    [Plugin] Bitmap To Mesh
    264 Posts 75 Posters 530.7k Views 75 Watching
      jeffschaid01
      In sketchup format (after converting to mesh) the file size is 13megs. I've attached the image for which I'm creating the "bitmap to mesh" from. Its size prior to converting to mesh is 44kb. I think you might be on to something as far as SU running out of memory. Possible work around?
        First verify it's a memory issue. open Task Manager and monitor the memory usage of SketchUp.exe when you export.
          That mesh I got from that image you posted was pretty dense. 85K triangles.
          I ran CleanUp on it afterwards, resulting in 34K triangles.
          If SU is running out of memory, I'd suggest you try with a smaller bitmap. Also, try to run CleanUp before exporting to get rid of co-planar faces.
            jeffschaid01
            Thanks very much for the help. The cpu usage is at about 250,000k when the export process hits 49% then climbs to 270k and the program crashes and closes. Is this beyond SU capabilities?
              No - it'd be at about 2GB. (Unless you have a 64bit OS and SU8M1 with more than 4GB RAM installed - then it can use up to 4GB.)
              It must be something else.
                jeffschaid01
                Is the "cleanup" process a function of SU?
                  It's another plugin of mine: http://forums.sketchucation.com/viewtopic.php?f=323&t=22920
                    jeffschaid01
                    Great. I will get this installed as well. Did you have a chance to take a look at the photos of the model I emailed you yesterday? If so, can that be achieved with this program?
                      Well, it generates the mesh. And I'd think that if you closed that mesh into a solid it should be possible to 3d point the model.
                      The problem seem to be the exporting. I also see the crashes. I even ran CleanUp on the mesh and it crashed.
                      Try to scale down the bitmap to half the size and see if it still crashes then.
                        jeffschaid01
                        Scaled down and unfortunately still having the same problem. You mentioned closing the mesh into a solid, is SU capable of completing a task like this? If not, any recommendations as far as a software program that may be capable of creating such a model?
                        • G
                          GUNAWAN W
                          was waiting for this for alooong time,
                          Awsome! Thanks thomthom 👍
                            Version 0.4.0b
                            • Progress feedback
                            (And I managed to delete one of the example images in the original post. 😞 No undo... )
                            • K
                              KulaCZEk
                              hi there,
                              Its there any posibility to reduce polygons? I tried Polyreduce plugin, which is on forum, but it doesnt work well. And my second question is about performance. I am using iMac, 2.66ghz, 4gb ram, nv9400. On this platform take generating of 150x150px height map around 4. minutes. Can you recomend something to speed it up?
                                Scale the bitmap down before processing it. Smaller image = simpler mesh = faster generation.
                                • ichiI
                                  ichi
                                  Thanks for the update thomthom,it's one of my favorite plugins 😄
                                  Blog
                                  • 66searcher6
                                    66searcher
                                    @ TT : well done ! it's great plugin . 👍
                                    http://hamidtoliat.deviantart.com/
                                    • Y
                                      yuchunGong
                                        daveydave
                                        thanks, works in verion 6 too.
                                        • K
                                          kgregorian
                                          Hey everyone, I am new to these forums and I have a quick question, I'm sorry in advance if it's already been answered. I just downloaded this plugin, and placed it in the right location...I have a Mac, so I wen to my internal hdd>app support>google sketchup 8>sketchup>plugins. Yet when I open sketchup it says the following: 'Error Loading File tt_bitmap2mesh.rb no such file to load -- TT_Lib2/core.rb'. This happened to me before, what I did to correct it. Any help would be appreciated. Thanks!
                                          • GaieusG
                                            You have missed the "Requirements" in the first post:
                                            You also need this plugin:
                                            http://forums.sketchucation.com/download/file.php?id=63393
                                            • 13
                                            • 14
                                            • 7 / 14
