    Notepad++ SU8 Ruby API Autocomplete
    62 Posts 12 Posters 19.5k Views 12 Watching
    • Dan RathbunD Offline
      Dan Rathbun
      @thomthom said:
      Why you need dot colon in keywords?
      = Seem to work anyway. Space was already there.
      Just wondering if it was required so that the feature can lookup things correctly.
      I'm not here much anymore.
        Dan Rathbun
        More information on this link: Autocompletion, aka API, files, which says:
        additionalWordChar: character(s) that may be part of words and which are not a lower or upper case letter, a digit or the underscore. The value is a string with all these extra characters, in any order and without separators. The string is empty by default.
        EDIT .. more info from that page:
        Names
        For both call tips and autocompletion to work, keywords must be words, ie identifiers most languages would readily accept. This means that only the 26 Latin alphabet letters in either lower or upper case (no diacritics), digits and the underscore are safe to use. Additional allowed characters will work if they are not whitespace. Autocompletion may cope with spaces or blanks, call tips won't. This is a Scintilla limitation.
          tomasz
          Thank you!
            Revision 3 - 01.02.2011
            Rebuilt the list from scratch. Used only the classes and methods from Ruby 1.8.6 and SketchUp API. (The old file seemed to have lots of Ruby On Rails references.)
              Dan Rathbun
              Do you it's possible to have whole qualified classnames and constants in the AutoComplete?
              Examples:
              Math::PI
              File::SEPARATOR
              Sketchup::Drawingelement
              UI::Toolbar
              etc. ??
                Dan Rathbun
                I noticed in the old list certain entries did not work correctly where the module name followed the keyword in paranthesis. Notepad++ got confused and took them to be a parameter (argument) list.
                  Yes, it's possible. Some Ruby classes are listed like that. File for instance. (Just ripped it directly from the docs.)
                  Is there a list of available?
                  (I just ripped the class names and methods from the Ruby docs and SU docs - without further processing.) So constants and nesting is missing.
                    Dan Rathbun
                    @thomthom said:
                    These are the ones that caused problems (but the ver 3 does not have them.)
                      Dan Rathbun
                      Both ver 2, and the original (Didier's version?) have fully qualified classes that you can cut and paste from.
                      For constants we'll have to compile a list.
                        @dan rathbun said:
                        [attachment=0:ef22v8uz]<!-- ia0 -->old_NPP_autocomplete.png<!-- ia0 -->[/attachment:ef22v8uz]
                        Oh! Didn't noticed that.
                        Ah, yea. I did that manually for v2.
                          Dan Rathbun
                          Here's the 1.8.6 constant list for the Errno module, on the PC:
                          For PC (note! OSX SystemCallError subclasses may differ.)
                          		<Keyword name="Errno;;E2BIG"/>
                          		<Keyword name="Errno;;E2BIG;;Errno"/>
                          		<Keyword name="Errno;;EACCES"/>
                          		<Keyword name="Errno;;EACCES;;Errno"/>
                          		<Keyword name="Errno;;EADDRINUSE"/>
                          		<Keyword name="Errno;;EADDRINUSE;;Errno"/>
                          		<Keyword name="Errno;;EADDRNOTAVAIL"/>
                          		<Keyword name="Errno;;EADDRNOTAVAIL;;Errno"/>
                          		<Keyword name="Errno;;EAFNOSUPPORT"/>
                          		<Keyword name="Errno;;EAFNOSUPPORT;;Errno"/>
                          		<Keyword name="Errno;;EAGAIN"/>
                          		<Keyword name="Errno;;EAGAIN;;Errno"/>
                          		<Keyword name="Errno;;EALREADY"/>
                          		<Keyword name="Errno;;EALREADY;;Errno"/>
                          		<Keyword name="Errno;;EBADF"/>
                          		<Keyword name="Errno;;EBADF;;Errno"/>
                          		<Keyword name="Errno;;EBUSY"/>
                          		<Keyword name="Errno;;EBUSY;;Errno"/>
                          		<Keyword name="Errno;;ECHILD"/>
                          		<Keyword name="Errno;;ECHILD;;Errno"/>
