    [Code] Win32 - Get SketchUp Window Handle (WIP)
    40 Posts 5 Posters 13.5k Views 5 Watching
      Further testing: the method will fail if the SketchUp window isn't the active window.
      • honoluludesktopH
        honoluludesktop
        Handle is a term I recall from my "good old DOS days" :-) Can the "SketchUp Window Handle" be used to close an instance of SketchUp from another instance of SketchUp?
        • Dan RathbunD
          Dan Rathbun
          Yes ... BUT ... we must first solve the issue of getting the CORRECT handle for each instance, and storing it (in the proper place,) where it can be accessed by multiple plugins.
          Once the "handle" is determined, the code that was needed to find it, is no longer needed, and should be garbage collected.
          THEN ... you'll need to solve the issue of talking between two instances of Sketchup Ruby, and having one inform the other what it's window handle is.
          I'm not here much anymore.
            GetActiveWindow
            http://msdn.microsoft.com/en-us/library/ms646292%28v=vs.85%29.aspx
            The return value is the handle to the active window attached to the calling thread's message queue. Otherwise, the return value is NULL.
            What is interesting with this function is that it find a window based on the calling thread. But it's limitation is that it requires one of the windows that belong to the thread to the the active one.
            But, I'm trying to find a function that either let you enumerate the windows that belong to a thread, or get the top most window for a thread. In either one of those conditions one should be able to reliably get the window handle.
            I think one can get lots of useful info if one can get the thread id of the SketchUp process. Any ideas of how one can do this. I've been scanning the Win32 API a bit today looking for relevant functions.
              @jim said:
              I am not entirely sure the Win32API.so file we all have been using supports callbacks, which the windows enumerator functions require as arguments.
              Specifically, calls to EnumWindows and EnumChildWindows can not be used with Win32API.
              The win32-api ruby library does support callbacks, and we should really be using that it anyway. it's more robust, and more stable (I've read.)
              I was just looking at this. I noticed the lack of Callback.
              Where is the win32-api found - the one that supports callbacks?
                Jim
                Fastly error: unknown domain 151.101.64.204
                (win32utils.rubyforge.org)
                I'm not sure if this can co-exist with Win32API or not.
                require 'win32/api'
                win32.zip
                  Jim
                  The win32-api ruby library does support callbacks, and we should really be using it anyway. it's more robust, and more stable (I've read.)
                    The example I saw of it:
                    http://stackoverflow.com/questions/3327666/win32s-findwindow-can-find-a-particular-window-with-the-exact-title-but-what/3328209#3328209
                    Seemed to use namespace Win32 as oppose to Win32API.
                    So this is not a module that ships with Ruby?
                    • Dan RathbunD
                      Dan Rathbun
                      Correct... no it's not, because it is platform specific, AND considered an extension. You, or any user must download it from RubyForge. If you want the latest releases, as they are released. I believe you also must compile them yourself, or wait until Mr. Berger & Co decides to do it.
                      • Dan RathbunD
                        Dan Rathbun
                        @thomthom said:
                        win32-api Seemed to use namespace Win32 as oppose to Win32API.
                        True it has it's own namespace... and another quirk.. Dan Berger reordered the arguments in the API calls making it a bit cumbersome to have scripts that can use either library.
                        • Dan RathbunD
                          Dan Rathbun
                          @jim said:
                          I am not entirely sure the Win32API.so file we all have been using supports callbacks, which the windows enumerator functions require as arguments. ...
                          Actually Win32API.so is obsolete, and for some time, they have been suggesting coders migrate to using the DL library directly.
                          In Ruby vers 1.9.x and up... they no longer supply a Win32API.so file, instead they have replaced it with a Win32API.rb script that mimics the old so file, and translates Win32API calls into DL library calls.
