    V6.0 compatibility
    11 Posts 4 Posters 781 Views 4 Watching
      First question - is the path correct ?
      For example, if they are in a sub-folder they won't load with that code...
      • honoluludesktopH
        honoluludesktop
        There is no path, all files are in the plugin folder, and it works in v7, and v8.
          @honoluludesktop said:
          UI::Command.new(("Select First Component"))
          Double brackets?
          • honoluludesktopH
            honoluludesktop
            OK, fixed that, but not the problem. What size do you fellows make your icons?
              16 for small icons, 24 for large. That is optimal sizes for best visual quality. Any other size and SU will resize the icons - poorly.
              As for the original question - have you tried if absolute paths is required in SU6?
              • honoluludesktopH
                honoluludesktop
                OK on the icon sizes, and no, didn't understand that I should try that for v6. Will try it, thanks.
                • honoluludesktopH
                  honoluludesktop
                  The v6 user said that the sized down icons did the trick. Anyway, I did both, sized down the icons, and placed a full path to the icon:
                  ` file_path_name=Sketchup.find_support_file "sketchup.exe", ""
                  file_path_name=File.dirname(file_path_name)+"/Plugins/hdt_folder/"
                  select_tb = UI::Toolbar.new("Select Components")
                  cmd2 = UI::Command.new("Select First Component") { hdt_clear_select_component }
                  cmd2.small_icon = file_path_name+"button_first_16.png"
                  cmd2.large_icon = file_path_name+"button_first_24.png"
                  cmd2.tooltip = "First Instance"
                  select_tb.add_item(cmd2)`
                  Any problem with the way I derived the drive_letter\pathname?
                  Below is a couple of the icons I drew at 50%. The following pair was reduced to 16 pixels square and displays as such. Any ideas how to improve the 16 pixel square's appearance?
                  Pair of icons drawn in sketchup.
                  The icon image reduced to 16 pixels square.
                    Jim
                    Many of the SketchUp icons are made in SketchUp and Layout. Google posted some 800x800px images of them on the official blog - they might give you some indication about how to make your icons in SketchUp.
                    Error 404 (Not Found)!!1
                    (sketchupdate.blogspot.com)
                    What software are you using to resize the images?
                    • honoluludesktopH
                      honoluludesktop
                      I am drawing the icons in Sketchup, and sizing them down with a Win2000 utility. Hmmm...think that's the problem? I will try a high end image editor.
                        Jim
                        Possibly (even likely.) There may be several settings to chose from when resizing the image; some designed for speed, others for quality. That may be all you need.
