    [Plugin] OBJexporter v3.0 20130131
    304 Posts 96 Posters 479.6k Views 96 Watching
      Alienizer
      I should know better not to ask you about the api, you're the expert, and I'm sure you've already taken the best possible route to make your exporter 😳
      About the door, you're right! I didn't catch that. Is it possible that your exporter reverse the order of the triangle's vertex because the Zaxis is down rather than up? say, p1,p2,p3 becomes p3,p2,p1 but the uv's are for p1,p2,p3, and that's why I get the face normal going in rather then out? My raytrace sees the face material just fine, but becuase it shoots a ray inward (bounce off the face normal) it hits no light, and shows real dark. When I manually reverse p3,p2,p1 to p1,p2,p3, then the bouce of the normal is outward and hits a light, and looks fine.
      One suggestion, is it possible to modify your exporter to save the textures all in png rather than mixed jpg, tga etc? no matter what the original was?
      Thanks tig for taking the time, I appreciate it.
      I'm from Mars and moved to Earth to alienize you. Unfortunately, I became humanized.
      • TIGT Online
        Clever idea about changing the Texture Files' format on export... πŸ˜„
        Here's v1.6 http://forums.sketchucation.com/viewtopic.php?p=294844#p294844
        Option to export all Texture files in PNG format added [after the OBJ save path has been given].
        'Yes' makes all the exported textures into PNG files: note that the processing might then take a second or two longer as these conversions will take a finite amount of time.
        'No' leaves them in their original format [as <v1.6 exports].
          Alienizer
          WOW that was FAST 😍 Thank you, thank you!
          Any thought about the Zaxis and the reverse p1,p2,p3?
          • TIGT Online
            That bit was easy - but that other bit is too obscure... because you should be able to have oddly place components and still return correct UVs πŸ˜•
              Alienizer
              hmmm, but when the vertex are CC instead of CCW, the ray/triangle intersect report the hit being on the back face rather then the front! Is there a way in the exporter to know which is p1, p2 and p3? and save them in the proper order? SKP must do it right for it to be able to display the back face in blue when viewed in mono.
                Alienizer
                tig, I found the problem. If you can do a test, (use a model with all faces facing the right way), run your raytrace and for every pixels on the screen, if it hits the back face (turn off back face culling) display that pixel in red, otherwise use some other color, material color perhaps. You will see that using skp exporter, they are fine, using yours, some are not. Now, a quick fix I did was to get the normal <-- cross(edge1,edge2) and then, calculate the normal for p1. Do a dot(Normal, NormalAtP1) and if the result is negative, recreate the face as p3,p2,p1 as oppose to p1,p2,p3, and swap 1 and 3 for the UVs as well. Then your raytrace will show the face correctly. I hope I make sense? Pehars that's how other render do it to correct such problem?
                  Alienizer
                  Sorry to be a pest TIG, but have you had a chance to read me posts? πŸ˜•
                  • TIGT Online
                    I have read it, but I am busy on several other things right now. 😞
                    Why don't you poke around in my code [the #500s lines] and see if you can fix it - then you can have joint (c) credit πŸ˜‰
                      Alienizer
                      🀣 If I was as smart as you perhaps I would!
                      • TIGT Online
                        OK I try to make time to look at it next week... πŸ˜’
                          Alienizer
                          THANK YOU TIG 😍
                            Kralizek
                            Works great for for me, thanks a lot TIG!
                            • I Offline
                              Immer
                              Thanks TIG, this is an incredibly useful plugin, the most reliable obj-exporter I've tried.
                              I have one feature request though - could you add an option to export faces with distorted textures using the original texture and just save the "distorted" UV coordinates in the .obj file? As it is now doing something as simple as exporting a spherically-mapped globe can generate hundreds of distorted texture files and a correspondingly complicated .obj file, not exactly ideal for loading into another program.
