    Keep WebDialog in front on XP/Vista?
    10 Posts 6 Posters 485 Views 6 Watching
      jeemang
      Very simple question: does anyone know how to keep a WebDialog in front of the other Sketchup windows on XP/Vista? I know this can be accomplished in OSX using WebDialog.show_modal, but I'm not aware of a good way to accomplish this on other platforms.
      Any help would be much appreciated.
      Josh
        dlg.show_modal{code_block}
        should work on PC
          Josh
          Just using .show should work. Under windows WebDialogs are always on top of it's owner Sketchup window.
          .show_modal is really for making modal windows, but under osx it doesn't work properly. But OSX has the quirk that WebDialogs doesn't normally stay on top if you use .show - but it will stay on top when you use .show_modal.
            On a PC dlg.show{} and dlg.show_modal{} will both produce a dialog in front of the Sketchup window... BUT on a PC the 'show' version although it stays 'on top' it lets you deactivate and/or minimize it and activate the SKP window and work on that instead; whereas the 'modal' version demands that you enter data and OK/Close before returning to the SKP window as it becomes the active front window that cannot be deactivated, but only closed.
            • Dan RathbunD Offline
              Dan Rathbun
              Given your WebDialog instance var as dlg
              one-liner:
              <span class="syntaxdefault">RUBY_PLATFORM</span><span class="syntaxkeyword">.include?(</span><span class="syntaxstring">'darwin'</span><span class="syntaxkeyword">)</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">?</span><span class="syntaxdefault"> dlg</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">show_modal</span><span class="syntaxkeyword">()</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">;</span><span class="syntaxdefault"> dlg</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">show</span><span class="syntaxkeyword">()</span><span class="syntaxdefault"> </span>
              I'm not here much anymore.
                todd burch
                In my tools, I use this:
                if !@wd.visible?    # get the dialog back
                	@wd.show()
                else
                	@wd.bring_to_front()
                  driven
                  morning,
                  I'm just wondering, can you have a conditional .show{} in your loader tool button, so that the first time you click, it creates the WD but subsequent clicks will just bring it forward i.e. show_modal..
                  occasionally, I end up with 5 or 6 copies of the same WD under my drawing...
                  and if you can do that, could you use it with a modify key to switch between show or show_modal... rather than closing something thats in the way, eg. WedConsole
                  maybe with a conditional tooltip...
                  probably only useful on a mac....
                  ADD: or maybe a version of Todd's would work?
                    I use something similar:
                    <span class="syntaxdefault">def self</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">show_window</span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> window </span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">  if window</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">visible<br />    window</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">bring_to_front<br />  else<br />    if RUBY_PLATFORM</span><span class="syntaxkeyword">.include?(</span><span class="syntaxstring">'darwin'</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">      window</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">show_modal </span><span class="syntaxcomment"># To keep window on top of SU on OSX<br /></span><span class="syntaxdefault">    else<br />      window</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">show<br />    end<br />  end<br />end </span><span class="syntaxcomment"># def&nbsp;</span><span class="syntaxdefault"></span>
                      I'm using a wrapper over WebDialog - subclassed it. http://www.thomthom.net/software/sketchup/tt_lib2/doc/TT/GUI/Window.html
                        jeemang
                        Wowsers, thanks for all the responses. Question answered!
