    Opening giant sketchup file
    3 Posts 3 Posters 480 Views 3 Watching
      davesec
      hi!
      so i had a sketchup file that was about 175kb. i added a bunch of materials/components/etc and the filesize jumped to about 57mb. i can't even open it now.. i think it might be because i installed vray.. is there some way i can open this stupid file or reduce it's size in a 'sketchup lite' or 'sketchup safe' mode or something so that i can open it and get rid of the materials? would rather not uninstall vray if possible!
      • T
        trouvetout
        This is not that giant you know; I frequently work on files that are twice this size.
        Many different things could provoke that behavior though, first troubleshoot method would be to do the following:
        1. Open sketchup (new file, not your big file)
        2. disable VRay plugin (go to window/preferences/extensions/ and there, uncheck the Vray plugin).
        3. Close the program.
        Now try to open your big file again and see if it opens up.
          SketchUpNoobie
          And once you get it open, you can go to Window > Model Info > Statistics > Purge Unused. That should drop your file size by quite a bit especially with a large file.
          SketchUpNoobie: the complete noob in all things SketchUp.
