    [Plugin] OBJexporter v3.0 20130131
    304 Posts 96 Posters 592.2k Views 96 Watching
      I found that my OBJexporter did make a correct OBJ version - which imported OK into other packages. It took ages to finish and the OBJ file was 22Mb! The Pro OBJ exporter is quicker because it's compiled etc... BUT mine is 'free' πŸ˜‰
      There is a problem with my old clunky OBJimporter - it will import some of the faces flipped - it's an issue with smoothed normals.***
      I suggest you try this quite new and free 'compiled' OBJimporter - it is much faster, and after some initial tweaking this version is now stable and it gave me a perfect re-import back into a SKP of Allo'... see here http://forums.sketchucation.com/viewtopic.php?p=316470#p316470 - read the thread to see how it's evolved... It could probably do with some better reporting in the Status-Bar, but otherwise I like it...
      ***As we now have this free 'compiled' OBJ 'FluidImporter', I probably won't bother doing any more work on my clunky version...
        Alienizer
        I know you are right, and I do make my models that way, but, in the 3D warehouse, you are not going to find many that follows that rule! They all use an electron thin wall, and don't even know about front/back faces! Let alone paper thin glass (no thickness)!! That's why I try to get some 3ds files, then use AccuTrans3D to convert it to KMZ so that I can load it in SKP.
        However, you're obj importer is by far the best of all! Thank you, and it's free! 😍
        Your renderer looks fantastic too. Great job, and thanks for taking the time to answer my post.
        I'm from Mars and moved to Earth to alienize you. Unfortunately, I became humanized.
          aapur
          i cannot get it into sketchup.
          OS: Win 7
          SU: 8
          what should i do. (be detailed please)
            Put the .rb file into your ../Plugins folder and restart Sketchup.
            Use Menu > File > OBJexporter
            Otherwise please be more specific with your problem's description...
              Alienizer
              TIG, I have another one for you. I created a simple Cornell box with a sphere in the middle. Sketchup OBj exporter rendered perfectly, yours seems to have not soften it! See screen shot...
                Alienizer
                I have another one for you...
                Error 404 (Not Found)!!1
                (sketchup.google.com)
                This guy did this by the book. It renders fine when exported using SKP obj exporter, but not when using yours!
                  Are you using the latest version of my exporter [v1.5] ?
                  This was updated to correct some smooth-normal issues, and it seems to work on exports tested by others.
                  Please download it from the first post and retry your sphere/box...
                  [It is also very similar to my Octane exporter which renders smoothed faces as expected too]
                  When re-importing it into a SKP you need to use this http://forums.sketchucation.com/viewtopic.php?p=318928#p318928 new tool - my old OBJimporter is now surpassed [and it never imported 'smoothness' anyway]...
                    Here's a quick test.
                    The SKP has two spheres one smoothed [dotted edges] and the other faceted.
                    It is exported as an OBJ and then used in a quick Octane render, which shows the smoothed sphere as a rounded pearl and the faceted one exactly as they are the SKP ?
                    Are you sure you have the latest version of OBJexporter ?TestSKP.PNGTestRender.png
                      I also tested the 'Mullaghmore' house.
                      The roof carpentry [first scene] exported to OBJ fine and here's a render in Octane MullaghmoreRoof.PNG compared to the original it seems perfect ?
                      When I exported the whole house and its site [house] to OBJ it took a while and it then loaded into Octane but after all of the materials loaded it crashed it [it does have 90 textures and then other materials, although the OBJ itself is relatively modest]. When I re-imported it into a SKP after some considerable wait I got it to import. Clearly all smoothing was lost [currently all OBJ importers to SKP ignore smoothed normals]. I could have then quickly re-smoothed and got back to something like the original. There was considerable redundancy with interior structure, furniture etc that's 'on' in the exported scene but never visible in a 'site' view - luckily the SKP is very well layered, so switching those unneeded things' layers 'off' let it be exported quickly to OBJ and then it rendered nicely in Octane too... The 'tiling' is a function of the original texture mapping rather than the export or render - just compare it with the original SKP view MullaghmoreHouseSite.png I'm not getting any real issues here - only that I can't expect a renderer to cope with a zillion unneeded hidden things in the model line floor joists and WCs as it needs to calculate all of them unnecessarily... πŸ˜•
                        Alienizer
                        Thanks TIG, but I do have the latest. I think I found the problem. It is that in some instances, your exporter export some faces as back face, that is, in the obj file, f 1/1/1 2/2/2 3/3/3 is f 3/3/3 2/2/2 1/1/1. Here is how I found out. Check this model...
                        You see the first brown door on the right? Erase everything except that door, then remove the frame and the back door (it's a bifold). Now you are left only with the 3d rect (6 faces, not paper thin). Now, the last two line foe example, is the front...
                        f 21/21/21 22/22/22 23/23/23
                        f 22/22/22 21/21/21 24/24/24
                        and it is reverse. a ray bouncing of the normal goes inward, not outward. Now, it I modify it like this...
                        f 23/23/23 22/22/22 21/21/21
                        f 24/24/24 21/21/21 22/22/22
                        it now renders fine and the face if oriented properly.
                        Most render such as yours may not be affected by this, but mine is! The fact remain that the face is not oriented properly.
                        Or is it just me that's going nuts?
