    Add_group( entity ) weirdness
    9 Posts 4 Posters 725 Views 4 Watching
      g1 = model.selection[0] < group with set of faces
      face = g1.entities.find { |e| e.is_a?(Sketchup::Face) } < fetch a face in g1
      face.material = 'red'
      face.back_material = 'green' <- Highlight the face for debugging
      g2 = g1.entities.add_group( face ) <- group the face
      This causes the face to appear to have been shifted to the origin of g1 - instead of preserving it's original position.
      On top of that - there appear to be a face also in the top context - it's even selectable. While g1 doesn't let you select any groups.
      It seem completely messed up. I tried Fix Problems - but it reported no errors.
      What is going on?
        Jim
        I got the same results - screwy.
          Even weirder... the original face and the one in the group are the same and select together.
          Now try exploding the new group.
          The new face from the exploded group stays where it was [wrongly located] with edges BUT the original face [in the wrong place] now has no edges except those that have appeared where it was originally ! The exploded face is also now outside of the original group!
          The entities.add_group(face_in_entities) should work πŸ˜•
          Cross-threading entities contexts causes splats but not with this simple way.
          My 'Mirror' tool does something very similar - you'd select the face that is within the group and mirror it, it'd be temporarily grouped and an instance of that temporary group inserted and transformed in the same entities so it is mirrored: you then choose to erase the original selection [original temporary group is erased and copy group exploded] or to keep the original [both groups are exploded].
          I've just tested Mirror and it works fine... it is doing almost the same thing ?
          BUT there is a difference - the difference is that you are within the group's entities when selecting and mirroring the face so that the newly grouped-face stays in the right 'context' of the active_entities... If you do thomthom's 'steps' BUT just before creating the new face-group you manually edit the enclosing group so that the active_entities changes to be the group.entities, then all is well!
          So it seems that entities.add_group(face_in_entities) WILL work IF the entities are the model.active_entities - OK if you are selecting stuff first within a context, because they will then be [unless you close the edit] but as you can't ' set' the model.active_entities within the API we're knacked if selecting an object outside of the active_entities... The only way to do this safely is to check is the entities==model.active_entities - if == you can use entities.add_group(face) BUT if not you must clone the face and erase the original -
          ` entities=g1.entities
          'face' got as before
          pts=[]
          face.vertices.each{|v|pts << v.position}
          g2=entities.add_group()
          nface=g2.entities.add_face(pts)
          fmat=face.material
          bmat=face.back_material
          layr=face.layer
          etc ### you could also clone the face attributes if it has any...
          you could also clone the face.edges material/layer/attributes for completeness...
          nface.material=fmat
          nface.back_material=bmat
          nface.layer=layr
          etc for attributes if necessary or to match the edges properties too...
          face.erase!
          face=nface`
          We now now have 'cloned' the face from inside of g1 and put it into g2, and erased the original.
          What a faff! πŸ˜’
            Not that easy - faces can have holes in them.
            I did make a method that will first recreate the face by taking the outer loop vertices, and then iterate over the remaining loops and create a face - then remove it. But I then ran into cases where SU claimed loop vertices where not planar (?!?) . x_X
              I successfully use the face-clone method in some of my tools - even for faces with holes.
              Get the face.outer_loop.vertices positions and make the cloned face ' nface' then use (face.loops-[face.outer_loop]).each{|loop|...} to make the inner face-holes from loop.vertices positions - e.g. tface=g2.entities.add_face(pts) then immediately remove that face tface.erase! to leave the inner_loop for the nface...
              Now you have cloned the 'face' as 'nface' with all of the required holes in it.
                yea, it was due to the face being pretty much a point that cause my errors.
                • K
                  kwalkerman
                  This is the same bug I detailed here:
                  404 Not Found
                  (forums.sketchucation.com)
                    duh! I even participated in that thread. yay for human memory!
                    • K
                      kwalkerman
                      hmm im somewhat confuses here-why did the face appear to have been shifted to the origin of g1 - instead of preserving it's original position?
                      I think that there is a problem somehow with the transformation of the objects. Following my instructions in the other post:
                      404 Not Found
                      the end result is that in the outliner, a group is added to Sketchup.active_model.entities. The transformation of the group is equal to the transformation of the original face in it's original group.
                      Then, when you open the original group for editing, the face appears in its original location.
                      So, there are two major problems:
                      1. when passing entities into entities.add_group, entities MUST equal model.active_entities
                      2. the entities passed in retain their original transformation, relative to the previous entities collection, with some strange behavior.
                      Karen
