    [Plugin] Compo Spray 1.4.2 Updated
    271 Posts 89 Posters 340.7k Views 89 Watching
      Aldob
      Thanks,
      My SU 7.1 just closing down as soon as I press component spray button on toolbar.
      I deleted older version from Plugins folder and my system is Win XP 64
      Regards
      • Didier BurD Offline
        Didier Bur
        It does bugsplat ?
        DB
        • pep75P Offline
          pep75
          It looks very promising, but it does nothing. I can see the menu etc, but when I push the "spray" button; "the computer says: "No".... 😉
          Oh I'm working with v8!
          • F Offline
            fjb80
            The compospray icon shows up, as does the toolbar, but when I click it nothing happens. Here's my error message from the ruby console:
            Error: #<Errno::ENOENT: No such file or directory - /Users/Fraser/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/CompoSpray/csSettings.html>
            (eval):269:in initialize' (eval):269:in new'
            (eval):269:in write_cs_dialog' (eval):107:in compoSpray_main'
            /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/compoSprayToolbar.rb:14
            (eval):269:in `call'
            (eval):269
            So it looks like it's missing an html file?
            Using OS 10.6, SU 8
            Thanks,
              It's looking in your user folder instead of the root folder where the plugin is installed.
              Have you installed some plugins into your user folder? In come cases that might confuse plugins.
              • F Offline
                fjb80
                The only files under the user library is a podium script. Can I edit one of the files in the folder (CSS) to make sure it looks in the HD library folder rather than the user library folder? I'm not sure how a ruby script works, but this would be a great one to get up and running.
                Thanks for the help so far,
                F
                  hmm... if I remember correctly, podium can confuse some scripts.
                  @didier: how are you locating your files? I find that basing all my paths on File.dirname(__FILE__) is the most reliable method. Sketchup.find_support_file doesn't seem to be that reliable as plugins might not be installed there.
                    Didier Bur
                    The HTML file isn't missing, because it is written (normally) each time the tool is launched, then loaded in the webdialog.
                    @thomthom: Here is how I locate this file:
                    @path_cs = Sketchup.find_support_file("Plugins")+"\/CompoSpray\/"
                    	@settings_dialog = UI;;WebDialog.new("CompoSpray Settings",true,nil,100,100,100,100,false)
                    	@settings_dialog.set_file(@path_cs + "csSettings.html")
                    Does this not work on a Mac the same way than on a PC ??
                    DB
                    • halroachH Offline
                      halroach
                      Is there a way to to spray onto closed components, rather than only onto "open" surfaces?
                      edit: I think stacking does it... ok! never mind!
                      Wonderful plugin!!!!
                      FlexTools - Super Quick Windows, Doors, Slats...
                        As you see in his error report, the plugin is trying to look for the file at:
                        while the plugin itself is located under:
                        OSX has a system Library folder and a User Library folder that looks very similar, and some users end up adding plugins to User Library. And I think Podium installs there.
                        And then you can get issues with Sketchup.find_support_file
                        The best way to determine the base path of your supporting folders are:
                        In your case it'd be:
                        @path_cs = File.dirname(__FILE__) + "/CompoSpray/"
                        However, that won't work in .rbs files.
                        In Vertex Tools I made the uncrypted loader, which was a regular .rb file, determine the paths and assign it to constants which the .rbs files could use.
                        I've never had any path issues that way, and the plugins can be installed anywhere on the system. (if the user prefers to install in a custom location.)
                          Didier Bur
                          Thanks for all these tips and explanations TT ☀
                          DB
                          • F Offline
                            fjb80
                            So is there a way I can update my plugin to get it to work or do I have to wait for an update? Can I change some code? I looked for the code attached to Didier's post but couldn't find it in any of the files I had. Again, I'm not super familiar with code so it may be somewhere else.
                            Any help would be appreciated. Thanks for the discussion and attempts to resolve my issue. Much appreciated.
                            Fraser
                            • N Offline
                              nickchun
                              Hi, I have tried to use this plugin on SU7 free, but cannot get it to work. I did not have the previous version so there were no files to delete. instead of the input box for 'shape' I get the box as shown for 'vertices of faces'.
                              Any ideas?
                              Nick
                              • halroachH Offline
                                halroach
                                Any ideas?
                                Nick
                                1. I got the same thing at first. After playing around with the model, making new components and refreshing the compospray window (by closing and reopening) that got solved.
                                2. I had a different problem with the altitude (min max) bars not updating their info unless I start moving the sliders. sometimes the sliders disappear completely and I need to refresh...
                                3. when using the spray tool, sometimes it works really quickly, other times it gets stuck for a very long time, even though the places on the curved surface I am clicking on look all quite the same. I am not sure how to recreate this, if I'll get to it I'll repost.
                                  Didier Bur
                                  @nickchun: this happens when the selection isn't empty before launching the tool.That's normal. If you read the doc you will notice that 😉
                                  PLEASE READ THE DOC FOLKS ! 🎉 ,
                                  DB
                                  • N Offline
                                    nickchun
                                    Didier, sorry, I didn't pick up on that in the manual. Components need to be placed in model outside of the selection right? Works fine. Thanks very much
                                    • OxerO Offline
                                      Oxer
                                      Thanks for update the plugin, i would like translate the plugin to spanish language, is this possible?
                                        Aldob
                                        It does bugsplat ?[/quote]
                                        It does nothing 😞 just closing SU down. Tested on SU 8.0 Works OK. But I have 7.1 Pro only. I guess some of ruby previously downloaded dcause that... But don't know which of them. Some of other commands from LSS tools and Tools on surface cause Closing down as well. They used to work well.
                                        Regards,
                                          Didier Bur
                                          Weird.
                                          There shouldn't be any conflict with another plugin because all is wrapped in a Ruby Module, and there are also no redefinition of standard methods or classes. A workaround would be to empty your Plugins folder except compoSpray, see if it works, and then add other scripts one by one and check when it makes SU close.
                                          Hope this helps,
                                          DB
                                            Didier Bur
                                            @nickchun:
                                            Components must have been imported in your model (you can see such components when clicking on the "house" icon of the components windows) prior to using the tool, otherwise they won't appear in the dropdown lists.
                                            When you select faces before launching the tool, the shapes dropdown list is replaced by 2 options: insert a component at each vertex of each selected face, or use the selected faces as the area to spray on.
                                            DB
                                            • 13
                                            • 14
                                            • 2 / 14
