[Code] Win32 - Get SketchUp Window Handle (WIP)
The example I saw of it:
http://stackoverflow.com/questions/3327666/win32s-findwindow-can-find-a-particular-window-with-the-exact-title-but-what/3328209#3328209Seemed to use namespace
Win32
as oppose toWin32API
.So this is not a module that ships with Ruby?
Correct... no it's not, because it is platform specific, AND considered an extension. You, or any user must download it from RubyForge. If you want the latest releases, as they are released. I believe you also must compile them yourself, or wait until Mr. Berger & Co decides to do it.
@thomthom said:
win32-api Seemed to use namespace
Win32
.True it has it's own namespace... and another quirk.. Dan Berger reordered the arguments in the API calls making it a bit cumbersome to have scripts that can use either library.
@jim said:
I am not entirely sure the Win32API.so file we all have been using supports callbacks, which the windows enumerator functions require as arguments. ...
Specifically, calls to EnumWindows and EnumChildWindows can not be used with Win32API.Actually Win32API.so is obsolete, and for some time, they have been suggesting coders migrate to using the DL library directly.
In Ruby vers 1.9.x and up... they no longer supply a Win32API.so file, instead they have replaced it with a Win32API.rb script that mimics the old so file, and translates Win32API calls into DL library calls.
This is the Win32API.rb file distro'd with Ruby v 1.9.1 p429
<span class="syntaxdefault"></span><span class="syntaxcomment"># -*- ruby -*-<br /># for backward compatibility<br /></span><span class="syntaxdefault">warn </span><span class="syntaxstring">"Warning;#{caller[0].sub(/;in `.*'\z/, '')}; Win32API is deprecated after Ruby 1.9.1; use dl directly instead"</span><span class="syntaxdefault"> if $VERBOSE<br /><br />require </span><span class="syntaxstring">'dl'<br /><br /></span><span class="syntaxdefault">class Win32API<br /> DLL </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">{}<br /></span><span class="syntaxdefault"> TYPEMAP </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">{</span><span class="syntaxstring">"0"</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">=></span><span class="syntaxdefault"> DL</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">TYPE_VOID</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> </span><span class="syntaxstring">"S"</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">=></span><span class="syntaxdefault"> DL</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">TYPE_VOIDP</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> </span><span class="syntaxstring">"I"</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">=></span><span class="syntaxdefault"> DL</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">TYPE_LONG</span><span class="syntaxkeyword">}<br /><br /></span><span class="syntaxdefault"> def initialize</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">dllname</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> func</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> import</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> export </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> </span><span class="syntaxstring">"0"</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">*</span><span class="syntaxdefault">rest</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault"> </span><span class="syntaxkeyword">@</span><span class="syntaxdefault">proto </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">[</span><span class="syntaxdefault">import</span><span class="syntaxkeyword">].</span><span class="syntaxdefault">join</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">tr</span><span class="syntaxkeyword">(</span><span class="syntaxstring">"VPpNnLlIi"</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> </span><span class="syntaxstring">"0SSI"</span><span class="syntaxkeyword">).</span><span class="syntaxdefault">sub</span><span class="syntaxkeyword">(/^(.)</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">*$/,</span><span class="syntaxdefault"> </span><span class="syntaxstring">'\1'</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault"> handle </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> DLL</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">dllname</span><span class="syntaxkeyword">]</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">||=</span><span class="syntaxdefault"> DL</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">dlopen</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">dllname</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault"> </span><span class="syntaxkeyword">@</span><span class="syntaxdefault">func </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> DL</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">CFunc</span><span class="syntaxkeyword">.new(</span><span class="syntaxdefault">handle</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">func</span><span class="syntaxkeyword">],</span><span class="syntaxdefault"> TYPEMAP</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">export</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">tr</span><span class="syntaxkeyword">(</span><span class="syntaxstring">"VPpNnLlIi"</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> </span><span class="syntaxstring">"0SSI"</span><span