    Notepad++ SU8 Ruby API Autocomplete
    62 Posts 12 Posters 18.1k Views 12 Watching
      Jim
      I only use Npp occasionally, but can test it out - what do i do with the file and how to I activate auto-complete?
        Added Install info in first post.
        • Dan RathbunD Offline
          Dan Rathbun
          @thomthom said:
          There appear to be something not working quite right. I'm not getting all the words in the suggestion list. For instance, it won't display "Sketchup" as a suggestion - despite it being there in the list.
          Auto Completion Wiki
          "The basic character set used to recognise keywords is made of letters a-z, A-Z, 0-9 digis and the underscore. You can add more characters ... by specifying he additionalWordChars parameter in the environment."
          So wouldn't we need a additionalWordChars=" .:" attribute in the Environment tag, to allow space, dot and colon (in Keywords) ??
          EDIT: add "=" to that list.
          I'm not here much anymore.
            Ah - good link. I was looking for a resource like that.
            Why you need dot colon in keywords?
            = Seem to work anyway. Space was already there.
            I made this definition so getters would be
            " materials.current"
            setters would be
            " materials.current ="
              Depending on the value of the 'ignoreCase' attribute in the 'Environment' element, the XML file has to be sorted case sensitive or case insensitive (if the attribute is absent it will default to case sensitive).
              Ah! Well that explains a few things!
                Dan Rathbun
                Just wondering if it was required so that the feature can lookup things correctly.
                  Dan Rathbun
                  More information on this link: Autocompletion, aka API, files, which says:
                  additionalWordChar: character(s) that may be part of words and which are not a lower or upper case letter, a digit or the underscore. The value is a string with all these extra characters, in any order and without separators. The string is empty by default.
                  EDIT .. more info from that page:
                  Names
                  For both call tips and autocompletion to work, keywords must be words, ie identifiers most languages would readily accept. This means that only the 26 Latin alphabet letters in either lower or upper case (no diacritics), digits and the underscore are safe to use. Additional allowed characters will work if they are not whitespace. Autocompletion may cope with spaces or blanks, call tips won't. This is a Scintilla limitation.
                    tomasz
                    Thank you!
                    Author of [Thea Render for SketchUp](http://www.thearender.com/sketchup)
                      Revision 3 - 01.02.2011
                      Rebuilt the list from scratch. Used only the classes and methods from Ruby 1.8.6 and SketchUp API. (The old file seemed to have lots of Ruby On Rails references.)
                        Dan Rathbun
                        Do you it's possible to have whole qualified classnames and constants in the AutoComplete?
                        Examples:
                        Math::PI
                        File::SEPARATOR
                        Sketchup::Drawingelement
                        UI::Toolbar
                        etc. ??
                          Dan Rathbun
                          I noticed in the old list certain entries did not work correctly where the module name followed the keyword in paranthesis. Notepad++ got confused and took them to be a parameter (argument) list.
                            Yes, it's possible. Some Ruby classes are listed like that. File for instance. (Just ripped it directly from the docs.)
                            Is there a list of available?
                            (I just ripped the class names and methods from the Ruby docs and SU docs - without further processing.) So constants and nesting is missing.
                              Dan Rathbun
                              @thomthom said:
                              These are the ones that caused problems (but the ver 3 does not have them.)
                                Dan Rathbun
                                Both ver 2, and the original (Didier's version?) have fully qualified classes that you can cut and paste from.
                                For constants we'll have to compile a list.
                                  @dan rathbun said:
                                  [attachment=0:ef22v8uz]<!-- ia0 -->old_NPP_autocomplete.png<!-- ia0 -->[/attachment:ef22v8uz]
                                  Oh! Didn't noticed that.
                                  Ah, yea. I did that manually for v2.
                                    Dan Rathbun
                                    Here's the 1.8.6 constant list for the Errno module, on the PC:
                                    For PC (note! OSX SystemCallError subclasses may differ.)