                          		<Keyword name="Errno;;ECONNABORTED"/>
                          		<Keyword name="Errno;;ECONNABORTED;;Errno"/>
                          		<Keyword name="Errno;;ECONNREFUSED"/>
                          		<Keyword name="Errno;;ECONNREFUSED;;Errno"/>
                          		<Keyword name="Errno;;ECONNRESET"/>
                          		<Keyword name="Errno;;ECONNRESET;;Errno"/>
                          		<Keyword name="Errno;;EDEADLK"/>
                          		<Keyword name="Errno;;EDEADLK;;Errno"/>
                          		<Keyword name="Errno;;EDEADLOCK"/>
                          		<Keyword name="Errno;;EDEADLOCK;;Errno"/>
                          		<Keyword name="Errno;;EDESTADDRREQ"/>
                          		<Keyword name="Errno;;EDESTADDRREQ;;Errno"/>
                          		<Keyword name="Errno;;EDOM"/>
                          		<Keyword name="Errno;;EDOM;;Errno"/>
                          		<Keyword name="Errno;;EDQUOT"/>
                          		<Keyword name="Errno;;EDQUOT;;Errno"/>
                          		<Keyword name="Errno;;EEXIST"/>
                          		<Keyword name="Errno;;EEXIST;;Errno"/>
                          		<Keyword name="Errno;;EFAULT"/>
                          		<Keyword name="Errno;;EFAULT;;Errno"/>
                          		<Keyword name="Errno;;EFBIG"/>
                          		<Keyword name="Errno;;EFBIG;;Errno"/>
                          		<Keyword name="Errno;;EHOSTDOWN"/>
                          		<Keyword name="Errno;;EHOSTDOWN;;Errno"/>
                          		<Keyword name="Errno;;EHOSTUNREACH"/>
                          		<Keyword name="Errno;;EHOSTUNREACH;;Errno"/>
                          		<Keyword name="Errno;;EILSEQ"/>
                          		<Keyword name="Errno;;EILSEQ;;Errno"/>
                          		<Keyword name="Errno;;EINPROGRESS"/>
                          		<Keyword name="Errno;;EINPROGRESS;;Errno"/>
                          		<Keyword name="Errno;;EINTR"/>
                          		<Keyword name="Errno;;EINTR;;Errno"/>
                          		<Keyword name="Errno;;EINVAL"/>
                          		<Keyword name="Errno;;EINVAL;;Errno"/>
                          		<Keyword name="Errno;;EIO"/>
                          		<Keyword name="Errno;;EIO;;Errno"/>
                          		<Keyword name="Errno;;EISCONN"/>
                          		<Keyword name="Errno;;EISCONN;;Errno"/>
                          		<Keyword name="Errno;;EISDIR"/>
                          		<Keyword name="Errno;;EISDIR;;Errno"/>
                          		<Keyword name="Errno;;ELOOP"/>
                          		<Keyword name="Errno;;ELOOP;;Errno"/>
                          		<Keyword name="Errno;;EMFILE"/>
                          		<Keyword name="Errno;;EMFILE;;Errno"/>
                          		<Keyword name="Errno;;EMLINK"/>
                          		<Keyword name="Errno;;EMLINK;;Errno"/>
                          		<Keyword name="Errno;;EMSGSIZE"/>
                          		<Keyword name="Errno;;EMSGSIZE;;Errno"/>
                          		<Keyword name="Errno;;ENAMETOOLONG"/>
                          		<Keyword name="Errno;;ENAMETOOLONG;;Errno"/>
                          		<Keyword name="Errno;;ENETDOWN"/>
                          		<Keyword name="Errno;;ENETDOWN;;Errno"/>
                          		<Keyword name="Errno;;ENETRESET"/>
                          		<Keyword name="Errno;;ENETRESET;;Errno"/>
                          		<Keyword name="Errno;;ENETUNREACH"/>
                          		<Keyword name="Errno;;ENETUNREACH;;Errno"/>
                          		<Keyword name="Errno;;ENFILE"/>
                          		<Keyword name="Errno;;ENFILE;;Errno"/>
                          		<Keyword name="Errno;;ENOBUFS"/>
                          		<Keyword name="Errno;;ENOBUFS;;Errno"/>
                          		<Keyword name="Errno;;ENODEV"/>
                          		<Keyword name="Errno;;ENODEV;;Errno"/>
                          		<Keyword name="Errno;;ENOENT"/>
                          		<Keyword name="Errno;;ENOENT;;Errno"/>
                          		<Keyword name="Errno;;ENOEXEC"/>
                          		<Keyword name="Errno;;ENOEXEC;;Errno"/>
                          		<Keyword name="Errno;;ENOLCK"/>
                          		<Keyword name="Errno;;ENOLCK;;Errno"/>
                          		<Keyword name="Errno;;ENOMEM"/>
                          		<Keyword name="Errno;;ENOMEM;;Errno"/>
