    [Plugin] ImageTrimmer
    364 Posts 58 Posters 243.4k Views 58 Watching
      The .jar is working fine when double-clicked [those are the files that it should automatically make for you before going to the next stage] but it's not working properly when UI.openURL() is used.
      It's probably down to your Java settings and permissions.
      A .jar file will run when its icon is double-clicked and it should 'executed' in a 'command' file.
      I don't have access to a MAC but is there a Java control-panel ?
      Can you set permissions and so on in that ?
      Please go to the SKMtools folder and check that the 'EdgeDetector.jar' has the correct 'properties' for you as a user - should be 'executable by you/others... If not fix it [also do this for all other jar-files in there too...]
        krath
        thanks for the quick reply,
        the "EdgeDetector.jar" file has already the correct Properties.
        There is an application called Java-preferences in the utilities folder, but I am nut sure which settings I should change.
        It has Settings for Security, Network and - I'm trying to translate since my OS is in german - two options for:
        "Run applets" > 1) "within own Process" or 2) "within browser process"
        Does that have any relevance?
          It has Settings for Security, Network and - I'm trying to translate since my OS is in German - two options for:
          I don't know.
          Try using alternatives and retry 'ImageTrimmer' for each.
          If it works one one thane that's the setting you need πŸ˜„
          If you do find the fix I'd appreciate it if you posted the settings as a few other MAC users seem to have issues too - although many don't πŸ˜•
            krath
            Thank you,
            I am fiddling with the settings already, with no luck so far.
            I did a quick google search for "setting java permissions osx" and that opens up a whole new scary landscape for me, which I am not sure I should embark upon right now. 😲
              If there are any MAC users out there successfully using ImageTrimmer then please contribute your settings etc so that other MAC users can benefit too... πŸ˜•
              • OxerO Offline
                Oxer
                Hi again TIG,
                The problem persists, it appears the same Console Error:
                Console error
                The EdgeDetector.jar file goes if you double-click on it, the permissions are correct, i think the problem on mac is that the plugin don't access to the EdgeDetector.jar file, i can't say you more.
                  Thanks Oxer... I've got some other MAC users [via PM] investigating the issue... watch this space... πŸ˜’
                  • ely862meE Offline
                    ely862me
                    With big png's just gives me bugsplat,can it be because of my pc(2.8ghz 1gb ram 1gb graphic card) ?
                    banana_tree.rar
                    Elisei (sketchupper)
                    Come and See EliseiDesign
                      @ely862me said:
                      With big png's just gives me bugsplat, can it be because of my pc (2.8ghz 1gb ram 1gb graphic card) ?
                      The banana_tree at that size has ~3.5 million pixels that would need processing into viable edges !
                      At 1/2 the size [scaled in Gimp] it's 1/4 of the pixels and although it's still too many to be sensible it probably won't splat - but it just doesn't do miracles, it just takes time... !
                      You have a lot of semi-transparent bleeding edges that also up the processing time dramatically - edit those out too - they're probably the biggest processing time killer, as it might have to find all sorts of small loops from the small semi-transparent 'islands' before discarding them.
                      You also have a lot of other small areas of pixels that will be ignored as edges as they are too thin [<2px] BUT these still need to be examined which slows things down too - so pre-edit the image a bit to simplify it!
                      [but you probably need 3Gb+ RAM too!]
                      Here's a result at about 1/2 size - original image, then as trimmed unsimplified and simplified x2.0...banana_tree.skpbanana_tree_trimmed.PNG
                      • ely862meE Offline
                        ely862me
                        Thank you very much for heads up and for a nice plugin !!
                          Here's v2.2 http://forums.sketchucation.com/viewtopic.php?p=294815#p294815 - follow the links to the 'download' page in SKMtools......
                          The MAC jar file execution has at last been addressed
                          [My thanks to Dave R for helping with the MAC testing etc πŸ˜„ ]
                          On a MAC you might find you are asked if you want to run a particular jar file - if so answer 'yes' - it's a one off prompt per jar-type so it should stop after the first run.
                          Feedback please...
                            krath
                            Flawless !!!
                            It now runs without Interruptions. Prefect results - especially with the ImageTrimmer-Simplifier afterwards. πŸ‘
                            Thanks a lot TIG et al !
