    Re: [Plugin] Another Mirror Ruby
    31 Posts 15 Posters 39.4k Views 15 Watching
    • I Offline
      ideas_arte
      Thank you very much, a basic tool and very useful!
        bjack56
        Thank you...works great, once I figured out to "right-click.save as" the image. 😍
          Ben Ritter
          Thanks for the script. However, I get a Bug Splat when I do not erase the original. I do not have this problem with SU 6. I'm running SU7.
            dedmin
            Bugsplat with Outliner open! SU7.
              lapx
              I'm getting the bugsplat as well and I'm using Su6. It worked fine before. But not working these days?
              It occurs when answering "no" to erase original. BUGSPLAT! everytime.
                lapx
                There error occurs with all three scrpits that I have: mirror 3[1].0rb , mirror2.8.rb and mirror.rb.
                I tested each one while temporarily renaming the others and each one failed with a bugsplat.
                Might there be conflicts with some other script(s)? 😲
                  dedmin
                  Can the Bugsplat when Outliner is open be fixed? I always forget about this and crash SketchUP!
                    You have to 'roll-up' the Outliner window to avoid a splat - it's a known issue with Sketchup itself... not any tool per se... You should never use any tool that makes and deletes instances in succession with the Outliner 'rolled-down'...
                    I have posted an updated version here http://forums.sketchucation.com/viewtopic.php?p=276512#p276512
                    Don't worry about the 'group.make_unique is deprecated...' error messages - it's a known mistake in the API error reporting, and Thomthom has been pressing to get it removed - you DO need to use group.make_unique in some circumstances...
                      dedmin
                      I see - thanks TIG!
                        rock1
                        and the great autocad mirror comes to sketchup!!! whoa..yippee!!
                        Signature removed by SCF Admin
                        • 2 / 2