                          		<Keyword name="Errno;;ENOPROTOOPT"/>
                          		<Keyword name="Errno;;ENOPROTOOPT;;Errno"/>
                          		<Keyword name="Errno;;ENOSPC"/>
                          		<Keyword name="Errno;;ENOSPC;;Errno"/>
                          		<Keyword name="Errno;;ENOSYS"/>
                          		<Keyword name="Errno;;ENOSYS;;Errno"/>
                          		<Keyword name="Errno;;ENOTCONN"/>
                          		<Keyword name="Errno;;ENOTCONN;;Errno"/>
                          		<Keyword name="Errno;;ENOTDIR"/>
                          		<Keyword name="Errno;;ENOTDIR;;Errno"/>
                          		<Keyword name="Errno;;ENOTEMPTY"/>
                          		<Keyword name="Errno;;ENOTEMPTY;;Errno"/>
                          		<Keyword name="Errno;;ENOTSOCK"/>
                          		<Keyword name="Errno;;ENOTSOCK;;Errno"/>
                          		<Keyword name="Errno;;ENOTTY"/>
                          		<Keyword name="Errno;;ENOTTY;;Errno"/>
                          		<Keyword name="Errno;;ENXIO"/>
                          		<Keyword name="Errno;;ENXIO;;Errno"/>
                          		<Keyword name="Errno;;EOPNOTSUPP"/>
                          		<Keyword name="Errno;;EOPNOTSUPP;;Errno"/>
                          		<Keyword name="Errno;;EPERM"/>
                          		<Keyword name="Errno;;EPERM;;Errno"/>
                          		<Keyword name="Errno;;EPFNOSUPPORT"/>
                          		<Keyword name="Errno;;EPFNOSUPPORT;;Errno"/>
                          		<Keyword name="Errno;;EPIPE"/>
                          		<Keyword name="Errno;;EPIPE;;Errno"/>
                          		<Keyword name="Errno;;EPROTONOSUPPORT"/>
                          		<Keyword name="Errno;;EPROTONOSUPPORT;;Errno"/>
                          		<Keyword name="Errno;;EPROTOTYPE"/>
                          		<Keyword name="Errno;;EPROTOTYPE;;Errno"/>
                          		<Keyword name="Errno;;ERANGE"/>
                          		<Keyword name="Errno;;ERANGE;;Errno"/>
                          		<Keyword name="Errno;;EREMOTE"/>
                          		<Keyword name="Errno;;EREMOTE;;Errno"/>
                          		<Keyword name="Errno;;EROFS"/>
                          		<Keyword name="Errno;;EROFS;;Errno"/>
                          		<Keyword name="Errno;;ESHUTDOWN"/>
                          		<Keyword name="Errno;;ESHUTDOWN;;Errno"/>
                          		<Keyword name="Errno;;ESOCKTNOSUPPORT"/>
                          		<Keyword name="Errno;;ESOCKTNOSUPPORT;;Errno"/>
                          		<Keyword name="Errno;;ESPIPE"/>
                          		<Keyword name="Errno;;ESPIPE;;Errno"/>
                          		<Keyword name="Errno;;ESRCH"/>
                          		<Keyword name="Errno;;ESRCH;;Errno"/>
                          		<Keyword name="Errno;;ESTALE"/>
                          		<Keyword name="Errno;;ESTALE;;Errno"/>
                          		<Keyword name="Errno;;ETIMEDOUT"/>
                          		<Keyword name="Errno;;ETIMEDOUT;;Errno"/>
                          		<Keyword name="Errno;;ETOOMANYREFS"/>
                          		<Keyword name="Errno;;ETOOMANYREFS;;Errno"/>
                          		<Keyword name="Errno;;EUSERS"/>
                          		<Keyword name="Errno;;EUSERS;;Errno"/>
                          		<Keyword name="Errno;;EWOULDBLOCK"/>
                          		<Keyword name="Errno;;EWOULDBLOCK;;Errno"/>
                          		<Keyword name="Errno;;EXDEV"/>
                          		<Keyword name="Errno;;EXDEV;;Errno"/>
                          output via: Ruby console and type (one-liner):
                          Errno.constants.sort.each {|e| puts %Q[\t\t<Keyword name="Errno::#{e}"/>\n\t\t<Keyword name="Errno::#{e}::Errno"/>\n] }
                          Then copy and paste into the ruby.xml file for Notepad++
                            Dan Rathbun
                            Here's the 1.8.6 constant list for the File module:
                            		<KeyWord name="File;;ALT_SEPARATOR"/>
                            		<KeyWord name="File;;APPEND"/>
                            		<KeyWord name="File;;BINARY"/>
                            		<KeyWord name="File;;CREAT"/>
                            		<KeyWord name="File;;Constants;;APPEND"/>
                            		<KeyWord name="File;;Constants;;BINARY"/>
                            		<KeyWord name="File;;Constants;;CREAT"/>