                                    		<Keyword name="Errno;;E2BIG"/>
                                    		<Keyword name="Errno;;E2BIG;;Errno"/>
                                    		<Keyword name="Errno;;EACCES"/>
                                    		<Keyword name="Errno;;EACCES;;Errno"/>
                                    		<Keyword name="Errno;;EADDRINUSE"/>
                                    		<Keyword name="Errno;;EADDRINUSE;;Errno"/>
                                    		<Keyword name="Errno;;EADDRNOTAVAIL"/>
                                    		<Keyword name="Errno;;EADDRNOTAVAIL;;Errno"/>
                                    		<Keyword name="Errno;;EAFNOSUPPORT"/>
                                    		<Keyword name="Errno;;EAFNOSUPPORT;;Errno"/>
                                    		<Keyword name="Errno;;EAGAIN"/>
                                    		<Keyword name="Errno;;EAGAIN;;Errno"/>
                                    		<Keyword name="Errno;;EALREADY"/>
                                    		<Keyword name="Errno;;EALREADY;;Errno"/>
                                    		<Keyword name="Errno;;EBADF"/>
                                    		<Keyword name="Errno;;EBADF;;Errno"/>
                                    		<Keyword name="Errno;;EBUSY"/>
                                    		<Keyword name="Errno;;EBUSY;;Errno"/>
                                    		<Keyword name="Errno;;ECHILD"/>
                                    		<Keyword name="Errno;;ECHILD;;Errno"/>
                                    		<Keyword name="Errno;;ECONNABORTED"/>
                                    		<Keyword name="Errno;;ECONNABORTED;;Errno"/>
                                    		<Keyword name="Errno;;ECONNREFUSED"/>
                                    		<Keyword name="Errno;;ECONNREFUSED;;Errno"/>
                                    		<Keyword name="Errno;;ECONNRESET"/>
                                    		<Keyword name="Errno;;ECONNRESET;;Errno"/>
                                    		<Keyword name="Errno;;EDEADLK"/>
                                    		<Keyword name="Errno;;EDEADLK;;Errno"/>
                                    		<Keyword name="Errno;;EDEADLOCK"/>
                                    		<Keyword name="Errno;;EDEADLOCK;;Errno"/>
                                    		<Keyword name="Errno;;EDESTADDRREQ"/>
                                    		<Keyword name="Errno;;EDESTADDRREQ;;Errno"/>
                                    		<Keyword name="Errno;;EDOM"/>
                                    		<Keyword name="Errno;;EDOM;;Errno"/>
                                    		<Keyword name="Errno;;EDQUOT"/>
                                    		<Keyword name="Errno;;EDQUOT;;Errno"/>
                                    		<Keyword name="Errno;;EEXIST"/>
                                    		<Keyword name="Errno;;EEXIST;;Errno"/>
                                    		<Keyword name="Errno;;EFAULT"/>
                                    		<Keyword name="Errno;;EFAULT;;Errno"/>
                                    		<Keyword name="Errno;;EFBIG"/>
                                    		<Keyword name="Errno;;EFBIG;;Errno"/>
                                    		<Keyword name="Errno;;EHOSTDOWN"/>
                                    		<Keyword name="Errno;;EHOSTDOWN;;Errno"/>
                                    		<Keyword name="Errno;;EHOSTUNREACH"/>
                                    		<Keyword name="Errno;;EHOSTUNREACH;;Errno"/>
                                    		<Keyword name="Errno;;EILSEQ"/>
                                    		<Keyword name="Errno;;EILSEQ;;Errno"/>
                                    		<Keyword name="Errno;;EINPROGRESS"/>
                                    		<Keyword name="Errno;;EINPROGRESS;;Errno"/>
                                    		<Keyword name="Errno;;EINTR"/>
                                    		<Keyword name="Errno;;EINTR;;Errno"/>
                                    		<Keyword name="Errno;;EINVAL"/>
                                    		<Keyword name="Errno;;EINVAL;;Errno"/>
                                    		<Keyword name="Errno;;EIO"/>
                                    		<Keyword name="Errno;;EIO;;Errno"/>
                                    		<Keyword name="Errno;;EISCONN"/>
                                    		<Keyword name="Errno;;EISCONN;;Errno"/>
                                    		<Keyword name="Errno;;EISDIR"/>
                                    		<Keyword name="Errno;;EISDIR;;Errno"/>
                                    		<Keyword name="Errno;;ELOOP"/>
                                    		<Keyword name="Errno;;ELOOP;;Errno"/>
                                    		<Keyword name="Errno;;EMFILE"/>
                                    		<Keyword name="Errno;;EMFILE;;Errno"/>
                                    		<Keyword name="Errno;;EMLINK"/>
                                    		<Keyword name="Errno;;EMLINK;;Errno"/>
                                    		<Keyword name="Errno;;EMSGSIZE"/>
                                    		<Keyword name="Errno;;EMSGSIZE;;Errno"/>
                                    		<Keyword name="Errno;;ENAMETOOLONG"/>
                                    		<Keyword name="Errno;;ENAMETOOLONG;;Errno"/>
                                    		<Keyword name="Errno;;ENETDOWN"/>
                                    		<Keyword name="Errno;;ENETDOWN;;Errno"/>