                            If it is not too complicated I would be interested, what the problem was running the scripts on the mac.
                            Thanks again
                              @krath said:
                              Flawless !!!
                              Thanks again
                              It was a bit obscure!
                              The command UI.openURL('file:/'+path_to_jar) works fine on all PCs AND on MACs where the path doesn't start with a '/' - e.g. PC's 'C:/Program.../...'.
                              BUT some MAC users install their Plugins in an alternative location which starts with a '/' therefore 'file:/'+path_to_jar fails as it doubles up the '/' to '//' and the file isn't then 'found'
                              πŸ˜’
                              So I added an additional test: if ' path_to_jar' starts with a '/' then jar='file:'+path_to_jar else jar='file:/'+path_to_jar.
                              So in the end a simple problem was masked by lots of other issues - but at least it's fixed [at last] πŸ˜’
                              [Actually Oxer HAD spotted the nature of the problem a few weeks ago, BUT "the penny hadn't dropped"... πŸ˜’ πŸ˜’ ]
                              • OxerO Offline
                                Oxer
                                Hi TIG,
                                Finally the problem have been resolved, sometimes you have the solution in front to your eyes but the forest don't let you see it.
                                Thanks TIG for you perseverance.
                                  krath
                                  TIG,
                                  on a MAC, the pathname always starts with a '/' because that's the root directory. Volumes follow behind that slash.
                                  Oxer stated two alternative Pathnames on his Mac earlier in this thread, the second of which started with "Library/...".
                                  It should really read "**/**Library/...".
                                  Hope I don't come across as beeing pedantic; maybe it helps avoiding similar problems in the future. πŸ€“
                                    @krath said:
                                    TIG,
                                    Hope I don't come across as being pedantic; maybe it helps avoiding similar problems in the future. πŸ€“
                                    OK - but it works now as the PC and MAC versions are differentiated by the inclusion or not of a trailing '/' after 'file:' πŸ˜„
                                      krath
                                      Yes, it does!
                                      Thanks to your persistence in solving the problem. πŸ˜„
                                        driven
                                        cheers Tig
                                        Heather hasn't tried the 'TIG PLAN' diet and comes in at >200% heftier...
                                        finally I got it to work on 10.5.8, and just incase it saves others some time searching.
                                        if you have them put them in this order, else download so you can.
                                          davidlouis
                                          Hi TIG
                                          I have migrated my version of skp to a new pc running windows 7 (former pc running winxp) and my image trimmer is not working at all.
                                          The tool does appear to start to run on an imported png file (as image) but won't progress to the first prompt to stand up the component etc. It simply stops and allows you to go back to using the skp tools.
                                          Ruby console report is below:
                                          Error: #<Errno::ENOENT: No such file or directory - C:\Users\Apache\Documents\TrimmedImages\Untitled-1[Edges].dat>
                                          C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/SKMtools/ImageTrimmer.rb:232:in readlines' C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/SKMtools/ImageTrimmer.rb:232:in make_edges'
                                          C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/SKMtools/ImageTrimmer.rb:185:in process_image' C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/SKMtools/ImageTrimmer.rb:162:in initialize'
                                          C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/SKMtools/ImageTrimmer.rb:759:in `new'
                                          This is a strange error about not being able to find a file...
                                          This runs just fine on my laptop with xp using the same file so i'm guessing that this is operating system based?
                                          Also when migrating the plugins, i did a simple copy and paste into the skp directory on the new machine... don'tknow if any files should be elsewhere given that you use a bit of java on this one.
                                          Any help will be much appreciated....
                                          Dave
                                            David
                                            This indicates that on your new PC either there is not a suitable version of Java installed, or it's not properly enabled, or if it is it does not have its options set correctly to allow 'jar' files to execute. There are several posts about what Java settings to have to allow all of this family of tools working - they all use 'jar' - Java executable applets - that you setting must allow to run in 'Java options'...
                                            Also please check access-rights to the Plugins folder and the SKMtools subfolder and its contents, which must allow read/write/execute etc for everything and everyone... This could cause problems to as some temporary files are written here.
                                            Please come back either with your fix or continuing problems... πŸ€“
                                            • 11
                                            • 12
                                            • 13
                                            • 18
                                            • 19
                                            • 11 / 19