                            		<KeyWord name="File;;Constants;;EXCL"/>
                            		<KeyWord name="File;;Constants;;FNM_CASEFOLD"/>
                            		<KeyWord name="File;;Constants;;FNM_DOTMATCH"/>
                            		<KeyWord name="File;;Constants;;FNM_NOESCAPE"/>
                            		<KeyWord name="File;;Constants;;FNM_PATHNAME"/>
                            		<KeyWord name="File;;Constants;;FNM_SYSCASE"/>
                            		<KeyWord name="File;;Constants;;LOCK_EX"/>
                            		<KeyWord name="File;;Constants;;LOCK_NB"/>
                            		<KeyWord name="File;;Constants;;LOCK_SH"/>
                            		<KeyWord name="File;;Constants;;LOCK_UN"/>
                            		<KeyWord name="File;;Constants;;NONBLOCK"/>
                            		<KeyWord name="File;;Constants;;RDONLY"/>
                            		<KeyWord name="File;;Constants;;RDWR"/>
                            		<KeyWord name="File;;Constants;;TRUNC"/>
                            		<KeyWord name="File;;Constants;;WRONLY"/>
                            		<KeyWord name="File;;EXCL"/>
                            		<KeyWord name="File;;FNM_CASEFOLD"/>
                            		<KeyWord name="File;;FNM_DOTMATCH"/>
                            		<KeyWord name="File;;FNM_NOESCAPE"/>
                            		<KeyWord name="File;;FNM_PATHNAME"/>
                            		<KeyWord name="File;;FNM_SYSCASE"/>
                            		<KeyWord name="File;;LOCK_EX"/>
                            		<KeyWord name="File;;LOCK_NB"/>
                            		<KeyWord name="File;;LOCK_SH"/>
                            		<KeyWord name="File;;LOCK_UN"/>
                            		<KeyWord name="File;;NONBLOCK"/>
                            		<KeyWord name="File;;PATH_SEPARATOR"/>
                            		<KeyWord name="File;;RDONLY"/>
                            		<KeyWord name="File;;RDWR"/>
                            		<KeyWord name="File;;SEEK_CUR"/>
                            		<KeyWord name="File;;SEEK_END"/>
                            		<KeyWord name="File;;SEEK_SET"/>
                            		<KeyWord name="File;;SEPARATOR"/>
                            		<KeyWord name="File;;Separator"/>
                            		<KeyWord name="File;;TRUNC"/>
                            		<KeyWord name="File;;WRONLY"/>
                              Dan Rathbun
                              Here's the 1.8.6 constant list for the Float class:
                              		<Keyword name="Float;;DIG"/>
                              		<Keyword name="Float;;EPSILON"/>
                              		<Keyword name="Float;;MANT_DIG"/>
                              		<Keyword name="Float;;MAX"/>
                              		<Keyword name="Float;;MAX_10_EXP"/>
                              		<Keyword name="Float;;MAX_EXP"/>
                              		<Keyword name="Float;;MIN"/>
                              		<Keyword name="Float;;MIN_10_EXP"/>
                              		<Keyword name="Float;;MIN_EXP"/>
                              		<Keyword name="Float;;RADIX"/>
                              		<Keyword name="Float;;ROUNDS"/>
                                Dan Rathbun
                                Here's the 1.8.6 constant list for the IO class:
                                		<Keyword name="IO;;APPEND"/>
                                		<Keyword name="IO;;BINARY"/>
                                		<Keyword name="IO;;CREAT"/>
                                		<Keyword name="IO;;EXCL"/>
                                		<Keyword name="IO;;FNM_CASEFOLD"/>
                                		<Keyword name="IO;;FNM_DOTMATCH"/>
                                		<Keyword name="IO;;FNM_NOESCAPE"/>
                                		<Keyword name="IO;;FNM_PATHNAME"/>
                                		<Keyword name="IO;;FNM_SYSCASE"/>
                                		<Keyword name="IO;;LOCK_EX"/>
                                		<Keyword name="IO;;LOCK_NB"/>
                                		<Keyword name="IO;;LOCK_SH"/>
                                		<Keyword name="IO;;LOCK_UN"/>
                                		<Keyword name="IO;;NONBLOCK"/>
                                		<Keyword name="IO;;RDONLY"/>
                                		<Keyword name="IO;;RDWR"/>
                                		<Keyword name="IO;;SEEK_CUR"/>
                                		<Keyword name="IO;;SEEK_END"/>
