    Request
    4 Posts 3 Posters 532 Views 3 Watching
      JuanV.Soler
      I am looking for a plugin able to erase perpendicular lines that have a height different to 0
      as well as another one able to drop parallel lines to z = 0
      all inside a group
      is it possible ?
      Thanks in advance 😄
        If you want to remove just lines that have ends at different heights then use something like
        m=Sketchup.active_model;s=m.selection.to_a;s.each{|e|next if e.class!="Sketchup;;Edge"; e.erase! if e.start.position.z!=e.end.position.z}
        To erase all 'level' lines that are not at z=0
        m=Sketchup.active_model;s=m.selection.to_a;s.each{|e|next if not e.class!="Sketchup;;Edge"; e.erase! if e.start.position.z!=e.end.position.z and e.end.position.z!=0}
        To 'flatten' lines so they are level... is more complicated as you need to transform the end_vertex.z to match the start_vertex.z of the line etc... 😕
        • srxS
          srx
          ThomThom Plan tools
          www.saurus.rs
            JuanV.Soler
            Thanks TIG and srx
            I will see if I can manage 👍
