    [Plugin] importDXFtext
    165 Posts 18 Posters 101.0k Views 18 Watching
      alexdobras
      i tried to import a dxf and SU is crashing. It is not a big file.
      you can check it out: http://dl.transfer.ro/transfer_ro-23mar-7b7d941ec2f2cc8f.zip (it expires in 10 days)
        alexdobras
        yeah, for some reason the file cannot import into Acad. I had a dwg, which i saved into dxf in order to work with the file in SU andBlender. Now, Blender 2.49 imports the file perfectly, i mean flawlessly with text and everything like i see it on CAD software i use: DraftSight. When i open the file in SU, the same file as in Blender, the model comes with a lot of deformations and with the text missing- I mean through SU 8 PRO native dwg/dxf importerthat comes with the pro version. No matter is dwg or dxf the file will import bad.
        So i am using this plugin in http://forums.sketchucation.com/viewtopic.php?f=323&t=31186&start=75, which actually doesn't deform the model, but takes more time to import the file. The only problem is it doesn't import the text, and the model need to have everything exploded, so no blocks.
        I hope you did understand about what i am talking about
        • TIGT Online
          Sketchup doesn't import dwf/dxf text that's why I wrote the script...
          It is a good idea to reduce the dxf down to just the text items- it speeds the import and aaoids errors. It's easy to make a copy of the file in your CAD app and then filter to leave just the dtext/mtext etc, then purge and audit the dwg, then finally save as a ~r2004 DXF...
            alexdobras
            i have done what you said, and still SU crashes right before imports the text 😐
            here is the 2004 ASCII drawing.DXF , only with text (just text)
            btw, i have intel i5 750, 2gb ddram3, video Geforce GTS250, win7 64 bit, and SU8
            • TIGT Online
              You have NOT trimmed down the file to include just 'Text' !!
              You have simply switched other layers 'off' - these are still there and so Sketchup WILL try to import them !!!
              Here's a properly reduced version of the DXF...TESTTEXT2004.dxf And the resultant SKP.TESTTEXT2004.skp
                alexdobras
                i tryed what you have sent me
                still, it crashes
                now see for yourself:click on Télécharger ce fichier
                http://dl.free.fr/getfile.pl?file=/r36AYYVu
                • TIGT Online
                  BUT you tried to import it in 'mm'... I did it in 'm' - as I explained before.......
                  I worked fine for me...
                  WHAT are the units you are working in ... 😲
                    alexdobras
                    sorry TIG, i knew i forgot to change something.
                    when putting to m , it works,
                    but i don't understand why is crashing at mm, though.
                    and a second one, why the file needs to be saved as 2004 ascii dxf, could;nt you make it up-to-date to ascii 2010 drawing?
                    thanks anyways for this wonderful plugin!
                    • TIGT Online
                      Thanks anyways for this wonderful plugin!
                      Presumably at 'mm' the size of some objects is just too small of Sketchup/OpenGL <~0.5mm - You OUGHT to import all of your DXFs etc in at their correct unit settings - I assumed 'm' as it simply 'worked' and you [still] gave me no clue - CAD files have no real UNITS - the recipient must be told that vital info so the units can be 'set' on import !??
                      Please remember that this is a ***ing 'free tool' 😒 I wrote it to read DXF format files as they were made at that time - so your saving it in a more recent DXF format gives YOU absolutely NO benefits and me only a headache...
                      Reading the code in a DXF file is complex enough to 'parse' - even in its 'text' format - I suggest you open a DXF file in Notepad to see what I mean... A binary format like DWG is a zillion times more involved [open one in Notepad to see the gobbledygook]... So... IF YOU want to write your own DXF importer and share it freely with the rest of us, then please feel free 😢
                      Gift horse...mouth... etc 😠
                        alexdobras
                        "you [still] gave me no clue" - i don't exactly understand what are you saying.
                        Perhaps my English is not as good as should be.
                          alexdobras
                          good news, mate:
                          i created another dxf with text and saved as Ascii 2010 drawing dxf
                          and guess what ? it has imported almost perfectly, if the cyan letters weren't reshaped:
                          here's the file:text2010.dxf
                          here's the preview in CAD:1.PNG
                          here's the peview in SU:2.PNG
                          seems when importing into SU, it is not recognized the shape of the cyan text 😐
                          the same exact thing happens with a 2004 dxf ,with the cyan text
                          • TIGT Online
                            Alex...
                            When you give a DXF [or DWG] to someone you need to tell them what units it was made with.
                            Sketchup always uses inches as its base units - the displayed units are simply to help users who work in say 'cm'...
                            CAD programs typically just work in an arbitrary 'unit'.
                            When you are working in the file you assume that say 1 unit = 1 cm.
                            When you give that CAD file to someone else unless you tell them the assumed units that were used they have no way of knowing what 1 unit of the CAD file is in the SKP... SO if a line is i unit long how do I know you meant it to be 1m or 1mm, or whatever...
                            On the issue of the 'incorrect font'.