                                		<Keyword name="IO;;SEEK_SET"/>
                                		<Keyword name="IO;;TRUNC"/>
                                		<Keyword name="IO;;WRONLY"/>
                                  Dan Rathbun
                                  Here's the 1.8.6 constant list AND class methods for the Marshal module:
                                  		<Keyword name="Marshal;;MAJOR_VERSION"/>
                                  		<Keyword name="Marshal;;MINOR_VERSION"/>
                                  		<Keyword name="Marshal;;dump" func="yes">
                                  			<Overload retVal="String" descr="Returns String result of serializing obj and all descendent objects.">
                                  				<Param name="~Object obj" />
                                  			</Overload>
                                  			<Overload retVal="~IO" descr="Returns io_obj, after writing to it, the serialized data for obj and all descendent objects.">
                                  				<Param name="~IO io_obj" />
                                  			</Overload>
                                  			<Overload retVal="~IO" descr="Returns io_obj, after writing to it, the serialized data for obj and the descendent objects limited to the specified depth (if non-negative. Default depth=-1)">
                                  				<Param name="~Integer depth" />
                                  			</Overload>
                                  		</KeyWord>
                                  		<Keyword name="Marshal;;load" func="yes">
                                  			<Overload retVal="~Object" descr="Returns the result of converting the serialized data in source into a Ruby object (possibly with associated subordinate objects). source may be either an instance of IO or an object that responds to to_str().">
                                  				<Param name="~IO|^String source" />
                                  			</Overload>
                                  			<Overload retVal="~Object" descr="Returns the result of converting the serialized data in source into a Ruby object (possibly with associated subordinate objects). source may be either an instance of IO or an object that responds to to_str(). If proc_obj is specified, it will be passed each object as it is deserialized.">
                                  				<Param name="Proc proc_obj" />
                                  			</Overload>
                                  		</KeyWord>
                                  		<Keyword name="Marshal;;restore" func="yes">
                                  			<Overload retVal="~Object" descr="Alias for Marshal;;load() Returns the result of converting the serialized data in source into a Ruby object (possibly with associated subordinate objects). source may be either an instance of IO or an object that responds to to_str().">
                                  			</Overload>
                                  			<Overload retVal="~Object" descr="Alias for Marshal;;load() Returns the result of converting the serialized data in source into a Ruby object (possibly with associated subordinate objects). source may be either an instance of IO or an object that responds to to_str(). If proc_obj is specified, it will be passed each object as it is deserialized.">
                                  			</Overload>
                                  		</KeyWord>
                                  As an experiment, in parameters, I used:
                                  "~" to denote "this class or subclass"
                                  "^" to denote "implictly convertable to" (which would include the class and any subclasses.)
                                  for ex: ^Integer would mean: " Integer class, subclass, or object that implements a to_i() method."
                                    driven
                                    Hi Dan,
                                    This is the sort of thing I want to check in SU ruby on the mac,
                                    Your first snip seems to bring up loads more methods than what your posting, are you editing yours down?
                                    I'd like to do more, but adding the code to get the extra bits is beyond me.
                                    Would you mind sharing Marshal snippet, and will that work with all modules?
                                    Is the a 1.8.6 module that simply didn't exist at all in 1.8.5 that I could test for?
