    [REQ] Texture/material brush
    11 Posts 8 Posters 1.1k Views 8 Watching
    • soloS Offline
      I have no clue if this is already available, as I have no idea how to even search for it.
      I'd like a tool that I can use as a brush and maybe even a spray effect for applying materials to faces.
      I was using Thomthoms 'Front-face' tool and while hovering over faces to change their direction I realised how helpful this would be for applying a texture on a heavy mesh model.
      So if anyone know if this already exists please direct me to it and if it does not exist, would any guru out there consider it?
      • mitcorbM Offline
        mitcorb
        Yeah, I've got a spider model that could use a spray paint effect on its body. The markings are so freeform and colorful that I do not know what render program could accomplish this. So, a tool like your idea would be great. While you wait, look up images of Leucauge Venusta Florida Orchard Spider. Or not. Hope somebody comes up with something.
        • F Offline
          Fletch
          did you mean to say "Tomasz"? 😉
          Fletch
          Twilight Render Cross-platform Plugin for SketchUp on PC or Mac
          • soloS Offline
            Oops. 😳
            I meant Tomasz. 😉
            (Thomasz - Thomthom, sound similar)
              Dsmelcer1234
              I you can natively import skp files into Photoshop cs4 and above, and then use the 3d tools there. I'm not 100% but I'll check. Here is a video of the painting tools.
              • soloS Offline
                Please do, I'd actually like to be able to export a component to Photoshop, paint it then return it to SU.
                  autarchos
                  i'm using cs5 and don't see .skp available - however, .dae, .kmz, .3ds, and .obj are, so it shouldn't be too complicated to export and import back, right?
                  • soloS Offline
                    If indeed Photoshop can do this and able to import .skp, then maybe we can get a plugin that can export component with a right click menu option.
                    Could be awesome if it works.
                    • E Offline
                      Ecuadorian
                      Having something like Deep Paint 3D inside SketchUp would be pure awesomeness.
                      -Miguel Lescano
                      • N Offline
                        notareal
                        I think .dae, obj or some other format needs to be used. No .skp import in CS (Design premium).
                        Welcome to try [Thea Render](http://www.thearender.com/), Thea support | [kerkythea.net](http://www.kerkythea.net/) -team member
                          dedmin
                          http://www.lynda.com/home/Player.aspx?lpk4=46318
                          http://forums.sketchucation.com/viewtopic.php?f=323&t=23595&hilit=Photoshop&start=30
