    .execute_script interesting quirk
    7 Posts 4 Posters 534 Views 4 Watching
      kdasilva
      I thought this experience would be worth sharing in case anyone else gets stuck like i did~
      So i don't know if this qualifies as a "bug" per say...but it definitely made my morning long and frustrating.
      Has any one else noticed that if you create an action_callback through clicking on a <a href...> tag instead of a button, the .execute script command no longer works on the web_dialog parameter. Correct me if Im wrong but I spent all morning testing this problem with two cal_backs that were essentially identical. It took me several hours to realize that the only difference was one got created through a button, and the other through a hyperlink
      everything else I worked in the callback except for .execute_script for the record
      (I was just using hyper-links because the buttons were so ugly)
      It would be interesting to see if other methods of creating a call_back in a webdialog have this bug.
      cheers
      Korbin
      *Update I did a quick test on a callback created through clicking on an image I have in my app, and it worked fine...verrrrry interesting
        I have several custom tools using href button with rounded ends etc instead of standard buttons - this way [you define the button class in your css style code] - the call_backs work fine - here's a snippet...
        <span class="syntaxdefault"><br /></span><span class="syntaxkeyword"><</span><span class="syntaxdefault">td align</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">center style</span><span class="syntaxkeyword">=</span><span class="syntaxstring">"width;84px; padding;3px;"</span><span class="syntaxkeyword">><br /></span><span class="syntaxdefault">      </span><span class="syntaxkeyword"><</span><span class="syntaxdefault">a id</span><span class="syntaxkeyword">=</span><span class="syntaxstring">"cancel_dropdown"</span><span class="syntaxdefault"> <br />         class</span><span class="syntaxkeyword">=</span><span class="syntaxstring">"button"</span><span class="syntaxdefault"> href</span><span class="syntaxkeyword">=</span><span class="syntaxstring">"#"</span><span class="syntaxdefault"> <br />         onclick</span><span class="syntaxkeyword">=</span><span class="syntaxstring">"this.blur(); window.location='skp;cancel_dropdown@';"</span><span class="syntaxkeyword">><br /></span><span class="syntaxdefault">      </span><span class="syntaxkeyword"><</span><span class="syntaxdefault">span</span><span class="syntaxkeyword">></span><span class="syntaxdefault">Cancel</span><span class="syntaxkeyword"></</span><span class="syntaxdefault">span</span><span class="syntaxkeyword">><br /></span><span class="syntaxdefault">      </span><span class="syntaxkeyword"></</span><span class="syntaxdefault">a</span><span class="syntaxkeyword">><br /></</span><span class="syntaxdefault">td</span><span class="syntaxkeyword">></span><span class="syntaxdefault"> </span>
          kdasilva
          even the .execute_script command? everything else works for me too except for that....although looking at your code it may be because i used:
          <a href="javascript:AddChangeDiagnosis()" ><b>[Add/Change]</b></a>
          to call the function, whereas both my buttons and the image i click use the "onclick" attribute
          ** confirmed....that was the problem, sooo take home lesson...always use "onclick" !
          • Dan RathbunD Offline
            Dan Rathbun
            Put this meta-tag in the <HEAD> section of the webdialog html:
            <span class="syntaxdefault"></span><span class="syntaxkeyword"><!--</span><span class="syntaxdefault"> This tells the HTML frame to use MS Common Controls ver 6</span><span class="syntaxkeyword">+</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">--><br /><!--</span><span class="syntaxdefault">  </span><span class="syntaxkeyword">(</span><span class="syntaxdefault">also known as XP style themed controls</span><span class="syntaxkeyword">.)</span><span class="syntaxdefault">   </span><span class="syntaxkeyword">--><br /><</span><span class="syntaxdefault">META HTTP</span><span class="syntaxkeyword">-</span><span class="syntaxdefault">EQUIV</span><span class="syntaxkeyword">=</span><span class="syntaxstring">"MSThemeCompatible"</span><span class="syntaxdefault"> CONTENT</span><span class="syntaxkeyword">=</span><span class="syntaxstring">"Yes"</span><span class="syntaxkeyword">></span><span class="syntaxdefault"> </span>
            I'm not here much anymore.
              I've not seen such quirk you mention. I suspect it might be some other JS error perhaps...?
                Dan Rathbun
                I think there is a whole topic on this concerning "Javascript:void(0);" vs "Javascript:return;" one of which needs to be in the HREF tag, the Ruby callback needs to be in the onClick call.
                  To avoid triggering an A HREF link, and instead execute some other JS code, you return false to the onclick event.
