    Rotate about Component axis?
    7 Posts 5 Posters 664 Views 5 Watching
      Before I reinvent the wheel, is there a plugin that does this already? Let you rotate a component around its axes using the insertion point as pivot?
        Jim
        This?
        http://forums.sketchucation.com/viewtopic.php?f=323&t=20346&hilit=plugin
          nearly. it doesn't use the insertionpoint as pivot.
          One can change it, but getting the pivor is not always easy with some components. some times there is nothing to snap to.
          • jason_marantoJ Offline
            jason_maranto
            Did this idea ever bear fruit?
            Best,
            Jason.
            • honoluludesktopH Offline
              honoluludesktop
              tt, I can think of two, the rotate component that TIG wrote, and mine. Don't know if TIGs can be easily used to rotate around the intersection point, but mine will rotate around the axis origin. If you elect to do one, make it point by any axis, mine is limited to pointing z, and requires something to point to. Another feature I thought of adding (probably beyond my skill set) is to incorporate moving the axis origin around the base of the component.
              Addenda: Oops, just noticed that the original post was May 2010.
              • halroachH Offline
                halroach
                Best,
                Jason.
                There is this: [Plugin] Free Rotate
                http://forums.sketchucation.com/viewtopic.php?f=323&t=30380
                I'm not sure it works with the insertion point, though I think it should 😎
                FlexTools - Super Quick Windows, Doors, Slats...
                  Best,
                  Jason.
                  It turned into this: http://forums.sketchucation.com/viewtopic.php?f=323&t=28455&p=247067#p247067
