    How is this possible ?
    12 Posts 3 Posters 991 Views 3 Watching
    • Didier BurD
      Didier Bur
      While working on a new version of the compoSpray script, I've comme across that: select a 2D "faceme" component and:
      c=Sketchup.active_model.selection[0].definition
      #<Sketchup;;ComponentDefinition;0xc3f3cf0>
      c.bounds.height
      9.09494701772928e-013
      c.bounds.height < 0.001 returns false !
      c.bounds.height == 0.001 returns true !
      Where am I missing something, or is Ruby crazy ?
      DB
        SketchUp's internal accuracy is 1000 of an inch. So any lengths you compare that are shorter than that - or when the difference between the lengths is less than 0.001 - will compare as equal.
        Length.<
        http://code.google.com/apis/sketchup/docs/ourdoc/length.html
        The < method is used to see if one length is less than another length.
        For example, if l1 = 1.0.inch and l2 = 1.000001.inch then l1 == l2 so l1 < l2 should return false.
          hm... am I making stuff up again... πŸ˜•
          • Didier BurD
            Didier Bur
            Thanks thomthom,
            and while we are at it, another weird thing:
            def test()
            case Sketchup.active_model.selection[0].class
            		  when Sketchup;;Face
            			puts "face"
            		  when Sketchup;;ComponentInstance
            			puts "instance"
            		  when Sketchup;;Group
            			puts "group"
            		  when Sketchup;;Image
            			puts "image"
            		  when Sketchup;;Edge
            			puts "edge"
            		  else
            			puts "something else"
            This always outputs "something else" in the Console. Case with 'class' as switch isn't allowed or not effective ? 😲
            DB
              This comparison weirdness doesn't happen for me.
              Do you have a script that's loading and resetting == for 'equality comparisons' in the Float class?
              I ran a BareGrep on my ../Plugins folder and found no likely culprits for ' class Float' matches - although I did find I have a Float def =~ in my Roof.rb tools which takes Floats to within 1/1000 as being equal - as in 0.0001==0 >>> false BUT 0.0001=~0 >>> true - but I don't suspect that...
              This is what I get
              y=9.09494701772928e-013
              y==0
              false
              y<0
              false
              y>0
              true
              y==0.001
              false
              y>0.001
              false
              y<0.001
              true
              (y*1000000).to_i/1000000.0
              0.0
              (y*10000000000000).to_i/10000000000000.0
              9.0e-013
              So you can see how to test for nearness to zero with the differing accuracies as the last two examples...
              BUT all == return correct results otherwise πŸ˜•
                @didier bur said:
                Thanks thomthom,
                def test()
                > 		  when Sketchup;;Face
                > 			puts "face"
                > 			puts "instance"
                > 			puts "group"
                > 			puts "image"
                > 		  when Sketchup;;Edge
                > 			puts "edge"
                > 		  else
                > 		end
                > end
                I found this out when writing my SKMtools class
                case v.class.to_s
                  when 'Fixnum'
                was my fix... it returns the class name as a string and compares it with another string in the 'when'... so your method WILL work thus
                    def test()
                    case Sketchup.active_model.selection[0].class.to_s
                            when 'Sketchup;;Face'
                             puts "face"
                            when 'Sketchup;;ComponentInstance'
                             puts "instance"
                            when 'Sketchup;;Group'
                             puts "group"
                            when 'Sketchup;;Image'
                             puts "image"
                            when 'Sketchup;;Edge'
                             puts "edge"
                            else
                  The object type you get from Boundingbox is Length - not Float. This is why you see this difference. Length has that tolerance built in. Something one need to be aware of when you compare data in Ruby SU. Always check if you have a Float or Length.
                  But will be very slow - same performance issue like using .typename.
                  I don't know why one can't use class for switch cases - but instead you should use if,elsif along with .class or .is_? in order to maintain performance. As string operations while iterating entities is just all too big of an performance hit.
                  • Didier BurD
                    Didier Bur
                    Thanks tt & tig for yur answers;
                    I'm aware of the "strings comparison time killer" that's why i want to use the class for the switch.
                    i'll use "elseif" instead 😞
                    DB
                      I really don't understand why switch own't work - since face1.class == face2.class work fine...
                        Ah - so then we can just do this:
                        def test()
                                when Sketchup;;Face
                                 puts "face"
                                 puts "instance"
                                 puts "group"
                                 puts "image"
                                when Sketchup;;Edge
                                 puts "edge"
                                else
                        ❓ Right?
                        • Didier BurD
                          Didier Bur
                          Partial answer here: http://www.postal-code.com/mrhappy/blog/2007/02/01/ruby-comparing-an-objects-class-in-a-case-statement/
                          and here http://groups.google.com/group/comp.lang.ruby/browse_thread/thread/3d83faf049160e58
                          This works:
                                       puts "face"
                          The simplest the best !
                          DB
                            This works:
                            >              puts "face"
                            So in your case
                                def test()
                                        when Sketchup;;Face
                                         puts "face"
                                         puts "instance"
                                         puts "group"
                                         puts "image"
                                        when Sketchup;;Edge
                                         puts "edge"
                                        else
                            should work ??? Avoiding the .to_s step πŸ˜„