class="syntaxkeyword">)],</span><span class="syntaxdefault"> func</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">*</span><span class="syntaxdefault">rest</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault"> end<br /><br /> def call</span><span class="syntaxkeyword">(*</span><span class="syntaxdefault">args</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault"> import </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">@</span><span class="syntaxdefault">proto</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">split</span><span class="syntaxkeyword">(</span><span class="syntaxstring">""</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault"> args</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">each_with_index do </span><span class="syntaxkeyword">|</span><span class="syntaxdefault">x</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> i</span><span class="syntaxkeyword">|<br /></span><span class="syntaxdefault"> args</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">i</span><span class="syntaxkeyword">],</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">[</span><span class="syntaxdefault">x </span><span class="syntaxkeyword">==</span><span class="syntaxdefault"> 0 </span><span class="syntaxkeyword">?</span><span class="syntaxdefault"> nil </span><span class="syntaxkeyword">;</span><span class="syntaxdefault"> x</span><span class="syntaxkeyword">].</span><span class="syntaxdefault">pack</span><span class="syntaxkeyword">(</span><span class="syntaxstring">"p"</span><span class="syntaxkeyword">).</span><span class="syntaxdefault">unpack</span><span class="syntaxkeyword">(</span><span class="syntaxstring">"l!*"</span><span class="syntaxkeyword">)</span><span class="syntaxdefault"> if import</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">i</span><span class="syntaxkeyword">]</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">==</span><span class="syntaxdefault"> </span><span class="syntaxstring">"S"<br /></span><span class="syntaxdefault"> args</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">i</span><span class="syntaxkeyword">],</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">[</span><span class="syntaxdefault">x</span><span class="syntaxkeyword">].</span><span class="syntaxdefault">pack</span><span class="syntaxkeyword">(</span><span class="syntaxstring">"I"</span><span class="syntaxkeyword">).</span><span class="syntaxdefault">unpack</span><span class="syntaxkeyword">(</span><span class="syntaxstring">"i"</span><span class="syntaxkeyword">)</span><span class="syntaxdefault"> if import</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">i</span><span class="syntaxkeyword">]</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">==</span><span class="syntaxdefault"> </span><span class="syntaxstring">"I"<br /></span><span class="syntaxdefault"> end<br /> ret</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">@</span><span class="syntaxdefault">func</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">call</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">args</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault"> return ret </span><span class="syntaxkeyword">||</span><span class="syntaxdefault"> 0<br /> end<br /><br /> alias Call call<br />end<br /></span>
It looks as though the DL library supports callbacks. Maybe we should use it ??
I've also read that the DL library is 'on the outs', and they are planning to deprecate it and replace it with something else.
@jim said:
The win32-api ruby library does support callbacks, and we should really be using it anyway. it's more robust, and more stable (I've read.)
Yes.. I agree. Dan Berger is a "sharp cookie" when it comes to both Ruby and Windows coding. He is also on several of the MAJOR Ruby development teams including RubyGems and rdoc.
See his profile: RubyForge Profile for Daniel Berger -
Will that work for Ruby 1.8?
@thomthom said:
I think one can get lots of useful info if one can get the thread id of the SketchUp process. Any ideas of how one can do this.
How about?
Process.pid()
Thread.main.object_id
@thomthom said:
I've been scanning the Win32 API a bit today looking for relevant functions.
Well all the API functions for: [Processes and Threads](http://msdn.microsoft.com/en-us/library/ms684847(v)
Ah - there we go, that might help.
GetCurrentProcessId
looks promising. -
pid = GetCurrentProcessId.call 4684 Process.pid() 4684
It seem to return the same thing. -
It seem to return the same thing.Yes and it's the same as you'll see in the Task Manager, or using tlist.exe from the command line (for that Sketchup instance.)
My bad..
Callbacks were added in 1.9.x, both 1.8.6 and 1.8.7 DL libs don't have the callback.rb file.sorry Thom
GetCurrentThreadId
I think this one is what we can use to get associated window handles. Just need to get callbacks working so we can useEnumThreadWindows
to get the windows for the calling thread. -
@jim said:
@thomthom said:
Where is the win32-api found - the one that supports callbacks?
http://win32utils.rubyforge.org/
I'm not sure if this can co-exist with Win32API or not.
require 'win32/api'
[attachment=0:26ojrmbj]<!-- ia0 -->win32.zip<!-- ia0 -->[/attachment:26ojrmbj]I just tried it, works fine with Win32API.
Here's a bastardised proof of concept snippet where I found the SketchUp window regardless if it had focus or not.