                                    		<Keyword name="Errno;;ENETRESET"/>
                                    		<Keyword name="Errno;;ENETRESET;;Errno"/>
                                    		<Keyword name="Errno;;ENETUNREACH"/>
                                    		<Keyword name="Errno;;ENETUNREACH;;Errno"/>
                                    		<Keyword name="Errno;;ENFILE"/>
                                    		<Keyword name="Errno;;ENFILE;;Errno"/>
                                    		<Keyword name="Errno;;ENOBUFS"/>
                                    		<Keyword name="Errno;;ENOBUFS;;Errno"/>
                                    		<Keyword name="Errno;;ENODEV"/>
                                    		<Keyword name="Errno;;ENODEV;;Errno"/>
                                    		<Keyword name="Errno;;ENOENT"/>
                                    		<Keyword name="Errno;;ENOENT;;Errno"/>
                                    		<Keyword name="Errno;;ENOEXEC"/>
                                    		<Keyword name="Errno;;ENOEXEC;;Errno"/>
                                    		<Keyword name="Errno;;ENOLCK"/>
                                    		<Keyword name="Errno;;ENOLCK;;Errno"/>
                                    		<Keyword name="Errno;;ENOMEM"/>
                                    		<Keyword name="Errno;;ENOMEM;;Errno"/>
                                    		<Keyword name="Errno;;ENOPROTOOPT"/>
                                    		<Keyword name="Errno;;ENOPROTOOPT;;Errno"/>
                                    		<Keyword name="Errno;;ENOSPC"/>
                                    		<Keyword name="Errno;;ENOSPC;;Errno"/>
                                    		<Keyword name="Errno;;ENOSYS"/>
                                    		<Keyword name="Errno;;ENOSYS;;Errno"/>
                                    		<Keyword name="Errno;;ENOTCONN"/>
                                    		<Keyword name="Errno;;ENOTCONN;;Errno"/>
                                    		<Keyword name="Errno;;ENOTDIR"/>
                                    		<Keyword name="Errno;;ENOTDIR;;Errno"/>
                                    		<Keyword name="Errno;;ENOTEMPTY"/>
                                    		<Keyword name="Errno;;ENOTEMPTY;;Errno"/>
                                    		<Keyword name="Errno;;ENOTSOCK"/>
                                    		<Keyword name="Errno;;ENOTSOCK;;Errno"/>
                                    		<Keyword name="Errno;;ENOTTY"/>
                                    		<Keyword name="Errno;;ENOTTY;;Errno"/>
                                    		<Keyword name="Errno;;ENXIO"/>
                                    		<Keyword name="Errno;;ENXIO;;Errno"/>
                                    		<Keyword name="Errno;;EOPNOTSUPP"/>
                                    		<Keyword name="Errno;;EOPNOTSUPP;;Errno"/>
                                    		<Keyword name="Errno;;EPERM"/>
                                    		<Keyword name="Errno;;EPERM;;Errno"/>
                                    		<Keyword name="Errno;;EPFNOSUPPORT"/>
                                    		<Keyword name="Errno;;EPFNOSUPPORT;;Errno"/>
                                    		<Keyword name="Errno;;EPIPE"/>
                                    		<Keyword name="Errno;;EPIPE;;Errno"/>
                                    		<Keyword name="Errno;;EPROTONOSUPPORT"/>
                                    		<Keyword name="Errno;;EPROTONOSUPPORT;;Errno"/>
                                    		<Keyword name="Errno;;EPROTOTYPE"/>
                                    		<Keyword name="Errno;;EPROTOTYPE;;Errno"/>
                                    		<Keyword name="Errno;;ERANGE"/>
                                    		<Keyword name="Errno;;ERANGE;;Errno"/>
                                    		<Keyword name="Errno;;EREMOTE"/>
                                    		<Keyword name="Errno;;EREMOTE;;Errno"/>
                                    		<Keyword name="Errno;;EROFS"/>
                                    		<Keyword name="Errno;;EROFS;;Errno"/>
                                    		<Keyword name="Errno;;ESHUTDOWN"/>
                                    		<Keyword name="Errno;;ESHUTDOWN;;Errno"/>
                                    		<Keyword name="Errno;;ESOCKTNOSUPPORT"/>
                                    		<Keyword name="Errno;;ESOCKTNOSUPPORT;;Errno"/>
                                    		<Keyword name="Errno;;ESPIPE"/>
                                    		<Keyword name="Errno;;ESPIPE;;Errno"/>
                                    		<Keyword name="Errno;;ESRCH"/>
                                    		<Keyword name="Errno;;ESRCH;;Errno"/>
                                    		<Keyword name="Errno;;ESTALE"/>
                                    		<Keyword name="Errno;;ESTALE;;Errno"/>
                                    		<Keyword name="Errno;;ETIMEDOUT"/>
                                    		<Keyword name="Errno;;ETIMEDOUT;;Errno"/>
                                    		<Keyword name="Errno;;ETOOMANYREFS"/>
                                    		<Keyword name="Errno;;ETOOMANYREFS;;Errno"/>
                                    		<Keyword name="Errno;;EUSERS"/>
                                    		<Keyword name="Errno;;EUSERS;;Errno"/>
                                    		<Keyword name="Errno;;EWOULDBLOCK"/>