                            The DXF importer uses a list of typical fonts found on most PCs and MACs.
                            A text-font that is not available as a 'tt' font on your system reverts to 'Arial' as here with the 'cyan' text.
                            Your DXF only includes ONE STYLE
                            STYLE
                            5
                            11
                            330
                            3
                            100
                            AcDbSymbolTableRecord
                            100
                            AcDbTextStyleTableRecord
                            Standard
                            70
                            0.0
                            41
                            1.0
                            50
                            0.0
                            71
                            2.5
                            3
                            txt
                            4
                            ENDTAB
                            which is named 'Standard' [#2] and uses a font-file called 'txt' [#3] - and there is no 'named' tt-font [no #1000]. It's set at 0.0 high [#40] so the user can specify the text height. It's width-factor is 1.0 [#41]. It's obliqueness is 0.0 [#50]. It is not flipped [#71]. It has no set color [no #62]...
                            The cyan colored TEXT that says 'traa aaskjaksdfasdfa' is set in the DXF as follows...
                            No STYLE set [no #7] - reverts to the default style of 'Standard'...
                            Layer = '0' [#8]
                            Thickness = 50 [#39] WHY ???
                            Oblique = 30 [#51] WHY ???
                            Color = '4' [#62]
                            Flipped = 6 [#71] WHY ???
                            Rotated = 10 [#50] WHY ???
                            If any TEXT has it's values set weirdly like this it will revert to some defaults to at least import something !
                            Please use this tool as it is intended... Sketchup importers will only bring in raw geometry and ignore text etc. I made this tool to bring in text from a DXF... BUT there are limits - it did bring in all of the text even if some of it had been cruelly 'mangled' by you before hand 😒
                              alexdobras
                              thanks TIG for the complete description.
                              i just wanted to dream about how cool it would have been if the text was completely imported with all the characteristics. but never the less,at least everything is imported and even has color.
                              so, thanks a tonne for making this possible, TIG, you rock!
                              • W Offline
                                Wakanai77
                                This worked for me and saved alot of time!
                                thank you very much
                                • Miner_JeffM Offline
                                  Miner_Jeff
                                  Hello,
                                  I realize this is a an old thread. Anyone else having issues trying to use this with Sketchup make 2015?
                                  I get a crash shortly after invoking the script in the console, goes straight to bugsplat reporting.
                                  Thanks Tig for all your selflessness in sharing of your ruby programming skills.
                                  Cheers,
                                  Miner_jeff
                                  • TIGT Online
                                    Can you shared the text's DXF with me ?
                                    You can PM it to me if needed.
                                    • TIGT Online
                                      Having looked at the DXF you PM'd to me...
                                      I confirm that it contains NO TEXT/MTEXT entities, unlike a normal CAD-originated DXF might.
                                      There seems to very little I might call 'text' ["...FILM..."], and there are many empty objects that look like they might have been intended to be text...
                                      I suspect that everything is in CAD 'lines' or 'polylines', and that no CAD 'text' is included in it - perhaps because of the preprocessing app you've used ?
                                        Miner_Jeff
                                        Hi Tig,
                                        You are correct. I will have to investigate Inkscape a little further as to why no text objects are being saved with the saveas DXF export.
                                        Do you get a bug splat if you attempt to use importDXFtext and there are no text entities in the DXF?
                                        Cheers,
                                        Miner_jeff
                                        • TIGT Online
                                          I haven't tried it.
                                          Away from my PC now...
                                          BUT it should just find 'nil' text-entities to process...
                                          Since it's a flaky DXF I suggest you find how to make a 'good' one containing the 'text' 😕
                                          • TommyKT Offline
                                            TommyK
                                            Hi TIG.
                                            I tried to get this plugin working on SU 2016 and wasn't successful. I go the following error in the console...
                                            I was also importing DWG - is this an issue?
                                            Error: #<ArgumentError: invalid byte sequence in UTF-8> /Users/tk/Library/Application Support/SketchUp 2016/SketchUp/Plugins/importDXFtext.rb:123:instrip!'
                                            /Users/tk/Library/Application Support/SketchUp 2016/SketchUp/Plugins/importDXFtext.rb:123:in block in get_styles' /Users/tk/Library/Application Support/SketchUp 2016/SketchUp/Plugins/importDXFtext.rb:121:in upto'
                                            /Users/tk/Library/Application Support/SketchUp 2016/SketchUp/Plugins/importDXFtext.rb:121:in get_styles' /Users/tk/Library/Application Support/SketchUp 2016/SketchUp/Plugins/importDXFtext.rb:1721:in run_tool'
                                            /Users/tk/Library/Application Support/SketchUp 2016/SketchUp/Plugins/importDXFtext.rb:1729:in importDXFtext' /Users/tk/Library/Application Support/SketchUp 2016/SketchUp/Plugins/importDXFtext.rb:1737:in block in <top (required)>'
                                            SketchUp:1:in call'
                                            • 2 / 9