                              I've modified version 1.1 to normalize the UVQ coordinates before export and it seems to work fine, it would be nice to have access to the more recent features though so I'm sending you the change in hopes that you'll incorporate it into the next version
                              the relevant change was changing the line
                              f_uvs=(1..mesh.count_points).map{|i|mesh.uv_at(i,1)}####1=front
                              to
                              f_uvs=(1..mesh.count_points).map{|i|flattenUVQ(mesh.uv_at(i,1))}####1=front
                              where flattenUVQ is defined as
                              def flattenUVQ(uvq)
                              return Geom::Point3d.new((uvq.x/uvq.z), (uvq.y/uvq.z), 1.0)
                              Thanks a bunch!
                              • TIGT Online
                                Sketchup's own OBJexporter also makes individual 'distorted' images when a texture has been 'distorted' by UV mapping - simple rotations or scaling shouldn't produce multiple images.
                                I added the feature to mimic it because otherwise you don't get the correct 'distortion' - I have previously tried the very method you outline in your code snippet but it never gave satisfactory results. The flattenUVQ method is actually in the code 'unused' [until the more recent updates that make distorted images...].
                                A distorted texture has 4 uvs but a triangulated mesh makes just 3 per facet ??
                                • I Offline
                                  Immer
                                  Yeah, I had noticed and used the flattenUVQ method provided - I figured it was something you had brought in from someone else's code but didn't use. I didn't see it in the latest version so I thought I'd include it in case you didn't have an archive of older versions.
                                  Don't get me wrong, it's awesome that you've managed to export non-linearly distorted faces accurately, however for many situations a linear approximation is preferable, especially if lots of additional textures or a complicated group layout present problems - like if you intend to use the exported object in a game engine, or want to fine-tune the UV mapping in another program. It may even be what was actually intended: for example UVTools' spherical map apparently uses distorted textures when linear interpolation is the correct method. In fact I'm not sure it's even possible to specify a lineraly distorted face in Sketchup. I've yet to find a way to, for example, squeeze a rectangular texture onto a trapezoid so the edges and center-points line up perfectly, and that's UV mapping 101.
                                  All I'm suggesting is a checkbox on the option screen to choose between the accurate method and the "clean" one, it should just be a matter of changing the logic to
                                  if "face is distorted"     *AND* "use accurate method"
                                     create accurate texture
                                     export face using accurate texture
                                  else
                                     output face with normalized UVs # normalizing should have no effect on non-distorted faces
                                    Alienizer
                                    *** BUG REPORT ***
                                    Using this model from the 3D warehouse...
                                    Error 404 (Not Found)!!1
                                    (sketchup.google.com)
                                    it export just fine, except the last line in the mtl file is "newmtl fueg" and nothing else after. The file is lock for writing, and after closing Sketchup, the reminder is written to the mtl file.
                                    • TIGT Online
                                      It is a 9Mb SKP and makes an OBJ file with 41 million lines of code so taking 5min+ to complete isn't surprising!
                                      It worked fine for me...
                                      The only 'error' was it didn't write '#EOF' into the end of the MTL file but that's just for me so I know it's done all materials [but it had?]
                                        Alienizer
                                        The only 'error' was it di dn't write '#EOF' into the end of the MTL file but that's just for me so I know it's done all materials [but it had?]
                                        I let mine site all night for 9 hours and the last line of the mtl file still was "newmtl fueg", and the exporter stutus said it was done in 66 secs. So I closed Sketchup and that commited the buffer to the mtl file and it was then complete!
                                        • TIGT Online
                                          Strange - might be a memory issue ?
                                          Also the missing [but not fatal] '#EOF' in the MTL was puzzling as there were no error messages ???
                                          If I get to the bottom of it I'll let you know.
                                            Alienizer
                                            This is the second model it did this. The first one, I thought it was Sketchup because when I closed it, then file became complete. I don't remember which one it was! I know the file doesn't get closed because it has a write lock on it until you close Sketchup, even though the exporter is done without any errors!
                                            I have a suggestion 😳 Can you incorporate the fix reverse back face material in the exporter? Perhaps add a checkbox for that opton? Maybe it's faster to do it as it goes then using both plugins? I'm not the expert so I don't know.
                                            Thanks TIG, your exporter is by far the best the way it is.
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 14 / 16