                                    		<Keyword name="Errno;;EWOULDBLOCK;;Errno"/>
                                    		<Keyword name="Errno;;EXDEV"/>
                                    		<Keyword name="Errno;;EXDEV;;Errno"/>
                                    output via: Ruby console and type (one-liner):
                                    Errno.constants.sort.each {|e| puts %Q[\t\t<Keyword name="Errno::#{e}"/>\n\t\t<Keyword name="Errno::#{e}::Errno"/>\n] }
                                    Then copy and paste into the ruby.xml file for Notepad++
                                      Dan Rathbun
                                      Here's the 1.8.6 constant list for the File module:
                                      		<KeyWord name="File;;ALT_SEPARATOR"/>
                                      		<KeyWord name="File;;APPEND"/>
                                      		<KeyWord name="File;;BINARY"/>
                                      		<KeyWord name="File;;CREAT"/>
                                      		<KeyWord name="File;;Constants;;APPEND"/>
                                      		<KeyWord name="File;;Constants;;BINARY"/>
                                      		<KeyWord name="File;;Constants;;CREAT"/>
                                      		<KeyWord name="File;;Constants;;EXCL"/>
                                      		<KeyWord name="File;;Constants;;FNM_CASEFOLD"/>
                                      		<KeyWord name="File;;Constants;;FNM_DOTMATCH"/>
                                      		<KeyWord name="File;;Constants;;FNM_NOESCAPE"/>
                                      		<KeyWord name="File;;Constants;;FNM_PATHNAME"/>
                                      		<KeyWord name="File;;Constants;;FNM_SYSCASE"/>
                                      		<KeyWord name="File;;Constants;;LOCK_EX"/>
                                      		<KeyWord name="File;;Constants;;LOCK_NB"/>
                                      		<KeyWord name="File;;Constants;;LOCK_SH"/>
                                      		<KeyWord name="File;;Constants;;LOCK_UN"/>
                                      		<KeyWord name="File;;Constants;;NONBLOCK"/>
                                      		<KeyWord name="File;;Constants;;RDONLY"/>
                                      		<KeyWord name="File;;Constants;;RDWR"/>
                                      		<KeyWord name="File;;Constants;;TRUNC"/>
                                      		<KeyWord name="File;;Constants;;WRONLY"/>
                                      		<KeyWord name="File;;EXCL"/>
                                      		<KeyWord name="File;;FNM_CASEFOLD"/>
                                      		<KeyWord name="File;;FNM_DOTMATCH"/>
                                      		<KeyWord name="File;;FNM_NOESCAPE"/>
                                      		<KeyWord name="File;;FNM_PATHNAME"/>
                                      		<KeyWord name="File;;FNM_SYSCASE"/>
                                      		<KeyWord name="File;;LOCK_EX"/>
                                      		<KeyWord name="File;;LOCK_NB"/>
                                      		<KeyWord name="File;;LOCK_SH"/>
                                      		<KeyWord name="File;;LOCK_UN"/>
                                      		<KeyWord name="File;;NONBLOCK"/>
                                      		<KeyWord name="File;;PATH_SEPARATOR"/>
                                      		<KeyWord name="File;;RDONLY"/>
                                      		<KeyWord name="File;;RDWR"/>
                                      		<KeyWord name="File;;SEEK_CUR"/>
                                      		<KeyWord name="File;;SEEK_END"/>
                                      		<KeyWord name="File;;SEEK_SET"/>
                                      		<KeyWord name="File;;SEPARATOR"/>
                                      		<KeyWord name="File;;Separator"/>
                                      		<KeyWord name="File;;TRUNC"/>
                                      		<KeyWord name="File;;WRONLY"/>
                                        Dan Rathbun
                                        Here's the 1.8.6 constant list for the Float class:
                                        		<Keyword name="Float;;DIG"/>
                                        		<Keyword name="Float;;EPSILON"/>
                                        		<Keyword name="Float;;MANT_DIG"/>
                                        		<Keyword name="Float;;MAX"/>
                                        		<Keyword name="Float;;MAX_10_EXP"/>
                                        		<Keyword name="Float;;MAX_EXP"/>
                                        		<Keyword name="Float;;MIN"/>
                                        		<Keyword name="Float;;MIN_10_EXP"/>
                                        		<Keyword name="Float;;MIN_EXP"/>
                                        		<Keyword name="Float;;RADIX"/>
                                        		<Keyword name="Float;;ROUNDS"/>
                                          Dan Rathbun
                                          Here's the 1.8.6 constant list for the IO class:
                                          		<Keyword name="IO;;APPEND"/>
                                          		<Keyword name="IO;;BINARY"/>
                                          		<Keyword name="IO;;CREAT"/>
