    Export sketchup to 3D pdf file?
    12 Posts 9 Posters 52.6k Views 9 Watching
    • T
      tallbridgeguy
      Hi, Microstation (cadd program) can export 3D pdf files that anyone with Adobe reader can use. (The topic has probably come up before but I can't find it.)
      I was wondering if there was a good exporter (free would be nice) for Sketchup to a 3D pdf file. I found this one but I would like a cheaper option.....
      http://www.simlab-soft.com/3d-plugins/3D-PDF-from-sketchup-main.aspx
      Thanks for the help!
      Stuart
      Nielsen
      http://www.tallbridgeguy.com/
      • mitcorbM
        mitcorb
        I Googled "sketchup to 3d pdf exporter.
        The first in the list was a Google Sketchup page on plugins. I did not dig any deeper. Here is the link: http://sketchup.google.com/intl/en/download/plugins.html
        Edit: scroll down a bit and you will see mention of what you are looking for.
        • F
          feryum
          PDF Creator is free. http://sourceforge.net/projects/pdfcreator/
          • T
            tallbridgeguy
            Thanks, I checked out the Google list. One product by Hypercosm looks interesting.
            Has anyone used the free plugin? It seems I need Sketchup pro to use it.
            http://www.hypercosm.com/
            Update: If you have quicktime, then you can view a 3D panorama.
            Here is one by a friend of mine.
            http://www.iowadot.gov/bridge/IowaFalls_highQ.mov
            is there any windows equal?
            thanks again!
            Stuart
            Updated here is a 3D pdf....use your left mouse button and the other tools in the toolbar.
            tbg.pdf
            Nielsen
            • ToboboT
              Tobobo
              Hi this is one i found in my recent quest
              Toby
              Philippians 4:13
              • B
                BrooksL
                feryum,
                PDF Creator does not produce 3D PDF files.
                ...it also can't do many things as well as Adobe Acrobat... enabling Reader commenting with Acrobat Pro is especially useful for collaboration...
                • ToboboT
                  Tobobo
                  @brooksl said:
                  Has anyone got experience with the SimLab or other 3D PDF conversion/exporting?
                  I have Simlab, it is not the best, you have to put a lot of post work in the simlab software to make it look good and there is a file size limit, which they don't tell you about.
                  But I would try it out.
                  Toby
                  Philippians 4:13
                  • B
                    BrooksL
                    I thought 3D PDF from SketchUp would be a great way to simplify drawing output and give contract manufacturers a way to view commented, 3D part designs.
                    However, we've run into a number of significant 'gothcha' problems with this - at least with the SimLab 2.4 pluggin...
                    The SimLab 2.4 pluggin exports only 2D plane 3D geometry; it does NOT export points, lines, guides, text, nor dimension entities - which makes it practically impossible to create a fully commented/annotated 3D model in PDF.
                    There are also some buggy problems using Acrobat Reader and I'm not sure whether they are on the SimLab side or the Adobe Acrobat Reader side:
                    1. Regardless of what units I draw the model in and what units I set Acrobat Reader to use, the Reader measurements always display in meters. [yes, I prefer SI, but some mfgs only build in inches]
                      1a) Most of our machines have Reader 9.5.1 because Reader X (10) implemented many significant UI changes that really aren't so slick (as short-sighted as MicroSoft suddenly moving to the ribbon interface). Regardless, Reader X does have an additional option for units scale and I can set 0.0254 units = 1 in and then Reader X will show measurements in inches, but this requires manual intervention each time and is not available in earlier (and still considered current) versions of Adobe Reader.
                    2. Acrobat Reader also seems to be buggy between versions with the measure enable;
                      2a) both Reader 9.5 and Reader X react a little differently when measure is enabled by the SimLab export configuration vs when measure/analysis is enabled via Acrobat Pro and then the file opened in Reader. When enabled in Acrobat Pro, measure options show up on the Reader toolbar and in the drop-down menu. ...it's like measure is not 'fully' enabled when done in the SimLab export.
                      2b) in reader 9.5.1, the measure mode cursor is a circle with a line through it - the "Unavailable" mouse cursor, and it often obscures the inferred measuring point. This problem was not seen in Reader X. Is this a known issue?
                    Has anyone else encountered similar problems? Are these problems surmountable? Do other 3D PDF exporters solve these issues?
                    -- BrooksL
                      ashraf
                      Tobobo,
                      First we are thankful for using SimLab 3D PDF, and we are really believe it is the best and it can handle more complex model.
                      We still are aiming to make it better, please send any files that did not work to support@simlab-soft.com and we will check it for you.
                      Thanks,
                      Ashraf
                      • V
                        Vigy
                        If you got one of the latest versions Photoshop then you can export your SU model to Google Earth File (.kHz) and then import it to Photoshop and follow the instructions below.
                        1. Right click on the 3D layer thumbnail
                        2. Select Export 3D layer
                        3. Name the file and select U3D from the Format dropdown menu
                        4. Click the Save button
                        5. The 3D Export Options dialogue box will open.
                        6. Make sure that JPEG is selected from the Texture Format dropdown
                        7. Use ECMA1 for the U3D Options
                        The steps above exported the Photoshop layer to a U3D file. The U3D file can now be published to PDF.
                        1. Open Adobe Acrobat X
                        2. Select File>Created PDF>From File
                        3. Browse to the U3D file you saved earlier
                        4. An Insert 3D dialogue box will open. Select OK (You may want to check out the “Advanced” options by clicking on the Show Advanced Options check box. There are some neat options to play around with).
                        5. Click on your 3D object to interact with it. Also notice the 3D tool bar that appears.
                        Cool! Now anybody with Acrobat Reader can view your 3D content!
                        See link with images http://blogs.adobe.com/edtechatadobe/2011/09/publish-photoshop-3d-layers-to-pdf.html
                          dmatho
                          ... and, if you want a more enhanced performance from the 3D-PDF, I'd suggest looking at Quadrispace.
                          Cheers,
                          . Diego .
                          • G
                            gbing
                            Hi to all. A very good companion for Sketchup is Designspark Mechanical also with 3D pdf output.
                            It is based on Spaceclaim and it is free!
                            Giovanni
