    Model.import() always true?
    6 Posts 4 Posters 500 Views 4 Watching
      Aerilius
      I'm trying to import collada files via the API. After importing, I want to apply some transformations to those files.
      According to the API, the Model.import method returns true/ false, but not the imported object.
      First Question: Is there a direct way to get the imported component instance? My current workaround is to get the last element of Model.entities:
      imported=@model.entities[@model.entities.length-1]
      ( @model.entities.last didn't work for me)
      This workaround makes only sense if the last element is actually the imported component instance and if the import was successful.
      The second problem is: When I import a corrupted collada file, the import should fail and return false, but for me it returns true. Is this a bug in the API, or does it depend how the import fails?
        @aerilius said:
        First Question:
        cache = model.entities.to_a model.import( ... ) imported_instance = ( model.entities.to_a - cache ).first
          Or...
          Do the import, then immediately
          defn=model.definitions.to_a[-1] instance=defn.instances[0]
          then use instance.transform!(tr)
          where 'tr' is the required transformation.
          Or it's it's easier for you to make a new transformation from scratch use
          instance.erase!
          followed by
          instance=model.active_entities.add_instance(defn, tr)
          where 'tr' is the required transformation...
            Aerilius
            • Dan RathbunD
              Dan Rathbun
              Do you have "Validate Collada File" checked in the Import Options dialog ??
              When the import "fails" does Sketchup raise any Ruby exception that can be trapped with a begin .. rescue .. end block?
              I'm not here much anymore.
                Aerilius
                For yery corrupted collada files, there appears just a messagebox "import failed [OK]". The ruby console does not display any exception but just true``.
                For some collada files, SketchUp says there is a chance that the import could fail and asks if I want to continue [yes]/[no].
                If I click yes, it succeeds to import it anyways, if I click no, the same messagebox appears "import failed [Ok]. In all cases, the console says true. I tried it with begin ... rescue ... end without success.
                model.zip
