    1.5k Posts 471 Posters 3.3m Views 470 Watching
      jmaher
      I think it will help if you could post the model.
      Fredo,
      I'd be grateful if you'd take a look.
      Thanks,
      j
      Arm and portion to be rounded
      • N Offline
        natush
        Thank you!!
        I reinstalled SketchUp8, and placed all folders into recommended folders and activated "rounded Corners" from Profiles. Now it works!!!
        Thank you very much!!!!
          theskulstudio
          Thank you very much
          • fredo6F Offline
            Jim,
            I could round the 2 faces of the arm model without problem and in less than 10 seconds. I used 6 segments and 0.4 cm offset (sorry, I am not comfortable with fractional inches).
            The few issues in the generated model comes from the too high sampling of the curved sections and some transverse edges. So you probably need to do some clean up. But overall, I could not reproduce the hang situation you described.
            Did you select the whole model (I mean all edges) or just the two lateral faces?
            Arm2 Rredo.skp
              jmaher
              Fredo,
              I selected just the two lateral faces. In fact, I tried doing each face separately.
              Clearly, the problem is with me. I'll go back to the drawing, do some clean up, and practice until I get it right.
              In the meantime, I'll use your result to continue with my design.
              Thanks so much!
              j
              • F Offline
                Frommer1
                i need help loading the plugin i downloaded everything as stated, but when i open sketchup, nothing is there how do i load the plugin?
                • Bob JamesB Offline
                  Bob James
                  See the directions on page 1 of this post: welcome to SketchUcation 😄
                  • F Offline
                    Frommer1
                    i am trying to round over the edges of a circle that is through a rectangle, as if you cut a hole in a piece of wood and then rounded the edges over. How do i do it. evertime i try it just closes the circle
                    • F Offline
                      Frommer1
                      I did and it still doesnt work on my laptop. I even erased the files and tried again. Any ideas. i was able to sucessfully load the plugin on a different computer however.
                        Since it creates new geometry, I can imagine that those faces also are created automatically. What happens if you delete the circle(s)? Is the rounded edge there underneath?
                        • F Offline
                          Frommer1
                          it appears to go away completely, as if it were never there
                            Could you attach the file,please? (Maybe a "before" and an "after" version of the same geometry in it)
                            • mitcorbM Offline
                              mitcorb
                              Could it be automatically re-skinning? Perhaps select the closed surface face and press Delete? Or turn on xray to see if the rounding has actually been done. I am guessing here.
                              • W Offline
                                watkins
                                Has anyone had any problems running Round Corners under SU8. The icons are showing, but I cannot seem to get it working. Which version is now considered SU8 friendly? I am building up my SU8 plugin folder slowly, and so I have very few plugins loaded, and mostly those of Fredo6.
                                  Bob James
                                  I use this quite often to round the edges of holes. It is normal for the hole to be "filled", but when you delete the new "filled" area, your are left with the hole with rounded edges.
                                    Yes, that's what I'd expect, too. Unless the hole is too tiny and the edges of the rounded corner would be less that that 1 mm / 1/16" limit (in which case they might be simply gone and you need to use the scale-up workaround)
                                    • F Offline
                                      Frommer1
                                      Here is is. i tried rounding the corners on the left hole and it is gone. the hole on the right is untouched. Please help! i tried erasing the center and the only way it shows up is if i delete some lines on the roundover
                                      test hole.skp
                                        Bob James
                                        I clicked on the area where the left hole should be. It was "filled in" as evidenced by the blue dots. I then deleted the "blue dot" area and was left with a rounded edge hole as expected.
                                          Yeah, it just fills the hole but you can delete the fill easily.
                                          However in the file, the round radius was set to 7' 7/8". I figured that about 3/8" is the max "desired" radius so you may want to revise that.
                                          delete this
                                          end up with this
                                          • fredo6F Offline
                                            @frommer1 said:
                                            I tried rounding the corners on the left hole and it is gone. the hole on the right is untouched. Please help! i tried erasing the center and the only way it shows up is if i delete some lines on the roundover
                                            As pointed out by Bob James and Gaieus, the rounding took place, but Sketchup automatically created a face when RoundCorner build the edges of the rounding.
                                            This may happen in those situations, and actually not easy to detect and correct.
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 73
                                            • 74
                                            • 19 / 74
