which creates an invisble 2D work plane on that height. The work plane plugin allows similar restriction, only it's not restricted to X,Y only and it works with the native toolset. You could technically set a work plan on the x,y axis at a Z height and use the native tools to draw in restricted 2D. Using the 2D tools to go the other direction would negate them from being 2D at all.
                                            hello earthmover,
                                            I came back to this task from one year ago, since I just searched the forum for my own entries on this issue.
                                            You have to know, that I'm comming from the CAD-world with their 'sketch-planes' (solidworks and the like)
                                            and it would come in handy in sketchup, if I could use the 'workplane command' like these too.
                                            I would like to be able to constrain/project any points that I catch in 3d 'over' that workplane to the workplane.
                                            Same like setting the z-elevation to zero or else with the 2d-tools..but to any given plane.
                                            Only difference: projecting any snaps in 3d-space onto that plane in 'normal' direction.
                                            If there's an option for this, please let me know. did'nt find it. best claude
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 39
                                            • 40
                                            • 18 / 40
