    Skydome No Shadow
    8 Posts 4 Posters 2.2k Views 4 Watching
      Booman
      I created my own skydome to use in conceptual presentations landscaping.
      Its simply a massive half-dome with a sky projected across it.
      The main problem I have, is that when I turn shadows on or use sun settings, it casts a shadow across my whole landscape.
      I have done some research and the only suggestions were to make it transparent, but if I do that, you won't see the pretty sky.
      I have also tried telling the group/component to NOT cast shadows, but still have the same problem because it blocks the sunlight.
      So does anyone know of a plugin or setting that will allow a skydome but somehow it ignores the sun or does not cast shadows?
      Brian McCracken
      In The Red Website Design
        Make the outside faces of the dome transparent by painting a transparent material on it. The inside surface will have your sky painted on it.
        Here's a quick example with a model I am working on at the moment. I don't have a sky so I used stone for the inside.
        http://farm6.static.flickr.com/5258/5553871531_81a465b94a.jpg
          Booman
          ooh, interesting idea. So create a transparent PNG, make it a material and apply it to the outside of the dome?
          Then leave my sky material on the inside?
          I will definitely try that!
          thank you
          Brian McCracken
          • BoxB Offline
            You don't need to make a transparent PNG, just paint it with anything and edit that materials transparency.
              Booman
              oh, so use the slider on the material and make it 0%
              got it
              Brian McCracken
                For my example I just applied the gray translucent material. I left it so you could that there was something there but you could certainly slide it all the way to transparent.
                • boofredlayB Offline
                  boofredlay
                  Or you can select the sky dome, go to Entity Info and uncheck "Cast Shadows".
                    Booman
                    I tried that too, but it still seemed to block the sun and NOT cast a shadow.
                    I'll try the transparent material idea when I get to work today.
                    Brian McCracken
