    Ordering 3dpoints ?
    36 Posts 8 Posters 6.0k Views 8 Watching
    • Dan RathbunD
      Dan Rathbun
      Although == is often overriden in custom subclasses (to do type conversion etc.,) .eql?() is usually not overriden, and retains the original finctionality of the == inherited from the superclass.
      Also .equal?() is NEVER overriden! (It's a really big no no.)
      I'm not here much anymore.
        Jim
        moved - ot.
        • Dan RathbunD
          Dan Rathbun
          @didier bur said:
          Here is my snippet for coplanarity test of 4 points (can be extended to any number of points):
          # Given a set of 4 3dPoints, return true if coplanar, or false
          > 	def quadPointsCoplanar?(pArray)
          > 		return (Geom.fit_plane_to_points(pArray[0],pArray[1],pArray[2]).isEqual?(Geom.fit_plane_to_points(pArray[0],pArray[1],pArray[3])))
          > 	end
          Will this work to simplify things ?
          <span class="syntaxdefault"></span><span class="syntaxcomment"># Given a set of 4 3dPoints, return true if coplanar, or false<br /></span><span class="syntaxdefault">    def quadPointsCoplanar</span><span class="syntaxkeyword">?(</span><span class="syntaxdefault">pArray</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">        return </span><span class="syntaxkeyword">(</span><span class="syntaxdefault">Geom</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">fit_plane_to_points</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">pArray</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">],</span><span class="syntaxdefault">pArray</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">1</span><span class="syntaxkeyword">],</span><span class="syntaxdefault">pArray</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">2</span><span class="syntaxkeyword">]).</span><span class="syntaxdefault">eql</span><span class="syntaxkeyword">?(</span><span class="syntaxdefault">Geom</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">fit_plane_to_points</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">pArray</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">],</span><span class="syntaxdefault">pArray</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">1</span><span class="syntaxkeyword">],</span><span class="syntaxdefault">pArray</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">3</span><span class="syntaxkeyword">])))<br /></span><span class="syntaxdefault">    end</span>
          I have no problem on Ruby 1.8.6 comparing floats that are very close:
          1.0000000001 == 1.0000000002 false 1.0000000001 == 1.0000000001 true
          • fredo6F
            I don't think eql? or any float comparison method would work, because the plane defined by [a0, a1, a2, a3] is the same as the one defined by [2 * a0, 2 * a1, 2 * a2, 2 * a3] or any other multiplying factor.
            It may be however that Geom.fit_plane_to_points normalizes the returned array, but it is not sure.
            So to be on the safe side, both for the precision and for the comparison, I would recommend to compare the planes A[a0, a1, a2, a3] and B[b0, b1, b2, b3] by:
            • checking if their normals [a0, a1, a2] and [b0, b1, b2] are parallel. SU will answer true or false taking into account the float precision
            • checking if the first point in the set of points is located on the second plane B.
            So, in Dider's example:
               planeA = Geom.fit_plane_to_points pArray[0], pArray[1], pArray[2]
               planeB = Geom.fit_plane_to_points pArray[1], pArray[2], pArray[3]
               normalA = Geom;;Vector3d.new *planeA[0..2]
               normalB = Geom;;Vector3d.new *planeB[0..2]
               normalA.parallel?(normalB) && pArray[0].on_plane?(planeB)
            Now for 4 points which are different and non-aligned, it is of course easier to do
                pArray[3].on_plane?(planeA)
            PS to Dan: very instructive your tuto on subclassing, really! Thanks.
            • Didier BurD
              Didier Bur
              @Dan:
              No, it doesn't work.
              @all: OK for not adding methods to base classes or SU classes. Module/sub-module stuffs are annoying to code (although the mixin mecanism is fun...) but far more secure.
              @tt: your Graham's scan works on every common or horizontal face, but not on vertical faces (I mean sets of 4 points that are in a main vertical plane (red-blue), (green-blue), see pic. I suppose that this is due to points having same X and same Y are not sorted correctly. I've tried to apply a transformation to each point before sorting, and apply the inverse transformation after, but no luck.
              This transformation was taking the normal of the plane of the 4 points as the Z axis, so the 4 points were virtually in a horizontal plane to be correctly handled by Graham, which is '2D'.)
              DB
              • Dan RathbunD
                Dan Rathbun
                @didier bur said:
                and finaly requires a constant
                Math.const_set("EPSILON", 1.0e-10)
                I am not sure I agree with this... I do like constants defined in a module that makes sense.
                However... is this constant only to be used by your plugin, Didier ?
                If so, it needs to be defined inside your plugin submodule, not a Ruby Core module.
                If it is to be used by more than one of your plugins, then it should be defined just inside your toplevel module.
                Never define global constants that are really your own private constants.
                If you wish.. you can create your own Math submodule but it must be defined as Didier::Math or whatever your toplevel namespace is. If you wish your custom Math module to have everthing the standard Math module has, do this:
                <span class="syntaxdefault">module Didier<br />  module Math<br />    include</span><span class="syntaxkeyword">(;;</span><span class="syntaxdefault">Math</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">    const_set</span><span class="syntaxkeyword">(</span><span class="syntaxstring">"EPSILON"</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> 1.0e-10</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">  end<br />end</span>
                ** The toplevel operator ( **::**) does not work for Ruby 1.8.0
                Now any plugin submodule of Didier when it calls Math, will find your nested custom Math module, instead of the standard one up at the toplevel. Example:this:
                <span class="syntaxdefault">module Didier<br />  module WizardPlugin<br />    def self</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">epsilon<br />      return Math</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">EPSILON<br />    end<br />  end<br />end</span>
                  Comparing normals to check if faces where co-planar caused me problems. Doing what Google recommended, taking all the points and checking if they all lie on the same plane has worked great.
                  Here's what I got from Simone Nicolo:
                  I'm afraid that comparing 2 unit vectors (within a tolerance of 0.001") is not NEARLY sufficient to determine of two faces are coplanar. Depending on the size of the faces, it is entirely possible (and in fact probable) that two faces with the same face normal (within tolerance) could be highly coplanar (again, within a tolerance of 0.001").
                  The correct way to check if 2 faces are coplanar is to collect all the vertices of both faces and check that they all lie in a common plane. One can use the method Geom.fit_plane_to_points to compute a best (least squares fit) plane through all the points and then follow that with calls to Geom.on_plane? for each point to verify that all points lie on the computed plane.
                  Note:this is the way SketchUp determines if 2 faces are coplanar
                    And that didn't work?
                    hmm... you'd think that;d work.
                    Did you use Transformation.axes to transform into 2d? Or some other method?
                    • Didier BurD
                      Didier Bur
                      I've used Geom::Transformation.new origin, zaxis
                      def MyWeirdModule.sort_points_by_x_y_thanks_to_TT(points)
                      		tpoints=[]
                      		# normal to the 3 first points of points array
                      		normalToPointsPlane=Geom;;Vector3d.new(points[0].vector_to(points[1])*points[0].vector_to(points[2]))
                      		t1=Geom;;Transformation.new(points[0],normalToPointsPlane)
                      		t2=t1.inverse
                      		points.each { |p| tpoints.push(p.transform(t2)) }
                      		tpoints.sort { |a,b| a.x==b.x ? a.y <=> b.y ; a.x <=> b.x }
                      		return tpoints.each { |p| p.transform!(t1) }
                      Adding Xaxis and Yaxis to the transformation definition didn't change anything 😞
                      DB
                        can be written
                        tpoints = points.map { |p| p.transform(t2) }
                        tpoints.sort { |a,b| a.x==b.x ? a.y <=> b.y : a.x <=> b.x }
                        doesn't do anything - you probably meant .sort!
                          <span class="syntaxdefault"><br />def self</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">sort_points_by_x_y</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">points</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">  v1 </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> points</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">].</span><span class="syntaxdefault">vector_to</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">points</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">1</span><span class="syntaxkeyword">])<br /></span><span class="syntaxdefault">  v2 </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> points</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">].</span><span class="syntaxdefault">vector_to</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">points</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">2</span><span class="syntaxkeyword">])<br /></span><span class="syntaxdefault">  t1</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">Geom</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Transformation</span><span class="syntaxkeyword">.new(</span><span class="syntaxdefault">points</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">],</span><span class="syntaxdefault">v1</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">v2</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">  tpoints </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> points</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">map </span><span class="syntaxkeyword">{</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">|</span><span class="syntaxdefault">pt</span><span class="syntaxkeyword">|</span><span class="syntaxdefault"> pt</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">transform</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">t1</span><span class="syntaxkeyword">)</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">}<br /></span><span class="syntaxdefault">  tpoints</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">sort</span><span class="syntaxkeyword">!</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">{</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">|</span><span class="syntaxdefault">a</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">b</span><span class="syntaxkeyword">|</span><span class="syntaxdefault"> a</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">x</span><span class="syntaxkeyword">==</span><span class="syntaxdefault">b</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">x </span><span class="syntaxkeyword">?</span><span class="syntaxdefault"> a</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">y </span><span class="syntaxkeyword"><=></span><span class="syntaxdefault"> b</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">y </span><span class="syntaxkeyword">;</span><span class="syntaxdefault"> a</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">x </span><span class="syntaxkeyword"><=></span><span class="syntaxdefault"> b</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">x </span><span class="syntaxkeyword">}<br /></span><span class="syntaxdefault">  tpoints</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">map</span><span class="syntaxkeyword">!</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">{</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">|</span><span class="syntaxdefault">pt</span><span class="syntaxkeyword">|</span><span class="syntaxdefault"> pt</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">transform</span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> t1</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">inverse </span><span class="syntaxkeyword">)</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">}<br /></span><span class="syntaxdefault">end<br /></span>
                          • Didier BurD
                            Didier Bur
                            Given 3 points:
                            v1 = points[0].vector_to(points[1])
                            v2 = points[0].vector_to(points[2])
                            t1=Geom::Transformation.new(points[0],v1,v2)
                            -> the transformation that put any face containing these points in the red-green plane is t1.inverse (I've drawn it to be sure)
                            So why does't Graham's scan work for such a face, once put on the main horizontal plane ?
                            I've typed: 'puts l_upper.length,l_lower.length' in self.convex_hull method. It always end up with 2 and 0 respectively.
                            Is the "guilty" self.right_turn?
                            It's just (one more time) a question of tolerance I guess. I've output the determinant value and it is sometimes, say -5.6843418860808e-014 and sometimes exactly 0.0
                            Maybe something to search here...
                            Another thing: convex hull is sometimes correct for any horizontal face at a z!=0, but always incorrect when the face is at z=0.
                            I tested a horizontal face with z!=0 and got a convex hull of 2 points. I erased that face and redraw it exactly the same, then the convex hull was correct (4 points). I made a copy of the correct face upward and again the hull was incorrect, go figure. Pffff, I'm really puzzled, after all...
                            DB
                            • Didier BurD
                              Didier Bur
                              Starting graham's hull from scratch, it works now. Thanks go to TT, mostly 👍
                              DB
                                It works on any plane now?
                                • Didier BurD
                                  Didier Bur
                                  Yep, on any plane
                                  Here is the rough test code: make a selection of n coplanar guide points on any face, type 'graham' in the console and it draws the convex hull correctly. As you will see, code is yours almost entirely. It's likely there is something wrong in my classes or methods.
                                  def graham()
                                  	pts=[]
                                  	# Selection of coplanar guide points to array pts
                                  	Sketchup.active_model.selection.each { |cp| pts.push(cp.position) }
                                  # Transform points to horizontal plane
                                  	t1=Geom;;Transformation.new(pts[0],pts[0].vector_to(pts[1]),pts[0].vector_to(pts[2]))
                                  	horizPoints = pts.map { |pt| pt.transform(t1.inverse) }
                                  	# Sort by X and Y
                                  	points = sort_points_by_x_y(horizPoints)
                                  	# Graham
                                  	l_upper = [ points[0], points[1] ]
                                  	2.upto(points.length - 1) do |i|
                                  		l_upper << points[i]
                                  		while l_upper.length > 2 && !right_turn?(l_upper.last(3))
                                  			l_upper.delete_at(-2)
                                  	l_lower = [ points[-1], points[-2] ]
                                  	(points.length - 3).downto(0) do |i|
                                  		l_lower << points[i]
                                  		while l_lower.length > 2 && !right_turn?(l_lower.last(3))
                                  			l_lower.delete_at(-2)
                                  	l_lower.delete_at(0)
                                  	l_lower.delete_at(-1)
                                  	# Reset convex hull to its original transform
                                  	hull=(l_upper + l_lower).map! { |pt| pt.transform(t1) }
                                  	# draw hull
                                  	Sketchup.active_model.entities.add_line(hull)
                                  	Sketchup.active_model.entities.add_line(hull.last,hull.first)
                                  def right_turn?(points)
                                  	p, q, r = points
                                  	return (determinant_3x3([1,p.x,p.y,1,q.x,q.y,1,r.x,r.y]) < 0.0)
                                  def determinant_3x3(array)
                                  	a,b,c,d,e,f,g,h,i = array
                                       return ((a*e*i) - (a*f*h) + (b*f*g) - (b*d*i) + (c*d*h) - (c*e*g))
                                  def sort_points_by_x_y(points)
                                  	return points.sort! { |a,b| a.x==b.x ? a.y <=> b.y ; a.x <=> b.x }
                                  DB
                                  • 2 / 2
