    SHADOW SETTINGS DIALOG BOX
    7 Posts 5 Posters 866 Views 5 Watching
    • pmolsonP Offline
      pmolson
      Good Morning,
      This morning I seem to have lost my shadow settings dialog box.
      When I click the toolbar button for shadow settings nothing happens.
      The button next to this that turns shadows off & on works fine.
      Without the shadow settings box I am unable to un-check "shadows on ground plane"
      for example.
      I thought it might be hiding under other dialog boxes so I closed them all and
      it was not hiding.
      I tried the "display dialogs" shortcut & that did not work.
      I tried shutting down and restarting. No such luck.
      This is the same system I use every day all day, no changes or updates or....anything.
      windows 7 pro, su 8 pro,
      Anybody have any ideas, short of re-installing?
      Paul
        dedmin
        Happens to me several times - just reinstall SketchUP.
          Jim
          Happens to me also, but I can get it back by enabling the dialog, then closing/opening SU.
            Jim
            I made this utility today - if it happens again, it'll be waiting in the Window menu.
            404 Not Found
            (forums.sketchucation.com)
            • pmolsonP Offline
              pmolson
              Thanks Jim, I will try it.
              Dedmin, thanks for the suggestion. I will try other method prior to
              re-installing. I find re-installing...unsettling.
              p
                lapx
                My shadow setting dialog box wont let me toggle the display toggles i.e on ground plane.
                How can this be fixed? I need to be able to change these.
                huh? now it appaers to be working. Was ghosted out before where one could not chnage the parameters. Strange? πŸ˜•
                  It is ghosted out until you turn on shadows at all.