                          This is the Win32API.rb file distro'd with Ruby v 1.9.1 p429
                          <span class="syntaxdefault"></span><span class="syntaxcomment"># -*- ruby -*-<br /># for backward compatibility<br /></span><span class="syntaxdefault">warn </span><span class="syntaxstring">"Warning;#{caller[0].sub(/;in `.*'\z/, '')}; Win32API is deprecated after Ruby 1.9.1; use dl directly instead"</span><span class="syntaxdefault"> if $VERBOSE<br /><br />require </span><span class="syntaxstring">'dl'<br /><br /></span><span class="syntaxdefault">class Win32API<br />  DLL </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">{}<br /></span><span class="syntaxdefault">  TYPEMAP </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">{</span><span class="syntaxstring">"0"</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">=></span><span class="syntaxdefault"> DL</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">TYPE_VOID</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> </span><span class="syntaxstring">"S"</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">=></span><span class="syntaxdefault"> DL</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">TYPE_VOIDP</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> </span><span class="syntaxstring">"I"</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">=></span><span class="syntaxdefault"> DL</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">TYPE_LONG</span><span class="syntaxkeyword">}<br /><br /></span><span class="syntaxdefault">  def initialize</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">dllname</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> func</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> import</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> export </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> </span><span class="syntaxstring">"0"</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">*</span><span class="syntaxdefault">rest</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">    </span><span class="syntaxkeyword">@</span><span class="syntaxdefault">proto </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">[</span><span class="syntaxdefault">import</span><span class="syntaxkeyword">].</span><span class="syntaxdefault">join</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">tr</span><span class="syntaxkeyword">(</span><span class="syntaxstring">"VPpNnLlIi"</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> </span><span class="syntaxstring">"0SSI"</span><span class="syntaxkeyword">).</span><span class="syntaxdefault">sub</span><span class="syntaxkeyword">(/^(.)</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">*$/,</span><span class="syntaxdefault"> </span><span class="syntaxstring">'\1'</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">    handle </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> DLL</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">dllname</span><span class="syntaxkeyword">]</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">||=</span><span class="syntaxdefault"> DL</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">dlopen</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">dllname</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">    </span><span class="syntaxkeyword">@</span><span class="syntaxdefault">func </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> DL</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">CFunc</span><span class="syntaxkeyword">.new(</span><span class="syntaxdefault">handle</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">func</span><span class="syntaxkeyword">],</span><span class="syntaxdefault"> TYPEMAP</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">export</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">tr</span><span class="syntaxkeyword">(</span><span class="syntaxstring">"VPpNnLlIi"</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> </span><span class="syntaxstring">"0SSI"</span><span class="syntaxkeyword">)],</span><span class="syntaxdefault"> func</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">*</span><span class="syntaxdefault">rest</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">  end<br /><br />  def call</span><span class="syntaxkeyword">(*</span><span class="syntaxdefault">args</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">    import </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">@</span><span class="syntaxdefault">proto</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">split</span><span class="syntaxkeyword">(</span><span class="syntaxstring">""</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">    args</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">each_with_index do </span><span class="syntaxkeyword">|</span><span class="syntaxdefault">x</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> i</span><span class="syntaxkeyword">|<br /></span><span class="syntaxdefault">      args</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">i</span><span class="syntaxkeyword">],</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">[</span><span class="syntaxdefault">x </span><span class="syntaxkeyword">==</span><span class="syntaxdefault"> 0 </span><span class="syntaxkeyword">?</span><span class="syntaxdefault"> nil </span><span class="syntaxkeyword">;</span><span class="syntaxdefault"> x</span><span class="syntaxkeyword">].</span><span class="syntaxdefault">pack</span><span class="syntaxkeyword">(</span><span class="syntaxstring">"p"</span><span class="syntaxkeyword">).</span><span class="syntaxdefault">unpack</span><span class="syntaxkeyword">(</span><span class="syntaxstring">"l!*"</span><span class="syntaxkeyword">)</span><span class="syntaxdefault"> if import</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">i</span><span class="syntaxkeyword">]</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">==</span><span class="syntaxdefault"> </span><span class="syntaxstring">"S"<br /></span><span class="syntaxdefault">      args</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">i</span><span class="syntaxkeyword">],</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">[</span><span class="syntaxdefault">x</span><span class="syntaxkeyword">].</span><span class="syntaxdefault">pack</span><span class="syntaxkeyword">(</span><span class="syntaxstring">"I"</span><span class="syntaxkeyword">).</span><span class="syntaxdefault">unpack</span><span class="syntaxkeyword">(</span><span class="syntaxstring">"i"</span><span class="syntaxkeyword">)</span><span class="syntaxdefault"> if import</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">i</span><span class="syntaxkeyword">]</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">==</span><span class="syntaxdefault"> </span><span class="syntaxstring">"I"<br /></span><span class="syntaxdefault">    end<br />    ret</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">@</span><span class="syntaxdefault">func</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">call</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">args</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">    return ret </span><span class="syntaxkeyword">||</span><span class="syntaxdefault"> 0<br />  end<br /><br />  alias Call call<br />end<br /></span>
                          It looks as though the DL library supports callbacks. Maybe we should use it ??
