City Engine to SketchUp Questions
I'm trying to import a model created in City Engine into SketchUp and keep the textures. The file type is .obj with the material files being .ppm and .mtl. Has anybody had any luck with this sort of import?
Thanks,
Lars
What importer are you using?
I would suggest using TIG's .obj importer plugin. Then make sure all materials are in the same folder as the .obj file. That might do the trick.
I'm not sure what the .ppm file is though.
