🔌 Quick Selection | Try Didier Bur's reworked classic extension that supercharges selections in SketchUp Download
Variable problem
11 Posts 3 Posters 261 Views 3 Watching
    chrisglasier
    Please would someone be kind enough to show me how to sort out this snippet?
    def kf(time)
    keyframes = {}
    model = Sketchup.active_model
    d = model.attribute_dictionaries['kframes']
    d.each_pair do | key,value |
    a =  1
    value.each do | v |
    if v.nil?
    v = [[1,0,0],0]
    v << time * a
    a += 1
    keyframes[key] = value
    return keyframes
    When I puts the v's all are correct, but value returns the previously nil v' s to nil. Just cannot see why!
      It doesn't work as you expect because you are not changing the content of the array. You're dealing with a local copy.
      I changed your loop to use .map - that should work. (untested)
      <span class="syntaxdefault"><br />def kf</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">time</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">  keyframes </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">{}<br /></span><span class="syntaxdefault">  model </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_model<br />  d </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">attribute_dictionaries</span><span class="syntaxkeyword">[</span><span class="syntaxstring">'kframes'</span><span class="syntaxkeyword">]<br /></span><span class="syntaxdefault">  d</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">each_pair do </span><span class="syntaxkeyword">|</span><span class="syntaxdefault"> key</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">value </span><span class="syntaxkeyword">|<br /></span><span class="syntaxdefault">    a </span><span class="syntaxkeyword">=</span><span class="syntaxdefault">  1<br />    value</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">map do </span><span class="syntaxkeyword">|</span><span class="syntaxdefault"> v </span><span class="syntaxkeyword">|<br /></span><span class="syntaxdefault">      if v</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">nil</span><span class="syntaxkeyword">?<br /></span><span class="syntaxdefault">        v </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">[[</span><span class="syntaxdefault">1</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">],</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">]<br /></span><span class="syntaxdefault">      end<br />      v </span><span class="syntaxkeyword"><<</span><span class="syntaxdefault"> time </span><span class="syntaxkeyword">*</span><span class="syntaxdefault"> a<br />      a </span><span class="syntaxkeyword">+=</span><span class="syntaxdefault"> 1<br />      v<br />    end<br />    keyframes</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">key</span><span class="syntaxkeyword">]</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> value<br />  end<br />  return keyframes<br />end<br /></span>
        chrisglasier
        @thomthom said:
        It doesn't work as you expect because you are not changing the content of the array. ....
        Thanks but I am sorry to say it doesn't work at all.
        Also my original code successfully adds the time to each ( v) array, it only seems the nil block is being ignored by value.
        So I don't know ...
          chrisglasier
          .... but map does work if there aren't any nil elements in the value arrays.
            sorry, should be .map!
            @chrisglasier said:
            Also my original code successfully adds the time to each (v) array, it only seems the nil block is being ignored by value.
            Yes, because nil is immutable.
              value.each do | v |
              if v.nil?
                v = [[1,0,0],0]
              v << time * a
              a += 1
              looks through the contents of 'value' and assigns some values to elements in array 'v', then it sets the keyframes[key] back to be value ???
              Don't you want to modify 'key'?
              Why don't you use keyframes[key] = v ???
                chrisglasier
                @tig said:
                value.each do | v |
                > if v.nil?
                >   v = [[1,0,0],0]
                > end
                > v << time * a
                > a += 1
                > end
                > end
                Value is an array of arrays (like [[1,0,0],0]). So v is one of those. I am sure it is caused by the nil block? (immutable??). Perhaps I should make a new array from the v's because they are OK.
                I will try that later or tomorrow.
                Thanks for your help.
                  In which case
                    new_value = []
                    value.each do | v |
                      if v ### ??? ### isn't this what you want ?***
                        v << time * a
                      else ### OR it's nil
                        v = [[1,0,0],0]
                      end ### ***if NOT then revert to your format...
                      new_value << v
                      a += 1
                      keyframes[key] = new_value
                    chrisglasier
                    @tig said:
                    In which case
                    >   new_value = []
                    >   value.each do | v |
                    >       v << time * a
                    >       v = [[1,0,0],0]
                    >     new_value << v
                    >     a += 1
                    >   end
                    >   end
                    Yes that looks good;I guess I can use v.is_a?(Array) for the if bit as the nil candidates are just empty elements.
                    Thanks to you both ...
                      if v returns true if v is not nil or not []
                      The else then takes it's 'converse' i.e. it is nil OR []
                      I'm not clear about how a good or bad entry for 'value >>> v' might actually 'look' in your code...
                        chrisglasier
                        <span class="syntaxdefault">new_value </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">[]<br /></span><span class="syntaxdefault">            value</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">each do</span><span class="syntaxkeyword">|</span><span class="syntaxdefault"> v </span><span class="syntaxkeyword">|<br /></span><span class="syntaxdefault">                if </span><span class="syntaxkeyword">!</span><span class="syntaxdefault">v</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">is_a</span><span class="syntaxkeyword">?(Array)<br /></span><span class="syntaxdefault">                    v </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">[[</span><span class="syntaxdefault">1</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">],</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">]<br /></span><span class="syntaxdefault">                end<br />                v </span><span class="syntaxkeyword"><<</span><span class="syntaxdefault"> time </span><span class="syntaxkeyword">*</span><span class="syntaxdefault"> a<br />                a </span><span class="syntaxkeyword">+=</span><span class="syntaxdefault"> 1<br />                new_value </span><span class="syntaxkeyword"><<</span><span class="syntaxdefault"> v<br />            end<br />            keyframes</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">key</span><span class="syntaxkeyword">]</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> new_value</span>
                        I did it like this in the end as both types of v have time added. Anyway it works which is good! Thanks again.
                        The empty elements currently are needed to delay certain rotations - like a kick at the end of a run. I have a mechanism to modularise the animation. I want to leave that until later.
