    Hardware recommendations
    409 Posts 97 Posters 208.7k Views 97 Watching
      archtrot
      We have been dealing with 80MB models in my office lately.
      I'm considering buying a couple of computers with the following spec:
      Windows 7 64 bit
      AMD Athlon 3.5Ghz dual core processor
      8 Gb RAM
      PNY Quadro 580 with 512 Mb RAM graphics card
      I can get this package built for around $2000.
      Can I do any better than this without doubling the cost?
        danbig
        Wow--this is a long topic. I made it through about six pages before I jumped here to ask my question:
        What is more important for SketchUp: system RAM, or video RAM?
        Does anyone have any suggestions for a notebook computer that will do well with larger sketchup files?
        • AnssiA
          Anssi
          Vram only becomes critical if you use a lot of very large textures. Su is a 32-bit application, so system RAM is not so critical either.
          What you should look for in a SU notebook is
          • processor speed, number of processor cores is not so important, as SU uses only one
          • SU benefits from the TurboBoost feature in the latest Intel multicore processors
          • a real graphics card (Nvidia seems still to be more reliable)
            seanheadrick
            Hello,
            My father, a long time CAD user was wanting to give SU a try and is having a problem downloading the software. He currently uses Auto Desk on the same laptop, so I found it hard to believe his suggestion that his computer was not capable of running SU was likely. I referenced below his laptop configuration. Could anyone tell me if it seems like he should or should not be able to run SU, and if not what the problem may be. I haven't been able to trouble shoot with him much so I don't know yet if he may just be doing something wrong when installing. I thought I would rule this out first.
            Thank you,
            Sean
            Toshiba Laptop
            2.3 GHz
            4 GB RAM
            235 GB remaining
            AMD Turion™ II Dual-Core Mobile Processor M520
            AMD M880G Chipset
            ATI Radeon™ HD 4200 Graphics with dynamically
            allocated shared graphics memory
            DO OR DO NOT, THERE IS NO TRY.
              The problem is that he can't download it? That would not be due to the hardware.
              What problem is it? Incomplete download? Errors?
                Dennis_n
                I'm about to buy a new notebook. I wanted to confirm that for SU productivity buying i-7 CPU vs i-5 is a waste of money. Sony Vaio F series carry i-7 but these laptops are about twice the price of the vaio E series. The principal difference between two laptops is the CPU.
                Please, let me know what do you think about i-7 vs i-5 for SU.
                • soloS
                  The i5 has 2 cores and they become 4 threads for rendering, the i7 has 4 cores and 8 threads for rendering. (8 better than 4)
                  For Sketchup you only need 1 core, a decent GPU and around 4gb ram (can get less), but if you intend rendering, get 8, ooodles of Ram and a new Gen video card.
                    Dennis_n
                    here is the Vaio E 1,027.01 USD
                    Intel® Core™ i5-460M Processor 2.53 GHz with Turbo Boost up to 2.80 GHz
                    4 GB (2 GB x 2) DDR3 SDRAM*2
                    ATI Mobility Radeon™ HD 5650 Graphics 1 GB DDR3
                    here is the Vaio F 2,056.60 USD
                    Intel® Core™ i7-740QM Processor 1.73 GHz with Turbo Boost up to 2.93 GHz1
                    8 GB (4 GB x 2) DDR3 SDRAM
                    2 (Max)
                    NVIDIA® GeForce® GT 425M GPU 1 GB DDR3
                    I'm a designer and don't really do renderings. SU is the most demanding application for me.
                    The added advantage to "F" is that the screen is not glossy and I like the design slightly better. However, forking out a whole grand is hard to justify for "slightly better looks".
                    So it seems I won't see a difference for the $1000. Also seems like the clock speed of i-7 is slower - does it mean that this particular i-5 would actually be faster?
                    • brodieB
                      brodie
                      Well, you're right that a higher clock speed = better for SU even though it has less cores (since SU only uses 1). However, that TurboBoost should come into play with SU, as it's made for applications which only use 1 core - that puts the F in a slightly better position that the E in terms of processor. But it's so slight in terms of speed, I wouldn't even consider it a factor.
                      I suspect the quality of those graphics cards is about the same too (without really looking into them at all). The BIG question I'd have on my mind though, is with that ATI card. ATI cards have, traditionally, had a lot of issues with SU for some reason. I'd make sure and find someone using that card with SU before spending the money. PERSONALLY, I'd look for something with similar specs to the E, but with an nvidia card because I've had such poor luck with ATI's playing poorly with SU (you'll see a lot of posts in this thread about ATI). But my experiences and many of the posts are fairly old so it's entirely possible that many/all of those issues have been overcome.
