    Trouble rendering 2.5D trees
    33 Posts 9 Posters 8.4k Views 9 Watching
    • EdsonE
      Edson
      tom,
      the whole thing is really weird. perhaps the problem shown in the second image I posted has to do with not having made each copy of the tree unique.
      are you using podium 1.7 or 2?
      I am patiently rendering each of your trees individually to see what happens. so far, no problems.
      http://www.mahfuz.arq.br
      • T
        tomsdesk
        Edson...podium 1.7: I didn't see a demo for V2
        2.5D Trees & Shrubs!
        • N
          notareal
          From Thea... what I seen 2.5D trees usually work fine. Just export and render.
          • F
            FilipAGuy
            Hello guys.
            I want to buy some of TOM´s tree packs, so I tryed to render samples posted
            on this forum with Podium V2 (2.02). And I got very similar results as Edson.
            rendered model as it comes
            rendered model in clay mode (no textures)
            Than I tryed to explode model. I exploded model completly, but wasnt working
            also. Only option which left was "unhide".
            rendered model exploded + unhide
            Only problem now is that model is not rotating anymore. I gonna try other samples.
            ASUS G73JH-A1 (ASUS G73JH-TZ002Z) i7-720 QM, RAM 8GB DDR3 1333 MHz, HDD 1TB (2x 500GB 7200 rpm), Blu-ray Combo, ATI Radeon HD 5870 1GB
            • EdsonE
              Edson
              perhaps you are exploding the images incorrectly. I suggest you go to tom's page at Solo's Place, scroll down the page and read his instructions.
              • T
                tomsdesk
                These trees don't need exploding...looks like you have "rendering" set to "use AA textures"...?
                see here: http://forums.sketchucation.com/viewtopic.php?f=40&t=32842&p=295990#p292038
                • F
                  FilipAGuy
                  [attachment=0:1w60mhgz]<!-- ia0 -->0renderingAAoff.jpg<!-- ia0 -->[/attachment:1w60mhgz]
                  I rendered without AA turned on and result is still same. Sorry guys Im just real noob in this. Im
                  sure that is my fault. Trying to render again. 😄
                  Edit: So I need to explode which part of tree to run it properly ? Without exploding whole model it doesnt work for me.
                  At this moment Im realy stucked with all. SketchUp and Podium.Maybe I need vacation 😕 😞
                  • T
                    tomsdesk
                    Again, no exploding necessary...it's looking like this issue is only with the newest version of podium: what do the podium guys say?
                    • C
                      clayc54
                      i completely missed the extension of this thread! thanks for trying out the render options.
                      ive posted this thread in the podium forum to see if anyone knows why v2 is producing those results.
                      • bigstickB
                        bigstick
                        Guys,
                        The best place for this kind of discussion is the Podium forum, you would have got a definitive answer a long time ago.
                        As a rule, the team don't follow Podium discussions on other forums, I only found this because clay posted a link on our site.
                        This is the long-standing textured components issue that has been plaguing us for some time. We are working on it, but until we get a fix, the solution is to explode the components. Generally you can regroup/recomponentise them afterwards.
                        We do have a V2 trial version 😄
                        • 2 / 2
