    64K vertices error re_visited
    2 Posts 2 Posters 1.3k Views 2 Watching
      aroestenburg
      I keep getting this error when trying to upload a model to Google Earth.
      "Warning: Vertec array in geometry triangles:Materals2:63150 has more than 64K vertices."
      It is only happening for the particular model shown in the image below. Others similar to this one are importing fine.
      I read this topic earlier on the message board but there were few responses.
      I tried using cleanup plugin by ThomThom thinking this may be a polycount issue but still no luck.
      any ideas?
      The .skp model:
      http://lh3.ggpht.com/_a6ubqXpGREI/TP3WiAE5AgI/AAAAAAAAAOI/9wS7w8CDnRs/s640/skp_model_pre_fail.jpg
      The result in Google:
      http://lh4.ggpht.com/_a6ubqXpGREI/TP3WhnM8wdI/AAAAAAAAAOE/oONgy4vpmIk/s640/ge_fail-2.jpg
        agamemnus
        Perhaps on the other ones, Google is using some internal optimizations to trim your model's vertex count. Maybe it can't do that on this one.
        One optimization might be to convert a rectangular face with several polys to two triangles, if they all have the same color or texture information. If you colored those polys differently this time around, then Google can't reduce the poly count anymore.