                      -Brodie
                        d12dozr
                        Dennis, if you are not set on a Sony, you might like this Asus.
                        -17.3-inch LED-backlit Full HD display for immersive cinematic experience with resolution up to 1920 x 1080
                        -NVIDIA GeForce GTX 460M graphics with 1.5GB DDR5 VRAM for unprecedented DirectX 11 gaming
                        Intel Core i7-740QM processor with Intel Turbo Boost Technology to automatically boost speed to your task at hand
                        -SuperSpeed USB 3.0 for quicker device charging and up to 10x faster transfers than USB 2.0
                        -500GB 7200RPM hard drives and 8GB of DDR3 system memory for smooth computing and ample storage for all your games and media files
                        -Price: $1,499.99
                        http://goo.gl/f7ooYh
                          Dennis_n
                          good specs on this baby.
                          However, I need it for business. the stealth like design won't fit well on a formal meeting.
                          there is HP Envy 17. that has
                          i5-580M (2.66GHz, 3MB L3 Cache) with Turbo Boost up to 3.33GHz or pay $450 more for
                          i7-840QM (1.86GHz, 8MB L3 Cache) with Turbo Boost up to 3.2GHz
                          • GaieusG
                            Now thatis good for SU! And in case you eventually decide to do some rendering, too, the 4 threads are still better than 2 for instance on a "traditional" dual core.
                            (And of course, you would not want to pay more for a CPU that can turbo boost less!) 😒
                              dsarchs
                              The i7 looks like the system to go with, turbo-boost will eliminate the slower speed when using a single core (which SU is) and more ram will be useful. I haven't kept up with mobile processors so I don't know which gen that i7 is, but the newest intel cpu version has JUST been released (goes on sale this Sunday) and (I've only read about the desktop line but I assume it carries over to the mobile selection as well) is about 20% faster and uses less power. Something to look into.
                              @ Brodie
                              I've always heard that SU doesn't like AMD/ATI cards, but I've never come across this, despite having a mobility 9700 (ATI) card in my laptop for the past 6 years. I've always had good performance and no problems. Do you know if this is only a problem with VERY low-end ATI cards or is it merely a thing of the past?
                              Has anyone had a problem with the last 2 generations of cards (5xxx/6xxx) and sketchup? I've always assumed this is just no longer an issue.
                              Knowledge is a polite word for dead but not buried imagination.
                              -e.e.cummings
                              • brodieB
                                brodie
                                My personal experience comes from 2 different cards a couple years back and further. They were mid-range ATI's that we used here at work for the CAD machines. Basically the issues were the usual, faces would appear selected that weren't, selections would select a face that was behind the one I selected, etc. The other bad experience was with an old dell I had with integrated graphics which had identical issues. Occasionally, I've heard of nvidia's with similar issues but those were always easily solved with a driver change, something that never seemed to completely solve the problem with the ATI's.
                                In the last year or so, I've seen very few comments regarding ATI's either negative or positive, at least insofar as SU is concerned. So the issues may be fixed. But, I personally, still wouldn't guy an ATI out of fear, and I'd recommend that others at least do some checking into the issue.
                                -Brodie
                                • GaieusG
                                  There used to be some problems with certainATI cards.
                                  Yes, basucally this was the issue and even in SU 6, there was an OpenGL setting to correct this bug:
                                  But (at least since v 7.1 - I cannot remember v.7.0) it has been removed meaning that this seems to be no longer an issue.
                                  nVidia's still have some advantages as some renderers tend to prefer them (think of CUDA support) but for SU modelling, there should not be a difference.
                                    I recently got an ATI card for my work computer - high-end quality ATI card, updated drivers. But I experienced glitches very often when using SketchUp and other OpenGL applications. I made the IT manager replace it with a nVidia card - then everything went back to normal.
                                    So I'm not sure if ATI is still completely free of issues. Seems nVidia is more stable - least for OpenGL.
                                    • GaieusG
                                      Fine, thanks for the info Thom. Whenever I am looking at different (possible new) comps, I am also trying to get an nVidia for them. Just in case.
                                      • brodieB
                                        brodie
                                        Good to know Thomthom.
                                        Gaieus, ya, I recall that 'correct reverse picking driver bug' checkbox. I'm not sure what it did internally, but as I recall, it never really fixed the problem in my case, although it would make the problems different which is sometimes a nice change of pace 😄. It is interesting that it was taken out, I'd forgotten all about it.
                                        -Brodie
                                          dsarchs
                                          Thom, which card did you get? I'm just about to buy a new ATI card and now you have me reconsidering.
                                          -e.e.cummings
                                            nVidia Quadro 3800
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 17 / 21
