    [Plugin] Select consecutive components v2.0 110510
    20 Posts 5 Posters 35.4k Views 5 Watching
    • honoluludesktopH Offline
      honoluludesktop
      Took a bit of effort, but I've combined the applications into one. All the functions are now in the tool bar, including "reverse_back_faces" if it is included in the default plugins folder.
      http://forums.sketchucation.com/download/file.php?id=58993
      First instance, next instance, select all or unique instances, and reverse back faces.
        honoluludesktop
        Provided minor enhancement. Mac cookie to the first one that IDs "what_is_it?".
        • facerF Offline
          facer
          Using SketchUp v6
          Select_each_component Plugin.
          Thankyou for your effort on the plugin, it holds promise.
          I unzipped the toolbar icons into the main plugins folder as per instructions.
          When I activate the plugin the tool bar is visible but without the toolbar icon pics.
          When I place my cursor over the first button it reads "first instance".
          Any suggestions as to why this may be.
          Regards
            honoluludesktop
            Not sure, the toolbar api commands are all SU v6.0+. I did not however, size the icons in a typical manner, since they ran OK in SU v 8.0. I do not have a copy of SU v6.0, and can not test the plugin with it. Give me a while, and I will make a set of icons for you to check with SU v6.0.
              honoluludesktop
              Facer, The previous menu icons were incorrectly titled, try these. Please let me know if this corrects the problem.
              Unzip, and place in plugin folder. If you like, remove the incorrectly named icon images.
              • facerF Offline
                facer
                HDT,
                Same as before, grey toolbar set with no icons displayed.
                A question:
                Why are the toolbar icons not stored in a "folder" linked to your plugin?
                At present the icons are stored in:
                C:\Program Files\Google\Google SketchUp 6\Plugins
                Regards.
                  honoluludesktop
                  Facer, Try these icons. You have the plugins in the correct folder. There is no good reason that I did not place the icons in a plugins/sub-folder. I have another release coming up, and perhaps I will do it at that time. In View > Toolbars, what is your toolbar button size set to? Try these icons at both large, and small size.
                  Oops, sorry, I bumped the topic at the bottom.
                  Unzip, and place in plugins folder.
                  • Bob JamesB Offline
                    Bob James
                    I have the same problem: the toolbar is there but no icons.
                    My icons are stored in:
                    C:\Program Files\Google\Google SketchUp 8\Plugins
                    • facerF Offline
                      facer
                      HDT,
                      Okay now with icons using "Select_button_24.zip"
                      I note these png image sizes as 21x24.
                      Your previous "Select_buttons" had a png image size of
                      314x363
                      Thanks for your assistance.
                        honoluludesktop
                        This upgrade includes some enhancements, and attempts to provide compatibility with SU v6.
                        The top image are the components, the second is with hidden lines on, the third and forth with unselected hidden, and the fifth is by all, selecting nested components.
                          honoluludesktop
                          Added current selection of components to all components in the model in this update along with an improved user interface.
