    Array doesn't work...
    4 Posts 3 Posters 549 Views 3 Watching
    • K
      kiesewetter
      Hallo!
      You might laugh because of that post, but I'm not able to find the reason why it doesn't work...
      I just want to create an infobox and safe the input to some variables...
      Here is the code and Sketchup's comment in the debugger:
      prompts = ["Bildhöhe", "Bildbreite", "Bilder pro Sekunde", "Filmdauer in Sekunden", "Ausgabename"]
      default = [  "800",         "800",           "25",                  "60",             "Ablauf" ]
      aufnahmebox = UI.inputbox prompts, default, "Ablaufsimulation mit statischer Ansicht"
      hoehe = aufnahmebox[0].to_i
      breite= aufnahmebox[1].to_i
      fps=aufnahmebox[2].to_i
      dauer = aufnahmebox[3].to_i
      name = aufnahmebox[4]
      load "C:/Users/tim/Desktop/array.rb"
      Error: #<SyntaxError: (eval):4:in `load': C:/Users/tim/Desktop/array.rb:1: syntax error, unexpected tCONSTANT, expecting ']'
      ...pts = ["Bildhöhe", "Bildbreite", "Bilder pro Sekunde", "Film...
      C:/Users/tim/Desktop/array.rb:1: syntax error, unexpected tCONSTANT, expecting $end
      ...ldhöhe", "Bildbreite", "Bilder pro Sekunde", "Filmdauer in S...
      (eval):4
      (eval):4
      Thanks for your time.
      Tim
        Try this
        def test
            prompts = ["Bildhoehe; ", "Bildbreite; ", "Bilder pro Sekunde; ", "Filmdauer in Sekunden; ", "Ausgabename; "]
            defaults = [800, 800, 25, 60, "Ablauf" ]
            aufnahmebox = UI.inputbox(prompts, defaults, "Ablaufsimulation mit statischer Ansicht")
            fps=aufnahmebox[2]
        See how I removed the accented letter 'ö' and used a 'oe'. Ruby/SUp isn't good with some 'accents' in some circumstances.
        'Bildhoehe' now works fine...
        Also note how I have removed the "" from the values you want as integers and made them integers initially - that way you can't try to use anything that isn't an integer as your input...
        I've also put the arguments for inputbox inside () - recommended but not fatal otherwise [yet]...
          That'd most likely be because different character encoding in the .rb file from SU. SU uses Unicode, UTF-8 encoded in it's interface. Should be find to pass on UTF-8 data, but it needs to be properly encoded.
          (though I'm not sure if you can run .rb files in UTF-8 - so one might need to write the strings in a UTF-8 file and change the encoding (don't convert, just change) in the editor - which should give you some extra funny looking characters.
          Might be easier to manage and reduce risk if you store them strings in an external UTF-8 encoded text file and load them from there.
          • K
            kiesewetter
            Works! 😄
            Thank you!