# http://stackoverflow.com/questions/3327666/win32s-findwindow-can-find-a-particular-window-with-the-exact-title-but-what EnumWindows = Win32;;API.new('EnumWindows', 'KP', 'L', 'user32') EnumThreadWindows = Win32;;API.new('EnumThreadWindows', 'LKP', 'I', 'user32') GetCurrentThreadId = Win32API.new("kernel32.dll", "GetCurrentThreadId", '', 'L') # Detect the toolwindows even if Hide Dialogs is active. def enum_sketchup_windows threadId = GetCurrentThreadId.call enumWindowsProc = Win32;;API;;Callback.new('LP', 'I'){ |handle, param| #puts "EnumWindows - Callback" #puts "> handle; #{handle}" #puts "> param; #{param.inspect}" window_text = get_window_text(handle) window_text.strip! # Remove trailing NULL character p window_text unless window_text.empty? if !window_text.index(param).nil? puts "window was found; handle #{handle}" 0 # FALSE - stop looking after we find it 1 # TRUE else 1 # TRUE end } EnumThreadWindows.call(threadId, enumWindowsProc, 'SketchUp') end # Takes the first enumerated window for the calling SketchUp thread and fetches # the root owner which should be the SketchUp window. (Not tested against wxSU) # # Is the enum required to get just one window? Any other function to get an # arbitrary window from the SketchUp thread? def find_sketchup_window threadId = GetCurrentThreadId.call hwnd = 0 enumWindowsProc = Win32;;API;;Callback.new('LP', 'I'){ |handle, param| hwnd = GetAncestor.call(handle, GA_ROOTOWNER) 0 } EnumThreadWindows.call(threadId, enumWindowsProc, 'SketchUp') hwnd end
Remaining issues:
- Migrate
Win32API
toWin32::API
for all function calls. - While testing I eventually got an exception that said there was too many callbacks initiated. Seems there might be a limit. I have not looked into this further, but I think once might have to make one callback proc, and then delegate to the appropriate handling method based on
param
- Migrate
= Documentation
The source file contains inline RDoc documentation. If you installed
this file as a gem, then you have the docs.Where do you get the source code?
I tried to install the gem, but got this error:
It is a c-language based extension, and apparently isn't available already compiled for your platform. So you would need to compile it.
This is the advantage of using the mingw32 Ruby Installer with devkit - it automatically builds native libraries.
But where is the source code - since it's suppose to contain the documentation?
For me, it is here:
C:\Ruby186\lib\ruby\gems\1.8\gems\win32-api-1.4.7-x86-mingw32\ext\win32
hm... guess I have to look into that ming-thing...
Anyway - I have produced a code which appear to return the handle for the SketchUp window of the calling thread. I created a EnumWindowsProc to delegate enumeration messages in order to avoid
Error: #<Win32::API::Error: too many callbacks are defined.>
. I really want to know what this limit is. This is the first draft, I expect there is a better way to deal with this.But, we do get a reliable window for the SketchUp window we want - as far as I have been able to test.
Maybe we can handle drag and drop by callbacks. Or intercept window messages so we can simulate the roll-up/down of toolwindows.
Still, OSX users are out of luck here...
Here's some interesting info:
# # some Sketchup window properties; # # AutomationId = "" # # CLASS = "Afx;00400000;b;00010011;00000006;00790557" # *** the last octet changes each time Sketchup is run, # examples; "Afx;00400000;b;00010011;00000006;0012077F" # "Afx;00400000;b;00010011;00000006;000E0699" # # ControlType = "ControlType.Window" # LocalizedControlType = "window" #
The main application window is the only one with a classname like this, and also the only one with a LocalizedControlType that equals "window".
ALL dialogs including WebDialogs, are:
# # ClassName = "#32770" # ControlType = "ControlType.Window" # LocalizedControlType = "Dialog" #
Are you planning on distibuting a pre-compiled win-api as part of TT_Lib2 ??
I have a few issues with this.
(1) It's not in the correct folder. What if a person already has it (and possibly a newer version,) installed ?require will not recognize the path string you have in that example, and would load the older version down under your TT_Lib2 folder. That would overwrite the newer classes that might be loaded, if they were loaded first.
OR.. since "T" comes before "W" your version would get loaded first, and when a normal version gets loaded after... your code might get broken. (I say "might" as newer versions are usually better.)
So? I like the idea of someone precompiling Berger's WinUtils, and zipping them for manual install by the community (and/or creating a one-click-installer for dummies.) But they should be in the proper folder ... and likely a path to them appended to the $LOAD_PATH array.
How much of Berger's suite would the distro have? the bare bones min or the whole thing?
