    Hardware recommendations
    409 Posts 97 Posters 92.7k Views 97 Watching
      kevsterman
      that graphics solution requires a bit of power and could be replaced with something like a nVidia GTX 280 or even a GTX 260 (less expensive than the GTX 280) that will give you similar (if not better) performance for roughly the same energy usage.
      I've compared the GTX 280 and the GTX 260 against the 9800GX2 on the nvidia website and the 9800 seems to outperform the other 2 quite a bit. For example, graphics performance for 9800 is 45x and for the other two its 35x. Texture fill rate for 8900 is 76.8billion and for the other two its 36.9 billion. Max memory bandwidth for 9800 is 128GB and for the other two its 111.9GB. Standard memory config for 8900 is 1GB and for the other two its 896MB.
      So isn't the 9800GX2 a better graphics card to get than the GTX280 & 260? 🤓
      "Avoid keeping more than 3 items on your desk that you can't fit into your mouth."
      • jujuJ Offline
        juju
        Only to applications that will / can make use of a SLI setup. Even though it is not strictly speaking a SLI setup since there is only one graphics card the implementation is still quite the same.
        SU benefits from stronger GPU and stronger (higher clocked) CPU components. You need to consider what application you're doing the upgrade for and if it will benefit from the technology offered or not, I made that mistake when buying a 2.4GHz quad core CPU thinking SU will be all over it like white on rice.
        AFAIK SU isn't optimised for dual graphics card implementations (or multi core CPU's) and as such wouldn't benefit from these technologies at the moment. Hopefully that will change with SU7, but who knows when that will be coming to market since there is not so much of a peep from Google, apart from "working on it" about SU7 release date.
        Also:
        The 9800GX2 has 512MB video RAM, 128 stream processors and 256-bit memory interface width per GPU. The higher the number in the memory interface width the better the graphics card is my rule of thumb.
        I must say, for the price these 9800GX2's are going at they would be awesome for gaming, but I'm not convinced that SU would benefit that much from it, but then again I could be wrong.
        • N Offline
          nbxx
          think you.
            sky2779
            hi all.i found that there would be some problem using ATI video card.something like there are some problems when you chooseing the face.
            is there anyone have the same problem?
              JuanV.Soler
              not here, yet 😄
              • brodieB Offline
                brodie
                Ya, that's pretty common w/ ATI cards. I had the same issue. You can try different drivers but that didn't work for me. I ended up having to turn off Hardware Acceleration (basically the same thing as yanking out your ati card and throwing it at the wall but less satisfying). I ended up buying an nVidia card.
                -Brodie
                • soloS Offline
                  Ati cards have been known to have a few glithes in the past for GPU intensive non game apps, however recently AMD merged/aquired them and it is said that the new generation cards coupled with AMD mobo's would not only solve such issues but also exceed nvidia benchmarks.
                  • Z Offline
                    Zilonx
                    Hi All,
                    This topic is very interesting. I'm using an old 128MB 1400 quadro board, and I`m looking for an upgrade. My system is fast with everything (XP64SP2), except SU - my gigantic models take up to 10~15 minutes just to change views (transitions/shadows disabled). Those models, on wireframe mode, it still take some minutes to change views too. Can the new GTX boards handle SU like professional boards? On SU, I'm in doubt about the advantages - if any - of the quadros over the newer GTX. Since I render Maxwell on a farm, this SU performance problem matters.
                    Also, can anyone post any links to benchmarks of nvidia versus amd? I found that ati/amd drivers still have less support for OpenGL than NVidia.
                    Thanks for any advice.
                      dsarchs
                      I was wondering why everyone only talks about Nvidia cards? Surely, they are great cards, but AMD seems to have some very competitive cards out right now. They big draw to Nvidia for me, right now, is the prospect of CUDA, but as that hasn't come out yet I think I could wait and in a year or so, buy a budget Nvidia card that would be easily comparable to their current high-end.
                      The problem with AMD seems to be that the cards run really hot. Still, at such a price difference you could afford a better cooling system and/or ventilated case.
                      Is there a real problem with SU using AMD cards? That would be hard to believe considering the amount of people using their cards. Does anyone here use a current-gen AMD card?
                      Here is an article [ http://www.tomshardware.com/reviews/radeon-hd-4870,1964.html ] reviewing the 4870 by tomshardware.com -- a very reputable online tech source. Also, notice the 4850 [which can be found for $150 or less] which is not much behind the more expensive 4870/GTX 260... I would imagine a crossfire 4850 setup [~$300] could be pretty sweet -- again, if you could keep it cool.
                      I would love to hear people's thoughts on this.
                      [Here's a section from the conclusion on this review]
                      **For once, our assessment of this Radeon HD 4870 will be simple: It’s an excellent high-end graphics card! With the same architecture and most of the strong points of the Radeon HD 4850, it’s in a higher category performance- and price-wise. The bottom line: Though it’s faster by an average of 6% (and in the majority of our tests) than the GeForce GTX 260, it sells for $299 – $150 less than the competing Nvidia card! Even the top-end card from Nvidia, the GeForce GTX 280 – souped up with more transistors, twice as much memory and higher clock speeds – is not that far ahead. It showed only 13% better performance than the Radeon HD 4870, though it costs twice as much.
                      A few points enter into the picture to make it bit less idyllic, however. First, the Radeon HD 4870 suffers slightly from the competition with its own stable mate, the HD 4850, since the smaller card has a better performance/price ratio (only 23% less performance at a price that is 60% lower). And, AMD has totally reversed its strong and weak points compared to the preceding generation, and in particular to the Radeon HD 3870 — The Radeon HD 4870’s performance is good with antialiasing enabled (despite having only 512 MB of memory), but it consumes a lot more power at idle and also under load (and more than the GeForce GTX 260). And it’s not exactly a model of silent performance, though it’s still a lot quieter than the GeForce GTX 260, and without heating up the inside of your case.**
                      http://media.bestofmicro.com/P/E/114962/original/avg-framerate.png
                      Knowledge is a polite word for dead but not buried imagination.
