    Select faces by orientation
    6 Posts 2 Posters 1.2k Views 2 Watching
      JPMays
      Anyone know a way to select all vertical faces? I need to uniformly delete them, and there are way too many to go through and do it manually.
      Thanks.
      Hofstadter's Law: It always takes longer than you expect, even when you take into account Hofstadter's Law.
        d12dozr
        ThomThom's Selection Toys will do that.
        http://goo.gl/f7ooYh
          JPMays
          I found those but can't figure out to be that specific. Are you familiar with them?
            d12dozr
            Yes, just right click on any vertical face, then Select -> Coplanar Faces
            I guess that will only select faces in that exact orientation, and so will take more than one selection but will still cut down some of your work
              JPMays
              Ok, that led me to an easy way to do this: to right click on a horizontal surface, then click select perpendicular.
              http://img839.imageshack.us/img839/6782/97183817.jpg
              Then deselect the original face and you're good to go.
              http://img580.imageshack.us/img580/293/17492130.jpg
              Thanks for the help.
                d12dozr
                ๐Ÿ‘ ah, perfect!
