    Lumion - Test drive
    extensions
    209 Posts 31 Posters 100.7k Views 31 Watching
    • GaieusG
      That's some crazy amount of wind on those poor plants, Bruce!
      Cool video though. I see you figured out how to animate (move) things like that train (true that you'd done with the ship earlier, stupid me...)
      • marvins_dadM
        marvins_dad
        How does it work for interiors...not too bad.
        Seems there is ambient light and anything white really glows and adds more light (kinda).
        I believe they have a light material, but I didn't try it out.
        [flash=640,390:3jisf6f2]http://www.youtube.com/v/CdqepN8mD-U[/flash:3jisf6f2]
        My Gallery
        • jason_marantoJ
          jason_maranto
          I'm finding all these videos fascinating -- does the software have a Angle of View/Field of View/Focal Length modifier for the camera? The reason I ask is I find the perspective distortion to be too extreme when rotating the camera (the strong fisheye effect at the corners makes me a bit dizzy).
          Best,
          Jason.
          • marvins_dadM
            marvins_dad
            There is an Exposure and Focal Length setting (in mm). The default setting is ISO 400 15mm.
            I hadn't looked at that yet - did notice the fisheying with the interior...figured I would check that out next time around.
            Best,
            Jason.
            My Gallery
            • jason_marantoJ
              jason_maranto
              Yeah 15mm would do it 🤢 -- something along the lines of 50mm would be much easier to enjoy the cool stuff in these videos ☀
              Best,
              Jason.
              • GaieusG
                Yes, there is a focal length setting (with some other generic camera settings). It really needs some playing around to get my favourite settings (and you would probably use something different for outdoors and for tight spaces like indoors, too).
                As for the very white; any rendering engine would be sensitive to that. As a general rule of thumb; never use pure white on anything as there is no such thing in real life.
                I have not tried it indoors yet. The projects I am experimenting with are quite narrow spaces... And what's Lumion is good at is its environment (plants, dynamic atmosphere/water etc.), quick terrain editing tools (sculpting and painting - although the ease of accuracy still nee some fine tuning IMO).
                • marvins_dadM
                  marvins_dad
                  @gaieus said:
                  [attachment=0:olwbszh9]<!-- ia0 -->FocalLength.jpg<!-- ia0 -->[/attachment:olwbszh9]
                  Wow - looks like you found more settings than I have. Maybe it is a difference from the demo to a full version. Promising that there are more adjustments. 👍
                  My Gallery
                  • GaieusG
                    Read the FAQ:
                    http://lumion3d.com/forum/index.php?topic=638.0
                    and here is the screenshot:
                    • marvins_dadM
                      marvins_dad
                      I found the setting, not sure in the demo it changes anything though.
                      My Gallery
                      • marvins_dadM
                        marvins_dad
                        A couple questions - think we are close to getting the software.
                        BTW - they have it on sale right now until May 8th for those that are on the fence.
                        If someone knows - I'd appreciate if they can help me out with these...otherwise I can search their forums.
                        1 - Can you adjust the sun per location/time/day similar to SketchUp? My initial investigation leads me to think not.
                        2 - Can you change the sun angle during your move around the model in an animation? Basically so you can light the northern side a little more so it isn't being rendered in shadow.
                        My Gallery
                        • GaieusG
                          Hi Antoine
                          1. No (at least I have not found anything).
                          2. Yes, you can animate the Sun
                          And thanks for the heads-up with the spring sale! Wrote an "urging post" in The Daily CatchUp:
                          Permalink: http://news.sketchucation.com/lumion3d-sale/ ‎Edit lumion3d-sale
                          • E
                            Ecuadorian
                            It's a scene effect. You can set the sun per clip.
                            -Miguel Lescano
                            • GaieusG
                              Yes, I should have been more informative. Here is the screenshot.
                              You can add these effects to the whole movie (if you select that when adding) however, not only per scene.
                              I guess if you have animated clouds for instance, that could/should go whole movie level while animated sun could only go for one scene where you want to show something related.
                              • E
                                Ecuadorian
                                Actually I have had problems with animated sun: If you set it in one clip, you need to reset it in the next clip. Otherwise, it will stay as it was at the end of the previous clip. I wish the clips without the effect just kept the setting you used while in build mode, but no... Even the build mode setting is lost once you use this effect in one clip, visit that clip and then return to build mode.
                                Too much words. I better post a video I finished on saturday for an architecture student. This is his final project:
                                [flash=853,505:29pcvn6a]http://www.youtube.com/v/XJf9z0V-4w8&fs=1[/flash:29pcvn6a]
                                Link to HD video:
                                http://youtu.be/XJf9z0V-4w8?hd=1
                                As Gaieus noted, you can set the animated clouds for the whole movie. I did just that.
                                Hey, this thread is pretty long. How about opening a part 2?
                                -Miguel Lescano
                                • GaieusG
                                  Yes, these settings override build mode (and the settings here are not the most intuitive either IMO - that is; you never now how accurately you are setting...).
                                  Now if in an initial clip I set the sun as somewhat rising (and maybe even the fog slowly disappearing/rising), I have no problem with the sun staying where it reached in the previous clip in the next clip - at least for a project I am working on ATM.
                                  • marvins_dadM
                                    marvins_dad
                                    Thanks.
                                    I did find a thread where they are wanting to emplement location and time lighting controls in the future....timeline is months, not years to add this feature.
                                    My Gallery
                                    • marvins_dadM
                                      marvins_dad
                                      Ecuadorian - thanks for the video as well.
                                      (didn't see this page when I posted).
                                      Thanks for the screenshot Gai - that helps when you can see where to find it. The learning curve for this program is odd because some things are really easy and intuitive, but others are hidden and take some time to find all the settings.
                                      I think we are pretty close to purchasing...we are currently using it on 3 projects to evaluate the software this week and so far have had a really good response from the powers that be.
                                      My Gallery
                                      • GaieusG
                                        Fine then. Some more purchases and I will claim a free copy.
                                        Joking aside; yes, together with the pro's and con's AND provided one can justify the costs, this is a good software. If some further features are implemented, it will be a fine product.
                                        You can also import SU terrain BTW although I have discovered some funny things (I will write some notes here).
                                        • boofredlayB
                                          boofredlay
                                          I really have to check into Lumion. I like this Bruce.
                                          • E
                                            Ecuadorian
                                            I was about to ask you about the grass edges...
                                            You have inspired me to try some desaturation on my future videos. 👍
                                            And yeah, I'm also using it for stills, as it's bloody fast to populate the scene with vegetation, vehicles, people, buildings, etc:
                                            -Miguel Lescano
                                            • 11
                                            • 7 / 11