                      -e.e.cummings
                      • jujuJ Offline
                        juju
                        The problem with AMD/ATi graphics cards is not about the incapability of hardware, it seems like a driver coding issue that isn't getting resolved.
                        However some people seem be using it without a problem, like when I had my old machine with the ATi Radeon 9800 Pro 128MB, didn't have any trouble using it with SU, just frikkin slow and almost unusable at times.
                          dsarchs
                          That card would've been before the ATI/AMD merger, I think. I've heard that they're graphic line is much better since the merger.
                          I'm not such a fan of AMD but I imagine I'll be buying a system sometime in the next year and have been starting to look around to see what's out there.
                          Personally I think that CUDA looks amazing... I really hope that pick's up in the very near future. Intel's philosophy of continually adding more and more cores seems ridiculous -- much too brute force -- while GPU [through CUDA] seems a very elegant use of hardware we already have [to a much larger result that merely CPU].
                          -e.e.cummings
                          • brodieB Offline
                            brodie
                            Regarding ATI/AMD it would be interesting to start hearing some feedback as to whether the 'old' issues still exist or not. However, at this point I think for SU users it's still risky to run out and buy an ATI card even if they're 'better.' You can buy a card w/ uber framerates and clockspeeds that'll make you dizzy but if you can't pick the face of a wall it's worthless. 👊
                            -Brodie
                            • Z Offline
                              Zilonx
                              This can have real significance under SU:
                              Page not found – Geeks3D
                              (www.geeks3d.com)
                              Where can we find info about OpenGL resources used by SU? Google people, anyone?
                              • soloS Offline
                                Could well be, maybe if anyone is experiancing any GPU issues this may be an option ... any lab rats out there wanna give it a go?
                                Nice find Zilonex, you may have a cure for many distressed users.
                                • AnssiA Offline
                                  Anssi
                                  The usual card tests found in magazines etc are rather useless for choosing a card to use with SU, as they seldom test OpenGL performance. Magazine editors are almost exclusively interested in DirectX performance, that is irrelevant to SU and mostly applies to games.
                                  I add one warning to notebook buyers. Driver upgrades to notebook graphics are almost exclusively available only through the notebook manufacturers, and most often than not the upgrades are few and long between. I was lucky in that the driver shipped with my Nvidia-equipped Acer luggable runs SU OK, as there has been no upgrade to that at all in four years. If you can, choose a graphics subsystem supported directly by the graphics manufacturer.
                                  Anssi
                                    Jackson
                                    Anssi,
                                    I was under the same impression for years regarding my nVidia Geforce Go7400 equipped laptop, but finally found a custom driver update solution on the laptopvideo2go website- it took a few tries of downloading supposedly compatible drivers, uninstalling old ones, running a registry cleaner and reinstalling new drivers before I found one that runs properly on my card, but FINALLY I have drivers just a few months old rather than the 3 yr old ones that were bundled with my laptop. The key is to remember to copy/paste the modified .inf file so that the driver installer will allow the modded drivers to be installed on your machine.
                                    (www.laptopvideo2go.com)
                                    Sadly they're only available for nvidia cards, but perhaps there's another site that specialises in ATI?
                                    Hope this helps,
                                    Jackson
                                      kwistenbiebel
                                      Jackson is right.
                                      The laptopvideo2go website is a MUST for laptop SU users.
                                      • Z Offline
                                        Zilonx
                                        Hi Tommy and ALL,
                                        Are there any news about the survey? I found this link ([http://www.tomshardware.com/de/GTX-280-260-GT200-Geforce-Nvidia,testberichte-240063-22.html](http://www.tomshardware.com/de/GTX-280-260-GT200-Geforce-Nvidia,testberichte-240063-22.html)), and this table ([http://media.bestofmicro.com/M/9/110961/original/062.gif](http://media.bestofmicro.com/M/9/110961/original/062.gif)) shows impressive data: under SPECViewPerf 10 benchmark, the 3870x2 score was about twice of the gtx280. I bought cg hardware for more than 15 years. So I like a lot the nv initiatives, like the future MentalRAY on hardware one - truly gold for cg professionals. But those numbers show very deceptive performance for the gtx280, and we all know that it is a card with a very impressive gpu. If anyone could post links or info to viewperf 10 and other benchmarks with the gtx280 I will be very glad of. What's the point? Well, nv could boost a lot their selling numbers if leave this professional versus gaming boards nonsense. Today, all the technological differences between the "gaming" and the "quadros" are vaporware - and we all know this. The results are clear: nv is losing a lot of key and loyal customers - I'm one of them.
                                          TIGER280E
                                          Hai everyone on this forum, I'm newbie in this useful forum,,,sorry for my english if it's not good,I'm from Indonesia,,,i just wanna ask you guys about product called WACOM TABLET,,,,is it usefull for using this product to draw the 3D things like SketchUp ? because there is a great sale for this product in my country,,,,i think thats a cool gadget for drawing,,,,,the point about my question , is this cool stuff can help increasing our performance for drawing in 3d, especially for SketchUp,? thanks guys,,,,once again, sorry for my english,,,,
                                            remus
                                            I use a wacom in SU, although i wouldnt say it increases the speed at which i model it is a more pleasant experience. They are also far superior for doing things in photoshop, which can often be a big part of making good models in SU.
                                            Overall id say go for it. They take a bit of getting used to but they are very nice to use once you get used to it.
                                            • 20
                                            • 21
                                            • 7 / 21