                          It isn't modeled perfectly - there are a few reversed or missing faces [showing as blue or 'nothing' here].BrukMono.PNG
                          My Twilight render is too [although it does auto-correct the rubbish modeling [reversed face on the end of the stone-wall and a triangle pane in particular].BrukTW.jpg
                          This crap render from AC3D also mimics Octane's output with the expected problemsBrukAC3D.PNG
                          Finally here's it exported to OBJ, re-imported into an empty SKP and a Twilight renderBrukOBJ=TW.jpg
                          They all seem to cope quite well with the original SKP - TW even forgives the reversed faces πŸ˜’
                          What's your renderer that seems to be causing this weirdness ? πŸ˜•
                            Alienizer
                            I was only using a simple raytrace to verify the orientation of the faces. When I click on a face, it shows me the reflected vector (also shows the normals etc), and it shows it correctly with the skp export, but with yours, it shows the reflected vector to go inwards. Not for the whole model, only for the 2 brown doors to the right. When I reverse the face (f #/#/#...) as I explained, then the reflected verctor is proper. The same thing happens with the body of the allo dinosaur, but not the head.
                            I know the renders takes care of that, but imho I think it's better to have a flawless obj than one the render has to fix, so I present you my findings. It seems that for those 2 doors, the triangles are CWW instead of CC (or CC instead of CCW). This makes a big difference when you do a ray/troiangle test and test for face culling or want to know if it hit the back face or not.
                              Thanks for the analysis...
                              The tool's 'triangulation' method is built in to the Ruby API's face / mesh methods.
                              There's little control over it, other than telling it what extent of detail the mesh will include - like back face UVs...
                              ...except that there are some arcane face / edge methods 'reversed_in' etc that are used to orient faces that share an edge but face opposite directions [i.e. one is reversed].
                              At the moment I can't see how... BUT perhaps you could reverse an edge's vertices on a particular face that is 'wrong' before making the triangulated mesh... I wonder if the problem 'door' face has some small facets - fluking it? I'll look more closely...
                              As it is, I see this glitch as a shortcoming of the API mesh method that is making occasional glitches in the mesh that the OBJ is then using in its exporting... πŸ˜•
                                Alienizer
                                I see what you mean. I did a test on that door, and I can't push/pull inward, skp says it's offset is at zero! If I remove the back face of the door and keep 5 sides, then it export find in yours. I don't know why it will not push/pull, I see no triangulation in skp that would show this 3D rectangle door not being 100% rectangular. If one face wasn't the same size, other faces would be triangulated accordingly in skp, and the hidden geom would show that, but it doesn't!!
                                I was wondering, I know little about skp api but I've look at all the api and I was wondering if there was a better way to get the data. For example, I see that you do not use uvhelper. Maybe there is a way to get the normals and tex uv using an api rather than doing it all over? skp diplays it right, so it must be stored somewhere no?
                                  It doesn't need to have a 'get_uv_helper' method because it gets the UVs directly from the face.mesh using
                                  f_uvs=(1..mesh.count_points).map{|i|mesh.uv_at(i,1)}###1=front
                                  which avoids lots of complex 'getting' otherwise...
                                  Clearly there's something adrift with those bi-folding doors...
                                  If you edit one and select-all you get 18 entities - the correct number of faces+edges for a cuboid so there's no tiny bits of stray geometry to mess with us...
                                  If you edit one of them you you'll find that the door 'slab' is not actually a cuboid - it's slightly skewed - faces don't meet quite at right angles, so PushPulling any vertical face 'inwards' is disallowed. To see this just try making a simple skewed cube and try to PushPull a face 'in' - you can't! because it clashes with connected internal geometry; however, it will PushPull 'out' as there's no clash and it makes two new edges and faces, because the extended side faces aren't coplanar with the original they spring from. This in itself shouldn't mess with the faces' mesh/UV mapping - it's weird...
                                  Also if you edit the door 'slab' so you can see the axes [switch them 'on' and v8 displays the actual component-axes during the edit, rather than the model-axes as in v7] you find it has been made [or at least inserted] 'upside-down' - the Z/blue axes is 'down' not and not 'up' as it ought to be...
                                  This might also be confusing the issue, but again it shouldn't matter.
                                  None of these issues ought to matter but it seems that they do πŸ˜•Capture.PNG
                                    Alienizer
                                    I should know better not to ask you about the api, you're the expert, and I'm sure you've already taken the best possible route to make your exporter 😳
                                    About the door, you're right! I didn't catch that. Is it possible that your exporter reverse the order of the triangle's vertex because the Zaxis is down rather than up? say, p1,p2,p3 becomes p3,p2,p1 but the uv's are for p1,p2,p3, and that's why I get the face normal going in rather then out? My raytrace sees the face material just fine, but becuase it shoots a ray inward (bounce off the face normal) it hits no light, and shows real dark. When I manually reverse p3,p2,p1 to p1,p2,p3, then the bouce of the normal is outward and hits a light, and looks fine.
                                    One suggestion, is it possible to modify your exporter to save the textures all in png rather than mixed jpg, tga etc? no matter what the original was?
                                    Thanks tig for taking the time, I appreciate it.
                                      Clever idea about changing the Texture Files' format on export... πŸ˜„
                                      Here's v1.6 http://forums.sketchucation.com/viewtopic.php?p=294844#p294844
                                      Option to export all Texture files in PNG format added [after the OBJ save path has been given].
                                      'Yes' makes all the exported textures into PNG files: note that the processing might then take a second or two longer as these conversions will take a finite amount of time.
                                      'No' leaves them in their original format [as <v1.6 exports].
                                        Alienizer
                                        WOW that was FAST 😍 Thank you, thank you!
                                        Any thought about the Zaxis and the reverse p1,p2,p3?
                                          That bit was easy - but that other bit is too obscure... because you should be able to have oddly place components and still return correct UVs πŸ˜•
                                            Alienizer
                                            hmmm, but when the vertex are CC instead of CCW, the ray/triangle intersect report the hit being on the back face rather then the front! Is there a way in the exporter to know which is p1, p2 and p3? and save them in the proper order? SKP must do it right for it to be able to display the back face in blue when viewed in mono.
                                            • 15
                                            • 16
                                            • 3 / 16
