    Assign materials to both sides?
    9 Posts 6 Posters 11.8k Views 6 Watching
      mirale999
      Is thare a plugin that can let me assign a material in one go to both sides?
      One click,two sides of the face. πŸ˜„ I think this function is good, when to build models for exporting into 3dsmax~
      I've found Builder Boy's plugin
      http://forums.sketchucation.com/viewtopic.php?f=180&t=32839 Is there a plugin: one click two sides? πŸ˜’
      paranoia is a higher form of awareness...
        This "one-liner" copy/pasted into the Ruby Console makes all faces in the current selection have the same material front and back... BUT don't use it as an excuse for sloppy modeling
        Sketchup.active_model.selection.each{|e|next if e.class!=Sketchup;;Face;e.back_material=e.material if e.material;e.material=e.back_material if not e.material}
        If a face has a front-material then it's duplicated on its back, if it doesn't have a front-material the back-material [if any] is duplicated on its front.
        It doesn't work on 'nested faces' unless you edit the group/instance and then 'select all', and then run the snippet...
          mirale999
          Thanks for your advice~ I'm lazy πŸ˜„ I was drawing a concept model, so I thought that sort of plugin can make something easy...
          • Guillo_OrtizG Offline
            Guillo_Ortiz
            Hi, I know this is and old post, but could this be done keeping the orientation?
              Please explain 'orientation'.
              Do you mean flipping a material's texture so that the image aligns front and back ?
              I think that there's separate thread about this...
              I'll search...
                After thinking a bit more...
                https://sketchucation.com/pluginstore?pln=FixReversedFaceMaterials
                [an oldie by me]
                Has several tools.
                It's primary aim is to reverse faces that have a texture on their back, and then move the texture onto the front - needed by most renderers.
                But it does have tools to replicate a material on front and back faces...
                Try it...
                • cottyC Offline
                  cotty
                  ThruPaint (part of FredoTools) can paint both sides with one click too...
                  my SketchUp gallery
                    jmartlncln
                    This is very useful! Is there a way to make it run through nested groups and components too? Also I need to look up how to add this, but a single click undo?
                      j_jones
                      [an oldie by me]
                      Has several tools.
                      Try it...
                      This is awesome thanks so much! πŸŽ‰ πŸ˜„ πŸ˜„ 😎
