    [Plugin] TECLA 0.1
    39 Posts 18 Posters 42.2k Views 18 Watching
    • bomastudioB Offline
      bomastudio
      Hi all,
      I wrote a plugin for Architects: TECLA. It adds new tools for insert walls, floor, columns, like in ArchiCAD, AllPlan ecc. It's free. And it's is in beta stage. I wish it is usefull.
      some video explain it better:
      01_IMPORT DXF in SketchUp free version
      [flash=600,450:pwyg5hwh]http://www.youtube.com/v/rmpvTnWSmgU?fs=1&hl=it_IT[/flash:pwyg5hwh]
      02_BUILD CONTOUR FROM A GOOGLE EARTH MESH SITE
      [flash=600,450:pwyg5hwh]http://www.youtube.com/v/KHxnd3xKyOE?fs=1&hl=it_IT[/flash:pwyg5hwh]
      the link to the home page of the project
      http://sites.google.com/site/teclait/
      README:
      TECLA is available as a setup.exe: this will be installed, as default, in the SketchUp 8/plugin/ folder. Here will be created a folder TECLA and two script: TECLA and TECLA_edit.
      After TECLA is installed, the setup will lauch for you the installation process of WxSU, a required library for use TECLA: as default, wxSU has target SketchUp 7/plugin, so if your version of SU is 8 YOU NEED TO MANUALLY CORRECT THE PATH for 7 to 8, i.e:
      form
      ... /Google SketchUp 7/plugin
      to
      ... /Google SketchUp 8/plugin
      The wxSu library must be installed outside the TECLA subfolder but INSIDE the plugin folder.
      Good work!!
      • soloS Offline
        Got a link?
          bomastudio
          Sorry, posted the link! πŸ˜„
          • Didier BurD Offline
            Didier Bur
            An installation guide or readme file will be handy... or do I get it after running the setup (sorry, I don't like setup.exe's)
            Do I need to download and install wxSU to run TECLA ?
            DB
            • utilerU Offline
              utiler
              Sounds interesting Bomastudio.... Keen to have a look!!!
              Just Curious...
                bomastudio
                @didier bur said:
                Yes, after running the setup you will read (in italian only at the moment, sorry .... πŸ˜• ) some readme.
                Didier, this is the first time I publish some code, so I need more guide to be correct toward other programmers. For one of the tool (wall tool) I start studing one of your script (thank you very much, you're great!!). Where you suggest me to tell the world I start from your script?.
                My setup.exe will install for you, with the warning that you MUST CHOOSE THE SAME FOLDER for both TECLA and WxSU.
                thank you very much for the future suggestion.
                  bomastudio
                  Thank you for your interest! Please, give me the more feedback you can!!
                    archano
                    visto che di italiani sul sito se ne vedono pochi, i complimenti te li faccio nella ns bella lingua ... bel lavoro ..ora sono curioso di vedere gli altri moduli...!!! πŸ‘
                      bomastudio
                      Grazie 1000!!!
                      Ho brutte notizie....gli altri moduli verranno non prima dell'anno prox!! πŸ˜• Vorrei prima finire il modulo architettura.... al momento ho in progetto di finire l'importatore dxf (anche 3D), aggiungere gli strumenti porte/finestre e scale..... spero di aggiornare presto....
                        Didier Bur
                        No, do as you like, it depends if my script was just a starting point or not...
                        DB
                          archano
                          .. . visto che sono un utilizzatore di archicad fin dalla versione 7 non può che farmi piacere il tuo impegno nello sviluppo di strumenti simili per sketch il che mi permette, tra l'altro, anche un miglior utilizzo "scolastico" dello stesso.. 😍
                            bomastudio
                            Cosa intendi per uso "scolastico"? Mi sembra interessante...
                            • tridemT Offline
                              tridem
                              Scusate se rompo, ma prima che lo faccia un moderatore.... πŸ˜‰
                              please, it's not too kind for other users writing in italian, for matters of general interest is recommended you use english, otherwise we have an italian section in the forum (not so attended indeed... πŸ˜• )
                              btw congrats bomastudio, it looks very interesting πŸ‘
                              • srxS Offline
                                srx
                                πŸ‘ Very interesting. Could you make it in English?
                                www.saurus.rs
                                  bomastudio
                                  right observation..... where is the italian section?
                                    bomastudio
                                    @srx said:
                                    :thumb: Very interesting. Could you make it in English?
                                    I'm working in this direction.... just a few days and it will be translated ....
                                    • tridemT Offline
                                      tridem
                                      if you want to see the national language sections, you have to join the related usergroup in the User Control Panel.
                                        dizain
                                        Message:
                                        Error loading Files wxSU-Example.rb
                                        Ciao
                                        David
                                          bomastudio
                                          @dizain said:
                                          Message:
                                          When appear this message?
                                            dizain
                                            when I open sketchup.
                                            Winxp
                                            Sketchup pro V7.1.6860
                                            Ciao
                                            David
