    [Plugin] Voodoo Camera Tracker Importer - March 9, 2011
    24 Posts 11 Posters 33.5k Views 11 Watching
      Sir
      Syntheyes is what we're currently experimenting with for our uni project. been used in films and things, its amazing...
      dont think it integrates with SKP tho, we've been using c4D with it.
      expensive too, but there are free demos
      This is the interesting bit
      Developing New Exporters
      currently exporters 'only' available for these
      Included exporters for MAXscript (3ds max, 3D Studio VIZ); Maya scene file; Softimage dotXSI; Lightwave; Maxon C4D (via .LWS); Modo; Bentley Microstation; Houdini; Blender; Carrara; Electric Image; Hash Animation: Master; Poser, Realsoft 3D; trueSpace; Vue 5 & 6 Infinite; Discreet Flame/Inferno/Smoke2008(3-D); Combustion(3-D); Combustion/Flame/Inferno 2-D ASCII tracker file; After Effects(2- & 3-D); Shake (2- & 3-D); Apple Motion(2- & 3-D); Nuke; FLAIR motion control cameras; Fusion (2-D); Fusion 5 (3-D); toxik; Mistika; Particle Illusion
      • Chris FullmerC Offline
        Yes, Syntheyes seems to be a popular option from what I've seen.
        It would be amost equally easy to make my pluing incorporate synthese exports also. In fact, I could perhasp just make my script read in the 3ds max export file. Then theoretically it might be able to import the camera match data from any camera match software. Maybe that would be a good solution,
        • F Offline
          floric
          This plugin was exactly what I was looking for. But it seem not to work correct.
          I generate a .txt (from 360 pictures, 132 kb) and then I import it with the plugin. The plugin asks me about the framerate, I klick OK and the scenes are generated. But all have the same perspective and there are no points from voodoo.
          If I play the animation every "picture" is exactly the same. The camera also seems to be nearly exactly at the point of origin.
          What went wrong? I used SU 8.
          Please help me. Thats a really great tool and would be if I can use it! πŸ˜„
          Thanks, floric
          I'm german. Please feel free to correct my language mistakes. :D
            Hmm, that is a good question. This plugin was a bit of an experiment by me, but it definitely should work. I guess could you upload the .txt file here? You might need to zip it so the forum accepts it. I'll take a look at it and see if there is an oddity in the file that my script is not able to understand. Thanks,
            • F Offline
              floric
              Thanks for your answer. πŸ˜„
              I attached the file in a ZIP. 😎
              Track.txt
              • F Offline
                floric
                PUSH
                Any changes at this problem. Or is there any other possibilitie to use Voodoo in Kerkythea?
                  😳 Sorry, I have not yet got to it. Perhaps this weekend I can though. Work has been unexpectedly bust the last couple of weeks - but we got a BIG project completed yesterday and this weekend I can finally relax.
                  • F Offline
                    floric
                    No problem. There is no hurry. πŸ˜„
                    • F Offline
                      floric
                      I really don't want to ennoy but ANY changes? πŸ˜„
                      It would be great if this plugin would work. πŸ˜„
                      EDIT: Sorry. I studied the camera-file of the tracker and it seems to be a bug of voodoo. πŸ˜„
                        Hey Floric, I am finally finding some time to look into this, and the first thing that I'm seeing is that the data is not coming out of Voodoo tracker correctly. So somehow I think you have not got Voodoo set up right. Is there any chance you could uploade the video that you are trying to track?
                          Bertier
                          that is great !
                          I'll give it a try.
                            sims
                            At first, I apologize for my pretty poor English, I don't speak it really fluently.
                            Whatever, I only wanted to thank you ! It's a pretty amazing work !
                            I'm a student in movie/photography and it's so useful for green screens !
                            Thanks a lot !
                              sims
                              After some tests, I still got a question: how do you make axes generated by voodoo match these of your sketchup model?
                              Maybe my purpose is not really clear... (Shame on my pretty poor English ^^)
                              So I join a screenshot:
                              http://img706.imageshack.us/img706/6049/printscreent.th.jpg
                              As you can see, there is some problem... And of course, if I simply rotate the model to make surface parallel to the ground, I lose scene views.
                              I'd like to make red and green axes match initial sketchup axes (and horizon to get realistic light while rendering) but I absolutly don't know how to do so ! I've been looking for solutions over the web for hours, but I didn't find anything !
                              No way to move horizon line in sketchup, nor to manually set axes in voodoo after tracking.
                              Well, I'm lost, can anyone help me, please?
                                Hi Sims, I've been out on vacation for a few weeks, but I'm back now.
                                I admit that I can't tell what it wrong with that image. It looks like it imported well to me. Could you upload the .txt file?
                                Or in your PM you sent me, you mentioned just trying to use another file format. If you could give me some better detail on what file format it is, I might be bale to write another version that reads their file format.
                                  sims
                                  Hope you enjoyed your vacation !
                                  First, about Voodoo, it generated a text file and it works. But as you saw, the wrong thing is that it didn't correctly find horizon... But I didn't manage to fix it.
                                  Then, I tried Boujou. It's much more flexible and userfriendly. It generates several kind of files. But its txt is not the same as Voodoo.
                                  You'll find attached both Voodoo and Boujou txt files from the same tracking test movie.
                                  Voodoo.txt
                                  Boujou.txt
                                    The picture is unclear. To me it looks like the camera path is oriented correctly with the model axes. It looks your "flat" plane and person component are the things that are wrong. The blue axis should be pointing upwards, but in your image, it is slanted, which is wrong. But I'm probably just not understanding what I'm seeing.
                                    As for Boujou, sounds good. I'll see if I can look at it. How quickly do you need it? I'm really swamped. But I might be able to get you something simple.
                                      sims
                                      Well, with Voodoo, something is wrong (even in 3D viewer), not only axes. It's really "skieve" as we'd say in my country. I mean, even while switching axes, it's still skewed.
                                      I would need it for post production, so first week of February. But I absolutly don't want to bother you ! If you are overbooked, don't waste your time for me !
                                      If I still have problems with 3D tracking, we'll work in 2D tracking, and that's it.
                                      Whatever, thank you for interest.
                                        kingsteve111
                                        Hi Chris
                                        This plugin is great! Thanks so much for writing it.
                                        I was wondering though if there is a way to make the imported pointcloud match the model, instead of pasting the model into the point cloud.
                                        I have found it nearly impossible to match large models to the point cloud. A easy way to do this would be to make the camera data align with the existing models axis.
                                        If you can alter that, I would find this plugin endlessly useful.
                                        Thanks again. πŸ˜„