                                    cheers
                                    	<Keyword name="File;;FNM_CASEFOLD;;File"/>
                                    		<Keyword name="File;;FNM_DOTMATCH"/>
                                    		<Keyword name="File;;FNM_DOTMATCH;;File"/>
                                    		<Keyword name="File;;FNM_NOESCAPE"/>
                                    		<Keyword name="File;;FNM_NOESCAPE;;File"/>
                                    		<Keyword name="File;;FNM_PATHNAME"/>
                                    		<Keyword name="File;;FNM_PATHNAME;;File"/>
                                    		<Keyword name="File;;FNM_SYSCASE"/>
                                    		<Keyword name="File;;FNM_SYSCASE;;File"/>
                                    		<Keyword name="File;;LOCK_EX"/>
                                    		<Keyword name="File;;LOCK_EX;;File"/>
                                    		<Keyword name="File;;LOCK_NB"/>
                                    		<Keyword name="File;;LOCK_NB;;File"/>
                                    		<Keyword name="File;;LOCK_SH"/>
                                    		<Keyword name="File;;LOCK_SH;;File"/>
                                    		<Keyword name="File;;LOCK_UN"/>
                                    		<Keyword name="File;;LOCK_UN;;File"/>
                                    		<Keyword name="File;;NOCTTY"/>
                                    		<Keyword name="File;;NOCTTY;;File"/>
                                    		<Keyword name="File;;NONBLOCK"/>
                                    		<Keyword name="File;;NONBLOCK;;File"/>
                                    		<Keyword name="File;;PATH_SEPARATOR"/>
                                    		<Keyword name="File;;PATH_SEPARATOR;;File"/>
                                    		<Keyword name="File;;RDONLY"/>
                                    		<Keyword name="File;;RDONLY;;File"/>
                                    		<Keyword name="File;;RDWR"/>
                                    		<Keyword name="File;;RDWR;;File"/>
                                    		<Keyword name="File;;SEEK_CUR"/>
                                    		<Keyword name="File;;SEEK_CUR;;File"/>
                                    		<Keyword name="File;;SEEK_END"/>
                                    		<Keyword name="File;;SEEK_END;;File"/>
                                    		<Keyword name="File;;SEEK_SET"/>
                                    		<Keyword name="File;;SEEK_SET;;File"/>
                                    		<Keyword name="File;;SEPARATOR"/>
                                    		<Keyword name="File;;SEPARATOR;;File"/>
                                    		<Keyword name="File;;SYNC"/>
                                    		<Keyword name="File;;SYNC;;File"/>
                                    		<Keyword name="File;;Separator"/>
                                    		<Keyword name="File;;Separator;;File"/>
                                    		<Keyword name="File;;Stat"/>
                                    		<Keyword name="File;;Stat;;File"/>
                                    		<Keyword name="File;;TRUNC"/>
                                    		<Keyword name="File;;TRUNC;;File"/>
                                    		<Keyword name="File;;WRONLY"/>
                                    		<Keyword name="File;;WRONLY;;File"/>
                                    ["ALT_SEPARATOR", "APPEND", "CREAT", "Constants", "EXCL", "FNM_CASEFOLD", "FNM_DOTMATCH", "FNM_NOESCAPE", "FNM_PATHNAME", "FNM_SYSCASE", "LOCK_EX", "LOCK_NB", "LOCK_SH", "LOCK_UN", "NOCTTY", "NONBLOCK", "PATH_SEPARATOR", "RDONLY", "RDWR", "SEEK_CUR", "SEEK_END", "SEEK_SET", "SEPARATOR", "SYNC", "Separator", "Stat", "TRUNC", "WRONLY"]
                                      Thanks Dan for posting this.
                                        Btw, I think I'll upload the list to BitBucket. I'll do that later today.
                                          Moved files into a BitBucket repository: https://bitbucket.org/thomthom/notepad-sketchup-autocomplete/
                                            Dan Rathbun
                                            Your first snip seems to bring up loads more methods than what your posting, ...
                                            "methods" ?? The snippet lists Constants. You mean this snippet ??
                                            @driven said:
                                            ... are you editing yours down?
                                            NO .. BUT the Errno module is created dynamically by Ruby at startup, and MAY DIFFERfrom platform to platform (ie, from one Operating System to another.)
                                            The count on the PC is 73 Constants within Errno module (pointing at SystemCallError exception subclass instances,) each of whom have a local constant Errno that wraps their private instance method errno(). SO a grandtotal of 146 module Errno constants on the PC.
                                            Just to be on the safe side.. and to be sure that Global Constants (defined in Object,) are not propagating into the Errno module, in Ruby 1.8.5 .... use the following snippet, and post the results here in a code box, please.
                                            (Errno.constants.sort-Object.constants.sort).each {|e| puts %Q[\t\t<Keyword name="Errno::#{e}"/>\n\t\t<Keyword name="Errno::#{e}::Errno"/>\n] }
                                            • 1 / 4