                          I've also read that the DL library is 'on the outs', and they are planning to deprecate it and replace it with something else.
                          Yes.. I agree. Dan Berger is a "sharp cookie" when it comes to both Ruby and Windows coding. He is also on several of the MAJOR Ruby development teams including RubyGems and rdoc.
                          See his profile: RubyForge Profile for Daniel Berger
                            Will that work for Ruby 1.8?
                            • Dan RathbunD
                              Dan Rathbun
                              How about?
                              Process.pid()
                              Thread.main.object_id
                              Well all the API functions for: [Processes and Threads](http://msdn.microsoft.com/en-us/library/ms684847(v)
                                Ah - there we go, that might help.
                                GetCurrentProcessId looks promising.
                                  pid = GetCurrentProcessId.call 4684 Process.pid() 4684
                                  It seem to return the same thing.
                                  • Dan RathbunD
                                    Dan Rathbun
                                    Yes and it's the same as you'll see in the Task Manager, or using tlist.exe from the command line (for that Sketchup instance.)
                                    • Dan RathbunD
                                      Dan Rathbun
                                      My bad.. 😳
                                      Callbacks were added in 1.9.x, both 1.8.6 and 1.8.7 DL libs don't have the callback.rb file.
                                      sorry Thom
                                        GetCurrentThreadId I think this one is what we can use to get associated window handles. Just need to get callbacks working so we can use EnumThreadWindows to get the windows for the calling thread.
                                          require 'win32/api'
                                          [attachment=0:26ojrmbj]<!-- ia0 -->win32.zip<!-- ia0 -->[/attachment:26ojrmbj]
                                          I just tried it, works fine with Win32API.
                                          Here's a bastardised proof of concept snippet where I found the SketchUp window regardless if it had focus or not.
                                          # http://stackoverflow.com/questions/3327666/win32s-findwindow-can-find-a-particular-window-with-the-exact-title-but-what
                                          EnumWindows       = Win32;;API.new('EnumWindows', 'KP', 'L', 'user32')
                                          EnumThreadWindows = Win32;;API.new('EnumThreadWindows', 'LKP', 'I', 'user32')
                                          GetCurrentThreadId = Win32API.new("kernel32.dll", "GetCurrentThreadId", '', 'L')
                                          # Detect the toolwindows even if Hide Dialogs is active.
                                          def enum_sketchup_windows
                                            threadId = GetCurrentThreadId.call
                                            enumWindowsProc = Win32;;API;;Callback.new('LP', 'I'){ |handle, param|
                                              #puts "EnumWindows - Callback"
                                              #puts "> handle; #{handle}"
                                              #puts "> param; #{param.inspect}"
                                              window_text = get_window_text(handle)
                                              window_text.strip! # Remove trailing NULL character
                                              p window_text unless window_text.empty?
                                              if !window_text.index(param).nil?
                                                puts "window was found; handle #{handle}"
                                                0 # FALSE - stop looking after we find it
                                                1 # TRUE
                                              else
                                                1 # TRUE
                                            EnumThreadWindows.call(threadId, enumWindowsProc, 'SketchUp')
                                          # Takes the first enumerated window for the calling SketchUp thread and fetches
                                          # the root owner which should be the SketchUp window. (Not tested against wxSU)
                                          # Is the enum required to get just one window? Any other function to get an
                                          # arbitrary window from the SketchUp thread?
                                          def find_sketchup_window
                                            hwnd = 0
                                              hwnd = GetAncestor.call(handle, GA_ROOTOWNER)
                                            hwnd
                                          Remaining issues:
                                          • Migrate Win32API to Win32::API for all function calls.
                                          • While testing I eventually got an exception that said there was too many callbacks initiated. Seems there might be a limit. I have not looked into this further, but I think once might have to make one callback proc, and then delegate to the appropriate handling method based on param.
                                            = Documentation
                                            The source file contains inline RDoc documentation. If you installed
                                            this file as a gem, then you have the docs.
                                            Where do you get the source code?
                                            I tried to install the gem, but got this error:
