    [Plugin][Code]SKMtools,Material/ImageTools
    178 Posts 37 Posters 308.9k Views 37 Watching
      Here's an update http://forums.sketchucation.com/viewtopic.php?p=293677#p293677
      The time-out for ImageTrimmer file creation extended to 60secs to cater for larger files being slow to complete...
        Some scripts have been recast to address glitches with MAC file paths.
        Everyone should update to these new versions...
          Here's another update http://forums.sketchucation.com/viewtopic.php?p=293677#p293677
          ImageTrimmer time-out for larger .dat files extended, EdgeDetector.jar improved...
            Here's an update - some minor issues fixed... http://forums.sketchucation.com/viewtopic.php?p=293677#p293677
              Here's another update - ImageTrimmer processing speed has been improved and 'hanging' is now much less likely... http://forums.sketchucation.com/viewtopic.php?p=293677#p293677
              • B
                Ben Ritter
                Thank you TIG
                  The Image and Material class extended methods will now only load if not already defined by SUp itself [==future-proofing since there's no medium-term hope of them doing this themselves?].
                    ImageTrimmer - glitches with simplify etc addressed and speed improved.
                      Following the inclusion of mew methods in SUp's v8-M1...
                      Material.class extensions - aliases added for save_thumbnail()==.write_thumbnail() and .delete==.remove. The .name='' and .delete methods now match SUp >=v8-M1 returned values.
                      To allow the methods to work in pre-v8-M1 SUp versions... with the new SUp method names / syntax.
                        The 'aliases' have be slightly recast to avoid removing the new methods.
                          The ImageTrimmer tool has an added option to 'flatten' the new materia's texture PNG [i.e. remove its transparency] so that it will then receive shadows.
                          Note that there is also a new jar FlattenPNG.jar that is used to do this.
                            A new tool has been added 'pngwhite2transparent.rb' and its matching jar file.
                            See its new thread for more details...
                              Mr Tee
                              Thanks alot TIG!
                                Here's an minor update http://forums.sketchucation.com/viewtopic.php?p=293677#p293677
                                The new tool 'pngwhite2transparent.rb' transparent color made by the .jar file is now 'white' [although you don't see it!].
                                  For ImageTrimmer - 'Simplified image' - a rare error on delete edge is now trapped.
                                    Here's a major update http://forums.sketchucation.com/viewtopic.php?p=293677#p293677
                                    The MAC execution of the jar files has been addressed - it affects most tools/methods.
                                    You need Java installed/enabled and appropriate permissions to execute files and read/write to the ../Plugins/SKMtools folder. On a MAC you might be prompted to allow a jar file to run - if so answer 'yes' - this should only get asked the once for each jar-type... ๐Ÿค“
                                      Here's an update http://forums.sketchucation.com/viewtopic.php?p=293677#p293677 which fixes a minor glitch with the ImageAnimationAppObserver - it was working OK but could sometimes give spurious error messages in an open Ruby Console until this fix...
                                        Adasiekkk
                                        Hi!
                                        Congrats on an amazing plugin, but there is one major issue I have.
                                        When I decide to undo the previous action (Ctrl+Z or Edit->Undo), in the place where animation was I now have all pictures tiled next to each other.
                                        Thanks,
                                        Adam
                                          Rather than try to undo Image Animations you must just stop all animations.
                                          To get back to an original Imgage's start-frame you need to start that individual Image's animation... angd then stop it when the frame you want appears...
                                          • B
                                            billberet
                                            hey everyone. I am new to this forum so please be gentle.
                                            i just built my first maker-bot and it is working great printing all my 3d models.
                                            i have installed google sketchup, free version, v8
                                            i installed the plugin, and everything is fine so far. i have the image trimmer menu item under the tools dropdown.
                                            so i want to create a 3d model of a 2d image.
                                            i import a greyscale .png file with transparencies, then i run the IMAGE TRIMMER plugin.
                                            when i do this, i get the notifications on the bottom saying 'making edges files'
                                            the dots scroll as it processes ...............
                                            then that's it, the process finishes and nothing happens.
                                            i am running on a win7 machine 64bit.
                                            does anyone have any ideas that can point me in the right direction?
                                            thanks again
                                            bill
                                            • 3 / 9