                                          		<Keyword name="IO;;EXCL"/>
                                          		<Keyword name="IO;;FNM_CASEFOLD"/>
                                          		<Keyword name="IO;;FNM_DOTMATCH"/>
                                          		<Keyword name="IO;;FNM_NOESCAPE"/>
                                          		<Keyword name="IO;;FNM_PATHNAME"/>
                                          		<Keyword name="IO;;FNM_SYSCASE"/>
                                          		<Keyword name="IO;;LOCK_EX"/>
                                          		<Keyword name="IO;;LOCK_NB"/>
                                          		<Keyword name="IO;;LOCK_SH"/>
                                          		<Keyword name="IO;;LOCK_UN"/>
                                          		<Keyword name="IO;;NONBLOCK"/>
                                          		<Keyword name="IO;;RDONLY"/>
                                          		<Keyword name="IO;;RDWR"/>
                                          		<Keyword name="IO;;SEEK_CUR"/>
                                          		<Keyword name="IO;;SEEK_END"/>
                                          		<Keyword name="IO;;SEEK_SET"/>
                                          		<Keyword name="IO;;TRUNC"/>
                                          		<Keyword name="IO;;WRONLY"/>
                                            Dan Rathbun
                                            Here's the 1.8.6 constant list AND class methods for the Marshal module:
                                            		<Keyword name="Marshal;;MAJOR_VERSION"/>
                                            		<Keyword name="Marshal;;MINOR_VERSION"/>
                                            		<Keyword name="Marshal;;dump" func="yes">
                                            			<Overload retVal="String" descr="Returns String result of serializing obj and all descendent objects.">
                                            				<Param name="~Object obj" />
                                            			</Overload>
                                            			<Overload retVal="~IO" descr="Returns io_obj, after writing to it, the serialized data for obj and all descendent objects.">
                                            				<Param name="~IO io_obj" />
                                            			</Overload>
                                            			<Overload retVal="~IO" descr="Returns io_obj, after writing to it, the serialized data for obj and the descendent objects limited to the specified depth (if non-negative. Default depth=-1)">
                                            				<Param name="~Integer depth" />
                                            			</Overload>
                                            		</KeyWord>
                                            		<Keyword name="Marshal;;load" func="yes">
                                            			<Overload retVal="~Object" descr="Returns the result of converting the serialized data in source into a Ruby object (possibly with associated subordinate objects). source may be either an instance of IO or an object that responds to to_str().">
                                            				<Param name="~IO|^String source" />
                                            			</Overload>
                                            			<Overload retVal="~Object" descr="Returns the result of converting the serialized data in source into a Ruby object (possibly with associated subordinate objects). source may be either an instance of IO or an object that responds to to_str(). If proc_obj is specified, it will be passed each object as it is deserialized.">
                                            				<Param name="Proc proc_obj" />
                                            			</Overload>
                                            		</KeyWord>
                                            		<Keyword name="Marshal;;restore" func="yes">
                                            			<Overload retVal="~Object" descr="Alias for Marshal;;load() Returns the result of converting the serialized data in source into a Ruby object (possibly with associated subordinate objects). source may be either an instance of IO or an object that responds to to_str().">
                                            			</Overload>
                                            			<Overload retVal="~Object" descr="Alias for Marshal;;load() Returns the result of converting the serialized data in source into a Ruby object (possibly with associated subordinate objects). source may be either an instance of IO or an object that responds to to_str(). If proc_obj is specified, it will be passed each object as it is deserialized.">
                                            			</Overload>
                                            		</KeyWord>
                                            As an experiment, in parameters, I used:
                                            "~" to denote "this class or subclass"
                                            "^" to denote "implictly convertable to" (which would include the class and any subclasses.)
                                            for ex: ^Integer would mean: " Integer class, subclass, or object that implements a to_i() method."
                                            • 1 / 4
